Main Transformer Replacement - AD0408
Service Home How To Procedures Main Transformer Replacement - AD0408
17.2 Main Transformer - Replacement
Recently Updated Last updated: 02/08/2021
AD0408
Replacement
This section applies to all size main transformer replacements and machine models.
Turn off the main breaker and lock out the machine from use. Verify there is no power going to the transformer with a volt meter.
Loosen the (4) screws and remove the cover plate [1].
NOTE: Before removing the transformer wires take couple pictures of where cables are connected.
Label and disconnect the wires from the appropriate taps [2], TB2 the 240 VAC terminal block [3], and TB1 the 120 VAC terminal block [4].
Insert a piece of wood [1] (1"X4" approx.) to support the transformer. Remove the (4) corner bolts only and remove the transformer.
Install the replacement transformer in the reverse order it was removed.
Important: If the transformer comes with its own hardware, you must use it. Do not reuse hardware
Install the hardware shown in the image.
  1. Hex Head Bolt
  2. Lock Washer
  3. Black Oxide Hard Washer
Apply blue loc-tite and torque the (4) bolts to 15 ft-1b (20 Nm).
NOTE:  Do not over torque the bolts as it will cause the back plate to warp.
Thermal Sensor
The following section applies to only the transformers that are equipped with a thermal sensor (see table below).
Transformers with a Thermal Sensor
32-5800H 32-5810K 32-5811C
32-5814B 32-5822D 32-5825F
32-5826 32-5829 32-5830A
32-5831A 32-5832A 32-5833B
32-5834B 32-5835B 32-5836
32-5837 32-5830E
For Coldfire Control:
  • Plug the thermal sensor to I/O PCB at P82.
  • Change parameter 1397 TRANSFORMER OVER HEAT MAX TIME to 60000.  A value of zero will disable this feature.
     Note: If the machine software does not have parameter 1397 TRANSFORMER OVER HEAT MAX TIME available, tuck the overheat cable inside the wire track.
For Next Generation Control:
  • Plug the thermal sensor I/O at P34.
  • Upload a new configuration file. The configuration file is updated when the part is ordered.
