Wye-Delta Contactor - Replacement - AD0328
Service Home How To Procedures Wye-Delta Contactor - Replacement - AD0328
Recently Updated Last updated: 02/02/2021
AD0328
- Jump to Section - 1. Electrical Safety 2. Introduction 3. Removal 4. Classic Haas Control - Installation 5. Vector Drive - WYE/DELTA - NGC- Installation (1 step) 6. Test Back to Top
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
This procedure tells you how to replace the Wye-Delta (Y/D) contactor assembly on a machine with a Classic Haas Control (CHC) or a Next Generation Control (NGC).
NGC control Mills built before 8/2017 the following is required for the first time the Wye-Delta assembly is replaced.
  • Mill software version 100.17.000.2034 or higher
  • I/O PCB firmware version 2.05, 2.07 or higher. DO NOT USE version 2.06
  • NGC I/O PCB: 34-3480A and 34-3480B, are not compatible with latest Wye-Delta assembly it must be replaced with a newer version.
  • Wye-Delta contactor patch file.
     Note: The patch gets added automatically to the configuration files after the Wye-Delta assembly order gets processed. If not email: [email protected] to have the patch added to the machine configuration files on the portal.
Removal
Locate the Wye-Delta contactor assembly.
Classic Haas Control:
Mills:
  • The Wye-Delta contactor assembly is in the electrical cabinet.
Lathes:
  • ST series: The Wye-Delta contactor assembly is located in the electrical cabinet.
  • DS-30: The main spindle Wye-Delta contactor assembly is located in the electrical cabinet.  The sub-spindle Wye-Delta contactor assembly is located behind the sub-spindle motor.
  • SL series: The Wye-Delta assembly is located underneath the Hydraulic Power Unit (HPU).
Next Generation Control:
Mills:
Lathes:
  • ST series: the Wye-Delta contactor assembly is located in the electrical cabinet.
  • DS-30: The main spindle Wye-Delta contactor assembly is located on the side of the main spindle motor.  The sub-spindle Wye-Delta contactor assembly is located in the electrical cabinet.
Remove the cover plate.
Mark the cable connections that do not have a label.
Remove the installed Wye-Delta contactor assembly.
Mills and Lathes:
Install the new Wye-Delta contactor assembly. Connect the vector drive and spindle motor cables to the Y/D assembly as shown in the illustration.
 Note: In some machines a white color wire was used instead of blue.
Machines with PRE- I/O S PCB connect cables to I/O PCB at P12 and P58.
Machines with POST- I/O S PCB connect cable to I/O PCB at P53A.
Cablepart number 33-1068/1071 [2] is not used on a machine with a Classic Haas Control, tuck this cable into the cable track.
 Important: Make sure all the wires are connected to the correct terminals and that the screws are tightened.
Mills and Lathes:
Connect cable 33-1076A/1077A to I/O PCB at P37.
Connect cable part number 33-1068/1071 to I/O PCB at P63 and P64.
Test
Test the operation of the Wye‑Delta contactor assembly:
  • Run the spindle at different speeds.
  • Orient the spindle. If the spindle oscillates during orientation check for loose wires.
Next Generation Control: If the machine experiences Alarms: 9101.013, 9101.014 or 9973 please instruct the customer to submit an error log report ([Shift] + [F3]) immediately after the alarm to [email protected] for analysis.
