PSUP PCB - Troubleshooting Guide - CHC - TG0107
Service Home PSUP PCB - Troubleshooting Guide - CHC - TG0107
Recently Updated Last updated: 10/14/2025
TG0107
Jump to Section 1. Introduction 2. Symptom Table 3. Short/Tripped Breaker 4. 120 VAC Connection 5. Low Volt Power Supply 6. 240 VAC Connection 7. On/Off Circuit 8. Fuses 9. Electrical Diagrams Back to Top
The Power PCB mounts the low voltage power distribution, high voltage fuses, and circuit breakers.
Alarm 552 TRIPPED CIRCUIT BREAKER (Version M PDIST PCBs only)
An overload condition on the coolant pump, chip conveyor, TSC coolant pump, or work light tripped one of the circuit breakers.
Check for a tripped breaker. Inspect the system connected to the tripped breaker. Correct the root cause of the overload condition and reset the breaker.
The circuit breaker jumper is missing. When the machine does not have TSC option there will be no circuit breaker installed on the PSUP PCB. Make sure the a jumper is installed.
The circuit breakers tabs are not seated correctly on the PSUP PCB. Make sure the all circuit breakers tabs are seated correctly on the PSUP PCB.
(Single-phase machines only), Alarm 552 TRIPPED CIRCUIT BREAKER occurs when the coolant pump gets commanded to turn on.
Note: The circuit breaker did not trip.
The 240 VAC input cable connected to the PSUP at P10 is not correct.
Turn off the main breaker and disconnect 240 VAC input cable from the PSUP at P10 and swap the white and black wire positions on the cable.
None of the 120 VAC connectors have power.
The 120 VAC breaker did not trip.
There is a bad conenction from the main transformer 120 VAC output to the PDIST PCB.
Inspect the cables and connections at TB1 on the the main transformer, and at P1 on the PDIST PCB (or TB1 depending on the version of the PCB).
The 5/12-12 VDC LEDs cycle on and off and the machine does not boot up.
There is a shorted output from the Low Voltage Power Supply (LVPS).
Inspect the Low Voltage Power Supply (LVPS). Look for burnt or overheated components. Inspect the cable harness from the LVPS.
None of the 240 VAC output connectors have power (coolant pump, TSC, or chip conveyor).
The breaker did not trip.
There is a bad connection from the main transformer 240 VAC output to the PDIST PCB.
Inspect the cables and connections at TB2 on the main transformer and at P10 on the PDIST PCB (or TB3 depending on the version of the PCB).
The machine does not power-up.
The voltage at the main circuit breaker is correct.
There is a bad connection at the PDIST PCB ON/OFF circuit connectors.
Inspect the cables and connections for damamge.
Fuses F1 or F3 are blown.
An electrical surge caused an overvoltage condition.
Inspect diodes, MOVs, and inrush current limitors VR1-6 on the PDIST PCB for cracks and burn marks. If VR1-6 are not damaged, replace the blown fuse.
The machine phase detect lights Pass and Fail are both lit.
The machine is wired for single phase.
This is normal for single phase power machines.
Corrective Action:
  1. Main Circuit Breaker
  2. Worklight/GFCI
  3. Coolant Pump
  4. TSC Coolant Pump
  5. Chip Conveyor
Inspect the system connected to the tripped circuit breaker. Find and correct the root cause of the overload condition. Inspect the cables and/or motors for the system connected to the tripped circuit breaker for damage. Reset the breaker.
120 VAC Connection
Corrective Action:
Inspect cables and connections at TB1 [1] on the main transformers, and at P1 [2] on the PDIST PCB Version M, or TB1 [3] on other versions of PDIST PCB.
Corrective Action:
240 VAC Connection
Corrective Action:
Inspect the 240 VAC output cables and connections at TB2 on the main transformers, and these locations on the PDIST PCB:
  • 93-1984: P10 [2]
  • 93-20025: P23, and P15 or P15A (either connector will work) [3]
  • 93-20026: TB3 [4]
On/Off Circuit
Corrective Action:
  • 93-1984: P10 [2]
  • 93-20026: TB3 [4]
Fuses
Corrective Action:
Inspect VR1-6 [1] on the PDIST PCB for damage. Replace any blown fuses [2].
 Note: Not all versions of the PDIST PCB have all of the VR numbers (1-6) [1] or both fuses [2].
Electrical Diagrams
Power Distribution
Power Distribution PCB
PLUG # CABLE # SIGNAL NAME LOCATION PLUG #
P1 94-96 3-PHASE TRANSFORMER -
P2 90C 120 VAC LVPS -
P3 90A 120 VAC SPARE -
P4 JUMPER - - -
P5 90B 120 VAC SWITCH DOOR FAN -
P6 90A 120 VAC SERVO FAN -
P7 90A 120 VAC DELTA-WYE -
P8 JUMPER +12/-12/+5 VDC IN FROM LVPS -
P9 JUMPER - - JUMPER
P10 77/79 230 VAC 3/PHASE TRANSFORMER/320V Power Supply -
P11 90A 120 VAC SPARE -
P12 90C 120 VAC SPARE -
P13 90C 120 VAC SPARE -
P14 90C 120 VAC SPARE -
P15 90C 120 VAC SPARE -
P16 90C 120 VAC SPARE -
P17 90C 120 VAC SPARE -
P18 860 120 VAC AMPLIFIERS -
P19 90 120 VAC 3/PHASE I/O PCB P56
P20 930 230 VAC CLNT PUMP/TSC I/O PCB P44
P21 160 230 VAC CHIP CONVEYOR I/O PCB P39
P22 740 ON/OFF FRONT PANEL (SKBIF) J20
P23 170 AUTO OFF / CONTACTOR CONTACTOR K1 / I/O PCB P42
P24 T5 K1 CONTACTOR TRANSFORMER TO T5 TRANSFORMER -
P25 71, 72, 73 230 VAC IN FROM K1 CONTACTOR -
P27 860 +12/+5 VDC I/O PCB P60
P28 860 +12/+5 VDC MOTIF PCB P15
P30 860 +12/-12/+5 VDC SPARE -
P33 860 +12/-12/+5 VDC MOCON 2 PCB P15
P34 860A +12VDC SMTC PCB P2
P35 860 +12VDC 8M MCD RELAY PCB P2
P36 92A - WORKLIGHT -
