BMT45 - Indexer Turret - Replacement - AD0746
Service Home How To Procedures BMT45 - Indexer Turret - Replacement - AD0746
- Jump to Section - 1. Introduction (12 steps) 2. Replacement (12 steps) Back to Top
Recently Updated Last updated: 06/10/2024
AD0746
This procedure shows how to replace a BMT/BOT/VDI style indexer turrets
Important : These are replacement service kits and should not be used for upgrading.
This Document Applies to the following Service Kits:
  • 93-4365 TURRET DISC KIT BMT45 INDEXER BMT 24
  • 93-4364 TURRET DISC KIT BMT45 INDEXER BMT 12
  • 93-4363 TURRET DISC KIT BMT45 INDEXER BOT 12 MET
  • 93-4362 TURRET DISC KIT BMT45 INDEXER BOT12 INCH
  • 93-4361 TURRET DISC KIT BMT45 INDEXER VDI 12
Required tools for live tooling turrets:
  • T-0159 BMT45 LT POCKET ALIGNMENT TOOL
  • T-0147 BMT45 LT OUTPUT SHAFT ALIGNMENT TOOL
  • Dial indicator
  • Service USB Key
Lifting Requirements:
  • The turret weighs approximately 100 lbs and requires a crane to lift safely
Note: When replacing a Live Tool Drive, install new shims. Shim part numbers are:
  • 59-1975 - .004"
  • 59-1976 - .005"
  • 59-1977 - .003"
  • 59-2189 - .007"
  • 59-2191 - .010".
All service kits will come with:
  • All the hardware needed to swap the turrets
  • Moly grease
  • Housing o-ring
  • Fully assembled turret with plugs
Note: VDI turrets will need to reuse the locks from the old turret
Replacement
Jog turret [1] towards the spindle for better access and ease of removal.
Note: Sheet metal covers will need to be removed to access the live drive motor for live drive removal so make sure to have adequate access to both the front and rear of the turret
Remove the sheet metal surrounding the turret to access the motor for removal.
Note : Access panel behind wedge / turret assembly may need to be removed to gain access to the back side of the sheet metal and slide it out of the way
Remove turret cover [2] along with live tooling bracket [4] (if applicable).
Important : Disconnect the power and encoder cables from the live drive motor carefully by twisting the metal collar then gently pulling on the connector.
Remove live drive motor [2] and motor bracket [4].
Remove clamp screw [1] and torque arm [2] along with the snap ring and springs [3].
Note : if torque arm is difficult to install, use a 3/8-16 bolt in the jack screw hole above the clamp bolt. Apply just enough torque to spread the torque arm so it can slide on the torque tube.
Note : Older versions of the BMT45 have one alignment pin while newer machines have two alignment pins. Refer to BMT45 Turret - Live Tool Drive - Alignment for more details.
Remove the (5) bolts from the retaining ring  [1] and slide the live tooling drive out of the turrret.
Note : It is highly likely that the new turret will require a different number of shims [2] but the original shim value is reccomeded to be used as a starting point.
Important: Before removing all of the (6) bolts make sure to have a crane support the turret using straps. Live tooling holes can be used for this purpose or eye bolts threaded into the tool holder holes.
Remove the (4) set screws [1] then remove the (6) bolts [2] holding the turret [3] to the housing.
Note: There is a locating dowel in the turret that is aligned with pocket 1 so make sure to pull away from the housing before pulling up.
Clean the old grease from all the mating surfaces [1] then apply moly grease to the areas highlighted in grey after replacing the O-ring [2].
Note : Apply an even coat and do not over grease the surfaces.
Lift the new turret using a crane and mount it onto the housing making sure to align the dowel [1] with the housing [2].
Torque the (6) bolts [2] then tighten the (4) set screws [3] to 5 ft-lb. Refer to Haas Fastener Torque Specifications.
Install and align the live tooling assembly [2]. Refer to BMT45 Turret - Live Tool Drive - Alignment
Note: You will need to reset turret tool changer alignment if the loads are too high. Refer to BMT45 - Turret Indexer Assembly - Troubleshooting Guide for more details.
Re-install live tooling bracket [1] and then the front cover [2].
