Front Window - Replacement - VF - DT-1 - TM-3 - AD0098
Service Home How To Procedures Front Window - Replacement - VF - DT-1 - TM-3 - AD0098
Recently Updated Last updated: 04/01/2019
Front Window - Safety Glass Replacement -
AD0098
Applies to machines built from: January, 2002
- Jump to Section - 1. Orientation of Window Glass 2. Front Window - Replacement - VF-1/2 - DT-1 - TM-3 3. Front Window - Replacement - VF-3/4/5/6/8 4. Front Window - Replacement - VF-7/9 Back to Top
 Note: Some Windows will have a engraved label "THIS SIDE OUT" on the pane of the new GLASS WINDOW . This label must face the outside of the door.  If the window has no engraving, the window can be installed in any direction.
Document Applies to these Parts:
KIT PN: 93-2246, WINDOW, GLASS 33.43" X 19.06" KIT. QTY: 1
[A] 28-0136 QTY: 1 DOOR WINDOW VF-SML PRE 2010 GLASS
[B] 57-0505 QTY: 1 SEAL, 0.75" X 0.1875" FOAM TAPE VINYL
[C] 46-1620 QTY: 4 NUT, 10-32 HEX WITH LOCKWASHER
[D] 59-0786 QTY: 12 BUMPER, NITRILE .50 DIAMETER X .25
[E] 25-10105 QTY: 2 RETAINER HORIZONTAL GLASS PRE 2010
[F] 25-10104 QTY: 2 RETAINER VERTICAL GLASS PRE 2010
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the handle from the door [1].
 Note: Do not remove the handle from the DT-1 door.
Go into the machine to get access to the inner side of the front door.
Carefully remove the (4) old retainers [E], [F], the old bumpers [D], the old foam tape [B], and the old glass window [A].
Use a scraper to fully remove all of the old foam tape [B] from the door. Clean the areas of all remaining tape.
Cut (1) piece of the new FOAM TAPE [B] to go on each new RETAINER [E], [F] and along the edge of the window opening. Apply the (5) pieces of tape. Make a 3/4” overlap at the ends of the (1) piece of tape on the door.
 Note: Some Windows will have a engraved label "THIS SIDE OUT" on the pane of the new GLASS WINDOW [A]. This label must face the outside of the door.  If the window has no engraving, the window can be installed in any direction.
Install the (12) new BUMPERS [D]. Install the bottom and left RETAINERS [E], [F]. Install the GLASS WINDOW [A]. Install the remaining (2) RETAINERS [E], [F].
 Note: The kits include (4) HEX NUTS [C]. Replace damaged or missing nuts on the machine.
KIT PN: 93-2223, WINDOW, GLASS 39.25” X 29" KIT. QTY: 1
[A] 28-0139 QTY: 1 WINDOW, GLASS 39.25" X 29.0"
[C] 59-0786 QTY: 14 BUMPER, NITRILE .50 DIAMETER X .25
Push [POWER OFF].
Remove the handle from the door [2].
Carefully remove the (4) retainers [1], the old bumpers [C], the old foam tape [B], and the old glass window [A].
Cut (1) piece of the new FOAM TAPE [B] to go on each retainer and along the edge of the window opening. Apply the (5) pieces of tape. Make a 3/4” overlap at the ends of the (1) piece of tape on the door.
Install the (14) new BUMPERS [C]. Install the bottom and left retainers [1]. Install the GLASS WINDOW [A]. Install the remaining (2) retainers [1].
KIT PN: 93-2292, WINDOW, GLASS 35.75" X 32.5" KIT QTY: 1
[A] 28-0073C QTY: 1 WINDOW, GLASS 35.75" X 32.5"
Push [POWER OFF].
Carefully remove the (4) retainers [1], the old foam tape [B], and the old glass window [A].
Cut (1) piece of the new FOAM TAPE [B] to go on the retainer [1] and along the edge of the window opening. Apply the (5) pieces of tape. Make a 3/4” overlap [4] at the ends of the (1) piece of tape on the door [2].
 Note: Some Windows will have a engraved label "THIS SIDE OUT" [3] on the pane of the new GLASS WINDOW [A]. This label must face the outside of the door.  If the window has no engraving, the window can be installed in any direction.
Install the bottom and left retainers. Install the GLASS WINDOW [A]. Install the (2) remaining retainers.
