H-5AX Double Yoke Spindle Head - Replacement - AD0743
Service Home How To Procedures H-5AX Double Yoke Spindle Head - Replacement - AD0743
- Jump to Section - 1. Introduction 2. Removal of Spindle Head (9 steps) 3. Installation of Spindle Head (8 steps) 4. Verify Axis Motion (1 step) 5. Complete an Inspection Report (1 step) 6. B-Axis Tool Change Offset (3 steps) 7. C-Axis Tool Change Offset (3 steps) 8. Complete an Inspection Report 9. B and C-Axis Compensation 10. Tool Changer Alignment 11. Calibrate Probe 12. MRZP Calibration 13. Safe Zone Calibration 14. Test Cut Back to Top
Recently Updated Last updated: 04/23/2026
AD0743
Revision A - 08/2025
This procedure shows how to complete a H-5AX Double Yoke spindle head replacement.
This document applies to the following Service Kits:
  • 93-4569 SPINDLE HEAD SVC ASSY HAAS 5AX VR/GM
Tools Required:
  • T-0142 SPINDLE ENCODER JUMPER
  • Service Key
  • HSK-A63 split tool
  • 49-1008 EYE BOLT 1/2-13 X 0.88 X 1.19 I.D. SHLDR (QTY: 2)
  • 43-0109 HHB 5/16 X 1.25 (QTY: 12)
  • Shims for C-Axis. Minimum of 5 shims of each of the following part numbers is need:
    • 59-0683 - .0005"
    • 59-0684 - .001"
    • 59-0685 - .0015"
    • 59-0686 - .002"
    • 59-0688 - .003"
 Note: The wood bracket shipped with the replacement head will be used to ship the original head back to Haas.
WARNING: It is important to verify and to go through the proper troubleshooting found in the H-5AX Double Yoke Spindle Head - Troubleshooting Guide and to fill out the H-5AX Service Request Form linked below before ordering a replacement head.
 Warning: Do not home B or C-Axis with a tool in the spindle.
Jog the Z-Axis to the top of travel.
Remove sheet metal [1] to access the cable connections inside the spindle head.
Return the B and C axis to its home position.
Place a piece of cardboard [1] or protective mat on the VR table to avoid damaging the table during the removal/installation process.
Place wooden blocks [2], tall enough to hold the spindle head without the spindle touching the table. Lower the spindle head onto the blocks. You will lower the spindle head until the spindle head is fully supported, this is indicated when the Z-axis load reaches 0-1%.
  Warning: The wooden blocks used need to be the same size. Mismatched blocks can cause damage to the spindle head.
Press [EMERGENCY STOP].
 Note: Make note of the all parameter/setting values before changing. They will need to be reset after the new head is in place.
Use a service key to disable the B and C-axis scales in the factory setting.  Parameters 6.083 and 7.083.
Power off the machine.
With the spindle fully supported remove the mounting bolts [1] that attach the spindle to the spindle head casting.
While the machine is powered off.
Disconnect the encoder cable [1] and install T-0142 Spindle Jumper [2] on the NGC Main PCB (P6).
Turn the machine back on and change the factory setting 4.004 Spindle Disabled from False to True.
 Note: If Alarm 4.9975 SPINDLE OVERHEAT appears after a power cycle, check  setting 4.004. Change the setting  from False to True again if needed.
Use a service key to set parameter 76 Low Air Pressure Alarm Delay to 999999.
Use a service key to uncheck the 4th and 5th axis on the Rotary tab in Settings.
Power off the machine and turn off main circuit breaker.
Remove the corrugated tubing [1] on the cables and the cable bracket [2].
Make note of the hose and cable connections. Disconnect the all hoses and cables [3] located inside the spindle head enclosure.
Note: Some of the cable and hose connection will be different on older machines.
Power on the machine.
Separate the spindle from the spindle head casting by raising the Z-Axis, make sure the casting clears both servo motors on the replacement spindle and current spindle.
Install the EYE BOLT 1/2-13 X 0.88 X 1.19 I.D. SHLDR [1] onto the spindle head.
With all the wires and hoses unplugged, use an appropriate lifting strap and forklift to move the old spindle head out of the machine.
Note: Approximate weight of H-5AX Head Assembly:
DOUBLE YOKE H-5AX HEAD HSK A63 20K = 405 lbs. (184 kg)
 Note: Check for any remaining shims on the Z and C-Axis mating surfaces.  Make note of shim amount and placement.
Clean and stone the spindle head mating surfaces.
Place the new spindle head into the same position as the spindle head that was removed.
Make sure the boss on the spindle casting is facing the right side of the machine, and that the servo motor is oriented towards the front of the spindle head casting or else the homing sequence may pose a problem later down the line if it is not.
Correct any alarms present and jog the spindle head casting down toward the new spindle.
 Note: Setting 53 jog without zero return will need to be turned on to do so. DO NOT ZERO RETURN THE SPINDLE HEAD.
Carefully jog the Z-Axis down making sure the spindle is straight to avoid wedging the spindle [1] into the spindle head bore.
Bolt the plate to the casting.
 Note: Replace mounting bolts if damaged.
Jog the Z-Axis to the top of travel removing the Double Yoke Head from of the bracket.
Remove the bracket from the table.
Power off the machine and turn off the main breaker.
Connect all the hoses and cables [1]. Neatly organize the hose and wires.
Install the corrugated tubing on the cables [2] and the cable bracket [3].
Connect the hoses from the spindle head to the hoses from the CALM Cabinet using the table below.
The Polyethylene (PE) hoses from the spindle head [1, 2, 8, 9] will have push-to-connect fittings.
The Polyurethane (PU) hoses from the spindle head [3, 4, 5, 6, 7] will have compression fittings.
 Note: The TRP hose [7] connects to the 3/8 black hose with the 3/8F NPT 1/4M compression fitting [10].
Haas Double Yoke (Before 5/9/2025)
  Head Hose Color     Head Hose Material Zip tie      CALM Hose Color      CALM Hose Material       Zip tie
Clamp B-Axis     Opaque [2] PE None Opaque PE None
Release B-Axis Blue [8] PE None Blue PE None
Clamp C-Axis Black [9] PE None Black PE None
Release C-Axis Orange [1] PE None Orange PE None
TRP Black [7] PU Black BLack PU Black
Taper Pressure Clear [6] PU None Clear PU None
Electrospindle coolant Black [3] PU Green Opaque PE Green
Electrospindle coolant Black [5] PU Green Opaque PE Green
Flood coolant Blue [4] PU Blue Blue PU inner braid Blue
Haas Double Yoke with Chiller (90° Swivel After 5/9/2025)
Flood coolant Black [4] PU Blue Blue PU inner braid Blue
Verify the B and C-Axis brake solenoid air lines match the CALM Cabinet schematic.
Remove the T-0142 Spindle Jumper [2] from the NGC Main PCB and plug the Spindle encoder cable [1] back in.
Power on the machine and reset Factory setting 4.004 Spindle Disabled from True to False.
Reset parameter 76 Low Air Pressure Alarm Delay from 999999 to 30.
Set 4.263 from True to False.
Power Cycle the machine.
Install any sheet metal [1] that was removed.
Reset all the parameters and settings that were changed to remove the spindle head to their original values.
 Note: Parameter 4.263 Spindle Axis Channel Disabled may also need to be caged back to False. If Parameter 4.263 is changed, the machine will need to be power cycled.
Follow the steps on the H-5AX Double Yoke Spindle Head - Troubleshooting Guide to clear any remaining alarms if needed.
Verify the following parameters/settings:
 Note: If the values on the machine do not match the values listed below, change the parameter/setting.
6.272 B-Axis Secondary Encoder Type = 0
7.272 C-Axis Secondary Encoder Type = 4
6.083 B-Axis Linear Scale Enabled = Enabled_Linear
7.083 C-Axis Linear Scale Enabled = Enabled_Linear
4.004 Spindle DIsabled = False
4.116 Spindle Encoder Type = 0
6.129 B-Axis Secondary Encoder Channel= 12
7.129 C-Axis Secondary Encoder Channel = 13
76 Low  Air Pressure Alarm Delay = 30.0
4.263 Spindle Axis Channel Disabled = False
 Note: If 4.263 is changed the machine needs to power cycle.
Verify Axis Motion
Verify all axis motion and loads.
 Warning:  Do not power up restart the machine or command a tool change as the tool changer arm is not aligned to the spindle and the Z-axis tool change position has not been set for the double yoke assembly.
Complete the latest inspection report found in the Alignment Inspection Report and Checklists folder on HBC.
 Note: This site is available only to Haas Service Techs.
Please refer to the H-5AX Double Yoke Spindle Head - Geometry Guide for further details on how to perform the 5AX inspection report checks.
Note: Complete the machine geometry sections and the C-Axis Parallel to Z-Axis check of the inspection report before setting the B and C-Axis Tool Changer Offsets. After the Tool Changer Offsets are set, finish the remaining checks on the inspection report.
Home the B & C-Axis.
Load the test arbor into the spindle. Place the indicator on the side face of the test arbor.
Find the high spot on the test bar by jogging the Y-Axis. Once the indicator is on the high spot jog the indicator up and down the test bar and adjust the B-Axis so that the error on the indicator is no more than 0.0001".
Use the following instructions to change the B-Axis Tool Change Offset if a service key is not available.
Press [SETTING] and navigate to the rotary tab. Highlight the 4th axis selection [1] and press [ALTER] [2] to set the B-Axis Tool Change Offset [3].
After adjusting the B-Axis Tool Change Offset. Redo the inclination test, sweeping from position [1] to [2]. If the inclination is out of tolerance after adjusting the offset, redo the adjustment portion.
If a service key is available press [DIAGNOSTIC] and navigate to the parameters tab and to the factory tab. Find Parameter 6.078 B-AXIS TOOL CHANGE OFFSET to set the Tool Change Offset by pressing the [B] + [F2] to set the offset to the current position.
After adjusting the Tool Change Offset. Redo the inclination test, sweeping from position [1] to [2]. If the inclination is out of tolerance after adjusting the offset, redo the adjustment portion.
Home the B and C-Axis.
In MDI command the B-Axis to -90°.
Load the test arbor into the spindle. Place an indicator on the front face of the test bar at the end of the bar [1] on the high spot. Zero the indicator at this location.
Jog the Z-Axis up so the test bar clears the table and command B = +90°. Jog the table in the Z and X direction to move the indicator to position [2] on the front face of the test bar at the end of the bar on the high spot. Adjust the C-Axis so that the error on the indicator is the same between positions [1] and [2]. This should not exceed 0.0005".
Once the end of the test bar reads the same error at both B = -90 and B = +90 degrees set the C-Axis Tool Change Offset. See steps below.
 Note: Do not move the Y-Axis during this step.
 Important: If the C-Axis Tool Change Offset is changed, the spindle orientation must be verified before doing a tool change.
Use the following instructions to change the C-Axis Tool Change Offset if a service key is not available.
Press [SETTING] and navigate to the rotary tab. Highlight the 5th axis selection [1] and press [ALTER] to set the C-Axis Tool Change Offset [3].
If a service key is available press [DIAGNOSTIC] and navigate to the parameters tab and to the factory tab. Find Parameter 7.078 C-AXIS TOOL CHANGE OFFSET to set the tool change offset by pressing [C] + [F2] to set the offset to the current position.
Complete the rest of the inspection report.
  Note: MRZP will be completed after the probe is calibrated and the compensations are calculated later in the procedure.
Calculate the compensation values of B=+90, B=-90, C=+90, C=+180, and C=-90 by following the step in the H-5AX - VR DOUBLE YOKE - HDC - B/C-AXIS COMPENSATION procedure.
Take a back up after populating the compensation values and attach it to the machine history.
Set the Z Tool Change Offset by following the steps in the Side-Mount Tool Changer - Z-Axis Tool Change Offset – NGC procedure.
Set the Spindle orientation by following the steps in the Side-Mount Tool Changer - HSK - Spindle Orientation Offset – NGC procedure.
Calibrate Probe
Calibrate the probe by following the steps in the WIPS - Probe Calibration - NGC procedure.
MRZP Calibration
Set MRZP by following the steps in the MRZP Calibration procedure.
Set Safe Zones by following the steps in the Safe Zone Calibration procedure.
Test Cut
Complete the H-5AX test cut procedure.
Adjust the MRZP values as needed.
