Axis Lubrication System - Haas Axis Lubrication Oil - RD0005
Service Home Axis Lubrication System - Haas Axis Lubrication Oil - RD0005
Recently Updated Last updated: 10/16/2025
RD0005
- Jump to Section - 1. Introduction 2. Identification Back to Top
Note: The location of the oil reservoir is different on some machines.
The CALM - Haas Axis Lubrication Oil system is a restrictor oil flow system that pumps oil through flexible plastic tubing and copper tubes to the axes.
Identification
Use the illustration to identify the parts of the lubrication system.
Note: For recommended lubricant types, see Lubricant Table for Haas Machine Components.
  1. Oil Pressure Switch - Monitors the oil system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level too quickly.
  2. Oil Pressure Gauge - Shows the pressure (in psi and bar) of the oil system.
  3. Oil Filter Wrench - Removes the oil reservoir.
  4. Oil Reservoir Assembly - Stores the oil.
  5. Air-Lube Panel Decal - Shows the color-coded cables that connect each solenoid.
  6. Oil Reservoir - Stores the oil that lubricates the spindle.
  7. Air Manifold Assembly - Supplies air to the machine.
  8. Axis-Lube Air Solenoid - Pressurizes the oil reservoir.
  9. Air Pressure Gauge - Shows the pressure (in psi and bar) at which the air is supplied.
  10. Electronic Analog Air Pressure Sensor - Monitors the air system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level for a set period of time.
Axis Lubrication
The oil reservoir [1] lubricates the axes at a rate of (1) oil cycle for every 3 hours of axis travel.
Oil moves from the oil reservoir [1] through flexible plastic tubing [2] to the axis manifolds [3].
Note: The number of axis manifolds may be different on some machines.
Note: Each axis has (1) ballnut [4] and (4-6 ) linear guide trucks [5].
Oil moves from the axis manifolds [3] through copper tubes. The copper tubes lubricate the ballnuts [4] and the linear guide trucks [5].
Note: There is (1) copper tube that goes to the ballnut and (1) copper tube that goes to each linear guide truck.
Note: The Haas Axis Lubrication Oil canister lasts approximately 10 months to a year under normal machine operation, 8 hours a day and 5 days per week.
Axis Manifold Fitting Information
The Haas Axis Lubrication Oil system uses adapter fittings [1] in the axis manifolds. The linear guide trucks and ballnuts use restrictor fittings [2]. The restrictor fitting has a gap [4] between the threads and the set screw [3]. This forces the manifold-fed oil to pass through the gap [4] to lubricate the axes.
Note: The copper tubes on this system may or may not be equal length.
Caution: Do not change the length of the copper tubes or flexible plastic tubing. This changes the flow of oil.
