Haas Cobot - End I/O Module - Replacement - AD0725
Service Home How To Procedures Haas Cobot - End I/O Module - Replacement - AD0725
Recently Updated Last updated: 11/06/2023
AD0725
- Jump to Section - 1. Introduction 2. Replacement (6 steps) Back to Top
This procedure will show how to replace the End I/O Module on the Haas Cobot package.
This Procedure Applies to the Following Part Numbers:
  • XXXXX for HC5
  • XXXXX for HC10 & HC15
Replacement
Remove the gripper installed onto the Cobot. For more information, refer to the Haas Cobot - Gripper - Installation - AD0711.
Turn ON the Cobot. Make sure the teach pendant [E-STOP] is released at all times.
Make sure that the Haas Cobot End I/O Module is not functioning by:
With the Cobot in Jog mode, the LED ring [1] around the End I/O Module should illuminate when functioning properly. Verify that the LED ring [2] does not illuminate.
With the Cobot in Jog mode, measure the voltage across the I/O port M12 connector [2] pins 11 and 12. Verify that there is no voltage.
IMPORTANT: Damage to the unit can occur if you cross the meter leads when checking the voltage. Make sure to use the correct meter leads to check the pins.
Jog the robot to a convenient position.
Turn OFF the Cobot.
Remove the (x4) screws securing the End I/O Module cover [1]. Disconnect the electrical connections.
NOTE: Make sure to make note on which side the M12 connector [2] is on and match this same orientation during install.
Remove the (x16) screws securing the End I/O Module end adapter [3].
Install the (x16) screws securing the End I/O Module end adapter [1].
Connect both electrical connections.
Install the (x4) screws securing the End I/O Module cover [3].
 NOTE: Make sure to install the End I/O Module cover [3] in the same orientation as the last with the M12 connector [2] on the same side.
Make sure that the Haas Cobot End I/O Module is functioning by:
With the Cobot in Jog mode, verify that the LED ring [1] around the End I/O Module is illuminated.
With the Cobot in Jog mode, measure the voltage across the I/O port M12 connector [2] pins 11 and 12. Verify that there is ~ 24V output.
Install the gripper back onto the Cobot. For more information, refer to the Haas Cobot - Gripper - Installation - AD0711.
