CL-1 Live Tooling Motor - Replacement - AD0528
Service Home How To Procedures CL-1 Live Tooling Motor - Replacement - AD0528
Recently Updated Last updated: 02/01/2023
CL-1 Live Tooling - Motor Replacement
AD0528
- Jump to Section - 1. Introduction 2. Removal (2 steps) 3. Installation (2 steps) 4. Verification (1 step) Back to Top
This procedure shows how to replace the live tooling motor [1] in a CL-1.
This procedure applies the following service kit:
  • 93-3320 LIVE TOOL SERVICE KIT CL-1 SIGMA 7 02
  • 93-3531 LIVE TOOL SERVICE KIT CL-1 SIGMA 7 04
  • 93-3540 LIVE TOOL RETROFIT KIT S5-02 TO S7-04 CL
  • 93-3547 LIVE TOOL RETROFIT KIT S7-02 TO S7-04 CL
IMPORTANT: When upgrading from Sigma 7-02 to 7-04 using service kit 93-3540, install the new motor into the new motor housing first. Then, install and align the motor housing with the machine, refer to CL-1 LIVE TOOLING - INSTALLATION.
Before starting the procedure do the following steps:
  • Clean up any chips.
  • Position the tooling on the x-axis all the way to the right and all the way forward on the z-axis for an optimal reach.
  • Make sure all sharp tools are removed and/or oriented away from the work area.
Removal
Remove the (4) Socket Head Cap Screws (SHCS) [2] to remove the motor plate [1] in the front.
Remove the (4) Socket Head Cap Screws (SHCS) [4] to remove the belt plate [3] in the back.
Disconnect the wires of the motor [2].
Remove the (4) Socket Head Cap Screws (SHCS) and washers [1] from the motor [2].
Lift the motor to remove the belt [3] from the motor pulley [4] and take out the motor [2].
Inspect the belt for wear or damage and replace if necessary.
Install the belt [1] over both pulley's[2].
Insert motor [5] into the housing and loop the belt [3] around the motor pulley [4].  Make sure that the belt is not riding on any one flange.
Use (4) Socket Head Cap Screws (SHCS) and washers [6] to install the motor [5].
Tighten the screws [6] evenly, then torque to 13 ft-lbs.
Install the motor connectors.
Ensure the wires are placed in the casing so that they are not pinched.
Install the motor plate [1] in the front with (4) Socket Head Cap Screws (SHCS) [2].
Install the belt plate [3] in the back with (4) Socket Head Cap Screws (SHCS) [4].
Verification
Press [POWER ON] to turn on the machine.
Test the live tooling motor to ensure everything runs smoothly.
