Spindle - Drawbar - Troubleshooting Guide - TG0132
Service Home Spindle - Drawbar - Troubleshooting Guide - TG0132
Jump to Section Back to Top
9.4 40T - Spindle Drawbar - Troubleshooting
Recently Updated Last updated: 10/15/2025
TG0132
Revision A - 12/2025
  1. Drawbar
  2. Toolholder
  3. Retention balls
  4. Pull stud
  5. Belleville springs
The toolholder frets in the taper. The tool pulls out of the taper. Check for damaged Belleville spring washers.
The part has a poor finish. The tool length is too long. Refer to the tool manufacturer's specifications.
The toolholder drops before the tool changer can grab it. The clamp force on the toolholder is too low, or the TRP pre-charge is not set correctly. Check the clamp force and pre-charge air pressure.
(TSC Only) Excessive coolant comes out of the coolant tube behind the spindle. The carbide insert on the drawbar is damaged. Check the carbide insert in the drawbar and TRP for damage.  Note: If the machine has a pre-charge system check that the pre-charge air pressure is set correctly.  Refer to the tool release piston pre-charge adjustment procedure: VMC - 30/40-Taper - Tool Release Piston - Pre-charge - Adjustment
The drawbar does not release the toolholder smoothly. The pull stud angle is pitted or damaged. Check the pull stud for damage.
The TRP sensor(s) are not aligned. Align the tool release piston sensor(s).
The air pressure or volume to the TRP is too low. Check the air pressure and volume.
The drawbar retaining balls are dry. Apply RED-i grease to the retaining balls.
Toolholder makes a "popping" noise when it is released. The toolholder and spindle taper are dirty. Clean the taper.
40T and 50T Belted Spindles
Pull studs will not enter into spindle taper, carbide tips on drawbar and TRP are damaged prematurely,
And possibly one of the following alarms:
Alarm 130 Tool Unclamped
Alarm 134 Tool Unclamp Fault
Alarm 9970 Unexpected Tool Release
There is a small delay from the I/O PCB that causes the pre-charge solenoid not to turn OFF. Order service kits 93-3451 & 93-3452 and follow the Low Load Solenoid Valve Kit - Installation procedure.
Service replacement drawbar will not fit into spindle shaft.  Replacement drawbar needs to be straightened before installation.  Roll replacement drawbar along a high-precision granite table to identify bends or waves in drawbar spring. Mark high spots. Clamp drawbar firmly and use a mallet to tap spring back into place. Take care not to damage drawbar. If drawbar cannot be straightened with this method, contact the service department for a replacement.
Toolholder Is Fretting
Corrective Action:
Verify that the tool length, axis feed, and spindle RPM are correct according to the tooling manufacturer's recommendations.
Drawbar Force
Corrective Action:
Check the clamp force with a clamp force measuring tool and refer to the Drawbar Force Reference Table. If the pull force is low, the drawbar is faulty.
Belleville Springs
Corrective Action:
If the Belleville springs on your drawbar are damaged, you must replace the drawbar. The drawbar in inline spindles cannot be removed. If the drawbar in an inline spindle is damaged, you must replace the entire spindle assembly.
Check for tools getting stuck in the spindle,  inspect the pull studs and spindle taper for damage.
Pull Studs
Corrective Action:
Remove the toolholder from the spindle. Check for damage to the pull stud. The pull stud must have a 45° angle [1].
Ball marks on the edge of the pull stud indicate that the drawbar does not open completely.
Refer to the TRP clamp/unclamp sensor adjustment procedure.
TRP Sensor(s)
Corrective Action:
Air Pressure
Corrective Action:
Verify that the air pressure to the TRP solenoid [1] is 90-psi (6.21 bar).
If the volume is correct, there should be only a 10-psi (0.69 bar) air pressure drop during a tool change. Use an inline air gauge to measure the change in air pressure.
Check for kinks or splits in the air hose that goes to the TRP assembly [2].
Make sure the volume of air supplied to the machine is sufficient. Refer to New Machine Setup/Pre-Installation.
Corrective Action:
To grease the retaining balls, put a ball of RED-i grease on top of a pull stud.
Put the toolholder into the spindle. Clamp and unclamp (4) or (5) times to load the grease onto the retaining balls.
Remove the toolholder. Wipe excess grease from the toolholder and spindle taper.
Contamination
Corrective Action:
Clean the toolholders and spindle taper. Check for damaged toolholders before you put them back in the machine. A damaged toolholder can cause damage to the spindle taper and create tool runout or problems with finish.
