Lathe - Thermal Growth Test - Probing - AD0850
Service Home How To Procedures Lathe - Thermal Growth Test - Probing - AD0850
- Jump to Section - 1. Lathe - Thermal Growth - Checklist 2. Lathe - Thermal Growth Test - Probing - Setup 3. Lathe - Thermal Growth Test - Probing - Work Offsets 4. Lathe - Thermal Growth - Test Procedure - Run Test Program Back to Top
Recently Updated Last updated: 06/01/2026
Lathe Thermal Growth Test - Probing
AD0850
Revision C - 06/2026
This test procedure will cover how to run the probing thermal growth test to help diagnose inaccuracy on Haas Lathes. To start, download the checklist below and fill it out. Review the results with your HFO and contact Haas Applications if necessary.
Thermal Growth Checklist
This video demonstrates how to set up and run the lathe thermal growth probing test on your Haas Lathe.
Note: This service video is for reference only and does not replace the written procedure.
Test Program Description:
This test is a standardized cutting program in which the machine will air cut and probe a tool using the ATP to see changes in probing from thermal growth.
Machine Requirements:
  • ST NGC Lathe
  • Automatic Tool Presetter
  • OD cutting tool
Inch Test Program:
O05521.NC
Metric Test Program:
O05522.NC
Tools:
  • Tool #1: OD cutting tool
  • No tools in the rest of the machine
Calibrate Tool:
  • Measure the tool offset for the OD turning tool in tool 1 using the ATP.
    •  Refer to Automatic Tool Presetter (ATP) - Alignment - Test - Calibration to calibrate your ATP if not done so already.
    • Use the manual VPS template to run the tool measuring program in MDI
G54:
  • Set G54 Z roughly 11 inches (30cm) from the face of the chuck.
  • Set G54 X and Y to zero.
G53:
On lines 32-34, 77-79, and 173-175 of the program, the G53 values will need to be adjusted based on your machine.
  • G53 X needs to be close to the X+ side of the ATP when extended.
  • G53 Z needs to be on the Z+ side of the ATP when the ATP is extended.
  • G53 Y and B need to be at zero if present.
For example:
G53 G00 Z-1.25 changed to G53 G00 Z-8.
G53 G00 Y0. stayed as G53 G00 Y0.
G53 G00 X-9. changed to G53 G00 X-10.
Note: Make sure you are using the correct units and sign convention when modifying these lines, or else you will get axis over travel alarms.
Test Program:
The machine will simulate cutting a part away from the spindle. This will be done with the tool in the machine. Once that is done, the machine will check the thermal growth by touching off on the ATP and will collect the data into a separate file. The test will then reset to the beginning and repeat until the feed hold and reset button is pushed.
 Note: Make sure the machine is cold and has not warmed up at all, besides by setting the work and tool offsets.
Run the test program:
Note: Run the program from Memory and not the USB.
Run this program for a minimum of three hours. Record the ambient temperature near the machine every hour while the test is running.
A DPRINT file will be saved to the User Data folder. Take an error report at this time. Attach the Error Report, DPRINT File, and ambient temperature recordings to a work order for the machine and contact Haas Service.
 Note: If the tool length offset changes by more than .002” between probe hits, you will get a #3000 alarm. To fix this simply restart the program.
