Desktop Mill & Lathe - PCB Board - Replacement - AD0562
Service Home How To Procedures Desktop Mill & Lathe - PCB Board - Replacement - AD0562
Recently Updated Last updated: 08/12/2024
AD0562
- Jump to Section - 1. Introduction 2. 93-32-3097A Replacement (4 steps) 3. 93-32-3197 DB25 Breakout Replacement (4 steps) 4. 93-3436 Tabletop Lathe Adapter Replacement (4 steps) Back to Top
This procedure shows you how to replace the PCB boards on the Desktop Pendant, Desktop Mill, and Desktop Lathe control boxes.
This procedure applies to the following service kits:
  • 93-32-3097A SVC KIT TABLETOP-SIMULATOR CCA - DESKTOP PENDANT
  • 93-32-3197  SV KIT DB25 FEMALE BREAKOUT CCA - DESKTOP MILL
  • 93-3436 TABLETOP LATHE SVC KIT - DESKTOP LATHE
Note: 93-32-3097A Tabletop Adapter is now applicable to all desktop mills and desktop lathes.
NOTE: Wear anti-static gloves when handling the PCB boards.
Push [POWER OFF].
Unplug the Desktop Mill or Desktop Lathe.
 NOTE: Be sure to unplug BOTH the control pendant and the Desktop Mill power cords as current runs between the pendant and the mill.
Remove (8) Philips head screws [1] from the control pendant rear panel and remove panel.
You will be removing the PCB board shown [2].
Put an identification label on each cable that is attached to the PCB [1]. This makes the installation easier. Disconnect these cables.
Remove the PCB board by unscrewing the (4) screws from the standoffs [2].
Install the replacement PCB board and reinstall the (4) screws into the standoffs.
Connect all cables to replacement PCB.
 Caution: Carefully compare the PCB to make sure you install each cable in the correct position. If you do not correctly install each of the cables, the PCB cannot operate correctly.
Reinstall the rear panel with (8) Philips head screws.
Plug in the machine and control pendant.
Push [POWER ON] and test machine operation.
Push [POWER OFF].
Unplug the Desktop Mill.
 NOTE: Be sure to unplug BOTH the control pendant and the Desktop Mill power cords as current runs between the two.
Remove (9) BCHS 6-32"  [1] from rear panel and remove panel.
You will be removing the PCB board from the left side as shown [2].
Put an identification label on each cable that is attached to the PCB. This makes the installation easier. Disconnect these cables.
Remove the PCB board by removing the (2) standoff bolts from the DB25 cable labeled CONTROL CBL 1 [10].
Install the replacement PCB board and hand tighten the standoff bolts.
[1] AMP SIG X
[2] AMP SIG Y
[3] AMP SIG Z
[4] 12V RELAY
[5] DOOR SW
[6] INVTR SIG
[7] X HOME SW
[8] Y HOME SW
[9] Z HOME SW
Push [POWER OFF].
Unplug the Desktop Lathe.
[1] RLY/PS Monitor
[2] AMP SIG X
[3] AMP SIG TT
[4] AMP SIG Z
[5] VFD SIG
[6] X HOME SW
[7] DOOR SW
[8] TT HOME SW
[9] Z HOME SW
[10] SP ENC
