      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
UMC Pneumatic Workholding - Installation AD0542
Service Home How To Procedures UMC Pneumatic Workholding - Installation AD0542
Recently Updated Last updated: 02/11/2022
UMC - Pneumatic Workholding Ready - Installation
AD0542
This procedure will explain how to install the pneumatic workholding assembly on UMC reboot machines.
Prerequisites:
Machine Software Version 100.20.000.1110 or higher.
This procedure applies to reboot machines only.
To install this option the platter will need mounting holes for a coupler, this was implemented after 04/2020.
The following kits are for UMC's after 04/2020 that do not need a platter:
  • 93-1000616: AIR VISE READY FIELD INSTALL UMC500
  • 93-1000617: AIR VISE READY FIELD INSTALL UMC750
  • 93-1000618: AIR VISE READY FIELD INSTALL UMC1000
  • 93-1000619: AIR VISE READY FIELD INSTALL UMC1500
  • 93-1000620: AIR VISE READY FIELD INSTALL UMC1250
For UMC's before 04/2020 the platter will be included in the following kits:
  • 93-1000621: AIR VISE READY FIELD INSTALL UMC500 W/P
  • 93-1000622: AIR VISE READY FIELD INSTALL UMC750 W/P
  • 93-1000623: AIR VISE READY FIELD INSTALL UMC1000 W/P
Assemble the pneumatic manifold as shown:
[1] FITG POLY1/4F NPT1/4M STR BRASS
[2] FITG PC1/4F NPT1/4M STR BRASS(2x)
[3] FITG ORB6M NPT1/4F STR STL (2x)
[4] O-Ring 2-212 (4x)
Connect the 3 Port Rotary Union Shaft to the 3 Port Rotary Union Shaft Extension using [2] SHCS 1/4-20 X 5/8 make sure the O-Ring 2-011 [1] are seated in the cavities of the shaft.
Torque the bolts to their required specs.
Press the dowel pin [1] into the anti-rotation block [2] until it bottoms out.
Assemble the platter coupler by installing the SHCS 5/16-18 X 1/2 [1] and O-Ring 2-011 [2] these will serve as plugs to the pneumatic lines until the vise is installed.
Finish assembling the coupler by installing O-Ring 2-031 [3] into the groove of the coupler [4].
Rotate the B-axis +90 degrees and remove the cover [1]. Return the B-axis to its original position at 0 degrees.
Remove the platter by following the removal section of the UMC C-Axis Platter Replacement linked below.
 WARNING: IF YOU DO NOT DEPRESSURIZE THE SYSTEM BEFORE REMOVING THE PLATTER YOU CAN PERMANENTLY DAMAGE THE BRAKE BY REMOVING THE PLATTER.
UMC Rotary Unit – Weight Reference Guide
Place the platter on a bench and bolt the coupler [1] to the platter using SHCS 1/4-20 X 5/8 [2].
While the platter is on the bench insert the felt strip included in the kit in the groove [3]
NOTE: If the UMC is not exchanging platters reuse the felt strip already in the groove.
Install the coupler onto the shaft assembly [1] by using 1/4-20 X 1 1/4 bolts [3]. Make sure the O-Rings 2-011 [2] are in the cavaties of the shaft and not where the bolts attach.
Install the coupler and platter assembly [2] back onto the rotary using M12 bolts [1].
Tighten the bolts, but do not torque them down yet.
Follow the installation section of the UMC C-Axis Platter Replacement linked below for the full instruction on how to correctly reinstall the platter.
Rotate the B-axis 90 degrees [1].
Attach the anti-rotation block [3] to the gearbox using the M6 bolts [4].
If the read head is in configuration [1] you will need to clock it to position [2]  this will require you to redo the compensations on the machine.
If the read head is in configuration [2] the compensations will not need to be redone.
Please contact service about borrowing a swivel checker.
Install the manifold assembly [2] by inserting the anit-rotation dowel pin [1] into the pneumatic manifold.
13
After installing the shaft assembly to the pneumatic manifold make sure to install the snap ring [2] to the shaft groove [1].
14
Install the foot pedal cable [1] to P14 on the I/O board.
From there route the cable to the hole of the front skirt of the machine.
Connect the foot pedal to the cable [1] coming from the front skirt of the machine.
Close the air valve [1] at the bottom of the lube cabinet.
Bleed the remaining air out of the manifold by pulling on the air release [2]. Make sure the gauge on the manifold reads zero.
16
Install the elbow fitting [1] directly into the manifold in position 3 on the front face of the manifold.
17
NOTE: For Non-CAN Lube Cabinet. If the machine has a CAN Lube cabinet skip to step 19.
Plug  the PROGRAMMABLE AIR solenoid cable to P50 on the I/O board.
Route the cable through the jumction box below the control cabinet, through the rear of the machine and into the top of the lube cabinet.
Plug the cable into the empty section of the solenoid connector bracket [1] marked APC DOOR INTERLOCK/PROGRAMMABLE AIR.
18
Install the SOLENOID ASSY PROGRAMMABLE AIR HIGH PRES [1] in position 4 on the front face of the manifold.
Connect the soleniod [1] to the APC DOOR INTERLOCK/PROGRAMMABLE AIR plug on the solenoid connection bracket.
Install the PROGRAMMABLE AIR BLAST SOLENOID [2] in position 7 on the front face of the manifold.
Connect the soleniod [2] to the PALLET AIR BLAST/PROGRAMMABLE AIR BLAST plug on the solenoid connection bracket.
19
For CAN Lube Cabinet:
Connect the soleniod [1] to the APC DOOR INTERLOCK/PROGRAMMABLE AIR plug on the CAN board solenoid connection bracket.
 NOTE: There is a splitter cable that plugs into the CAN solenoid connector bracket this will plug into the two solenoids denoted as [1].
Connect the soleniod [2] to the PALLET AIR BLAST/PROGRAMMABLE AIR BLAST plug on the CAN solenoid connection bracket.
20
Connect the pressure sensor cable to the pressure sensor as shown.
Route the cable back to the I/O board and plug this into P13 using the adapter cable provided in the kit.
NOTE: If the machine is equipped with an APL there will be no need for the adapter cable. The APL will already have a cable plugged in to P13, this cable will have connector that the pressure sensor cable can plug into.
21
Install the air booster on the side of the lube cabinet using the magnets to attach.
22
Add the decal [1] to the bracket of the air booster.
23
Route air lines through the black conduit that routes through the center bore and to the workholding manifold.
Route the opposite ends of the air lines to the top of the lube cabinet.
24
Pull the hoses through the B-axis body and to the pneumatic manifold as shown.
Use the velcro ties [1] and cable clamps [2] to neatly route the cables to the pneumatic manifold.
25
The clamp hose denoted in green  [1] goes the fittings as shown.
The unclamp hose denoted in red [2] is goes to the fitting as shown.
The clear hose goes to the air blast port on the side of the manifold [1]
26
Connect the two red hoses to the two 1/4 push connect fittings and route the hoses through the bottom of the lube cabinet.
NOTE: The image shows the hoses as yellow and blue, but this is for identification purpose, they are both red.
27
The air booster hoses [1] that were routed through the bottom of the lube cabinet will be routed through the back of the air manifold bracket [2] and connect to the solenoid and fittings as shown.
The air hoses routed from the workholding manifold [3] will come out from the top of the lube cabinet and route to the solenoids shown.
28
Re-introduce air to the manifold by turning the valve [1].
29
Reinstall the new cover [2] and return the rotary [1] to 0 degree's on the B axis.
30
Attach the decal [1] (PN: 29-1171) that shows the correct method for cleaning the platter and rotary union port on the front of the UMC.
31
Please refer to the link to install the UMC Pneumatic Vise option.
UMC PNEUMATIC VISE - INSTALLATION AD0453
Option - Activation Code + Patch - NGC
32
Please refer to the link to verify/load any patches involved with the installation.
