Lathe - Motor Coupling - Alignment - NGC
Service Home How To Procedures Lathe - Motor Coupling - Alignment - NGC
Recently Updated Last updated: 03/28/2022
- Jump to Section - 1. Lathe - Turret Motor Coupling - Alignment (6 steps) Back to Top
Rotate the turret to Pocket 1
Remove the covers to access  the turret motor coupling.
  • Remove the rear cover [1].
  • Remove the (3) screws [2], as shown.
  • Remove the covers in the sequence shown
  • Remove the covers [1, 2, 3] at the rear of the machine.
  • Remove the covers and wipers [4, 5, 6] near the right side of the turret.
 Note: A wiper [4] is on the top, and a wiper is on each side [4].
Make sure a minimum 1" (25 mm) space is between the turret and all objects in the direction of the Z Axis.
Set parameter 9.019 TT-AXIS INVISIBLE to FALSE. Then press [POSITION] and [ALTER] and select the TT -Axis to display the turret position and load.
With the turret clamped at Pocket 1. Loosen the motor side of coupling[1]. Handjog the motor until TT-Axis reads 0 degrees. Tighten the motor side of the coupling.
Move the coupler to the left and to the right with the same tool used to tighten the collar nut.
Take note of the total degrees that the motor rotates in backlash. Divide the total number by two.
Example:
|-.023| + |.277|  = .300
.300/2 = .150
Loosen the worm gear side of coupler and rotate the coupler until the TT axis matches the value calculated above.
If the backlash is biased in the positive direction, move the TT to the negative side. If the backlash is biased in the negative direction, move the TT to the positive side.
Example: If TT axis reads +.300, rotate coupler until the axis reads -.150. If TT axis reads -.300, rotate coupler until the axis reads +.150.
Tighten the coupler.
Make sure the movement in either direction is the same.
Example: Position of TT moves from  -.100 to .100
Torque both coupling bolts to 15 ft-lbs.
Release the E-Stop
Ensure Turret is in Pocket 1
[MDI] -> "TT" -> [ZERO RETURN] -> [SINGLE]
Verify the backlash in the coupler by rotating the turret to several pockets
At each pocket place press [EMERGENCY STOP].
Verify the coupler moves an equal amount in each direction for each pocket checked.
Press [POSITION] and [ALTER] and unselect the TT -Axis. Then set parameter 9.019 TT-AXIS INVISIBLE to True.
