Gearbox - Oil Pump - Replacement - AD0297
Service Home How To Procedures Gearbox - Oil Pump - Replacement - AD0297
Recently Updated Last updated: 12/04/2018
AD0297
- Jump to Section - 1. Introduction 2. Document Applies to these Parts 3. Gearbox - Oil Pump - Replacement (5 steps) Back to Top
This procedure tells you how to replace the oil pump in a gearbox. Although this procedure provides instructions for multiple kits, you only need (1) kit to complete the task.
KIT PN: 93-30-11626, OIL PUMP, CALM MACHINE GEARBOX. QTY: 1
KIT PN: 93-30-11656, OIL PUMP, PRE-CALM MACHINE GEARBOX. QTY: 1
[A] 30-11626 QTY: 1 GEARBOX OIL PUMP ASSY, WITH INLET SCREEN
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the two oil port covers [1]. Use an oiler to add (2) drops of oil to each of the ports.
Put the oil port covers [1] back on the oil pump.
Use a pen or thin rod [2] to turn the fan [3] 2 full revolutions.
 Note: For machines that have a pressure switch connected to the oil pump with spade connectors, use the adapter cable (P/N: 93-1353). The cable is included in the kit 93-30-11626.
Remove the spindle head covers.
Remove the oil supply [1] and oil return [2] hoses. Put a plug in each hose.
 Note: If the hose has a threaded connection, use an open-end wrench to support the fitting on the pump. Use a second wrench to remove the hose.
Disconnect the oil pressure cable [3] and the power cable [4] from the spindle connector panel.
Remove the pump assembly from the motor housing.
Attach the GEARBOX OIL PUMP ASSY, WITH INLET SCREEN [A] to the motor housing.
Attach the oil supply hose [1] and the oil return hose [2].
 Note: If the hoses have threaded connections, do these steps to connect each fitting:
  • Tighten the fitting with your hand.
  • Put a wrench on the fitting on the pump.
  • Put a second wrench on the fitting on the hose. Turn it clockwise 1/8 to 1/4 turn.
Connect the cable [3] for the pressure sensor to the spindle connector-panel that has the label "OIL PRESSURE."
 Note: The illustration shows a CALM machine. For pre-CALM machines, the cable [3] for the pressure sensor has a different type of connector.
Connect the power cable [4] to the location on the spindle connector panel that has the label "OIL PUMP."
Install the spindle head covers.
