Toolroom Lathe Installation - NGC
Service Home How To Procedures Toolroom Lathe Installation - NGC
Recently Updated Last updated: 02/10/2026
- Jump to Section - 1. Introduction 2. Leveling Screws Hardware 3. Remove Rust Inhibitor 4. Air Connection 5. Electrical Installation 6. Shipping Brackets Removal 7. Machine Leveling (3 steps) 8. Spindle Sweep Check 9. Machine Operation (8 steps) 10. Lathe Maintenance Schedule Back to Top
This procedure shows you how to install a Toolroom Lathe.
Tools required:
  • Precision Machinist Level, 0.0005" Division
  • T-2181A CNC Dual Leveling Tool
  • T-2113 Spindle Alignment Bar - A2-5 for TL-1/TL-2/TL-1-EDU
  • T-1312 Spindle Alignment Bar - A2-6 for TL-1/TL-2/TL-1-EDU
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
To safely and effectively remove rust inhibitor from way covers and other non-painted surfaces:
Initial Scraping
  • Use a plastic scraper to remove the bulk of the rust inhibitor.
  • Avoid using metal tools to prevent scratching or damaging the surface.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers.
Chemical Cleaning
  • Spray the affected areas with a heavy-duty citrus cleaner or Simple Green.
  • Ensure full coverage of all non-painted surfaces coated with rust inhibitor.
Soak Time
  • Allow the cleaner to soak for several minutes to loosen remaining residue.
Wipe Down
  • Use a clean shop towel to thoroughly wipe off the softened rust inhibitor.
Rust Proofing
  • Apply mineral spirits or WD-40 to all exposed metal surfaces to prevent future rust formation.
Important: Always wear gloves and eye protection when handling chemical cleaners. Dispose of used towels and cleaning agents according to local environmental regulations.
 Important: To avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Rust Inhibitor - Safety Data Sheet (SDS)
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
Remove the door to pendant shipping bracket [1].
Remove the pendant shipping bracket [2].
Remove the two door bolts [3].
Remove the cross slide to spindle housing shipping bracket [4].
Machine Leveling
Zero return each axis one at a time or press [POWER UP]. Go through the leveling process.
Repeat these steps to achieve correct machine level.
Set the machine height using the four leveling to 3.0" above the floor. Turn each screw so they have equal tension.
Move tailstock to home position
Place tool T-2181A onto the cross slide so that the large level is parallel to the X-axis.
Jog the turret to center of X-axis then jog the turret to center of Z-axis.
Look at the smaller level that is parallel to the Z-axis and raise or lower screw 4 to center the bubble.
Now look at the larger level that is parallel to the X-axis and raise or lower screw 1 to center the bubble.
To check for twist in the machine move the turret along the Z-axis back to home position.
Using the larger level raise or lower screw 2 to center the bubble and wait 10 seconds for the bubble to settle.
Move the turret back towards the spindle as far as possible and raise or lower screw 1 to center the bubble. Continue moving the turret from the home position to the spindle and adjusting screw 1 and 2 until the twist is removed.
Tighten the locking nuts making sure that you do not raise or lower the screws.
Verify that the machine is level by moving the turret along the Z-axis and checking for twist and continue adjusting until level.
Spindle Sweep Check
Alignment Bar Runout
  • The maximum radial error that is permitted is 0.0001 (0.0025 mm)" at each end.
Top of Bar Error:
  • The maximum permitted error is 0.0005"/10" (0.012 mm / 254 mm).
Side of Bar Error:
Note: If the spindle sweep is out make sure the level of the machine is correct.
Machine Operation
Test Coolant Operation
  • Connect the coolant pump.
  • Run coolant by pressing  [COOLANT] on control pendant.
Remote Jog Handle Color Installation
  • If your machine includes the Remote Jog Handle Color option perform the installation procedure
For a guide on how to perform the Remote Jog Handle Color installation procedure please see:
RJH-C Installation
Remote Jog Handle Touch Installation
  • If your machine includes the Remote Jog Handle Touch option perform the installation procedure
For a guide on how to perform the Remote Jog Handle Touch installation procedure please see:
RJH-T Installation
  • Go to MDI. Type in S500 M3; Press [ENTER]. Make sure the machine is not in Setup Mode. Check the Key Switch on the side of the pendant.
  • With the door open, press [CYCLE START]. The machine should say to close the door and press [CYCLE START].
  • With the door closed, press [CYCLE START]. The Interlock Pin should extend and the spindle starts rotating.
  • While the locks are on try to open the doors.
  • The spindle should not stop rotating but if the spindle stops, re-adjustment is required.
Test Safety Features
  • Test Memory Lock switch by verifying that in the locked position changes cannot be made to settings or programs[1].
  • Test Run/Setup Mode switch by verifying that in the unlocked position machine functions can be done in Setup Mode[2].
  • Verify that Interlock and Actuator are installed & cable is routed correctly.
  • Verify that a window (or T/S access door) latch is installed on each side window.
  • Verify that the latch engages to keep the window or door in the up position.
  • Verify that a window or door lock is installed on each side window.
  • Verify that the window or door locks closed in the down position.
  • Verify that all lathe door locks function like the windows and doors stated above.
Electronic Handwheel Installation
  • If your machine includes the E-Handwheel option perform the installation procedure.
For a guide on how to perform the E-Handwheel installation procedure please see:
E-Handwheel Installation
Steadyrest Installation
  • If your machine includes the Steadyrest option perform the installation procedure.
For a guide on how to perform the Steadyrest installation procedure please see:
Wi-Fi Camera Installation
  • If your machine includes the Wi-Fi Camera option perform the installation procedure
For a guide on how to perform the Wi-Fi Camera installation procedure please see:
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. Please see the link below for recommended maintenance intervals.
