Haas Bar Feeder - Drive Belt - Replacement - AD0325
Service Home How To Procedures Haas Bar Feeder - Drive Belt - Replacement - AD0325
4.2 Drive Belt Replacement
Recently Updated Last updated: 02/08/2021
AD0325
Applies to machines built from: April, 2015
  1. drive belt
  2. belt tensioner
  3. tension adjuster nut
  4. clamp plates
  5. drive pulley
This document applies to these parts:
  • [A] 54-0147 QTY: 1 BELT, BARFEEDER AT5 153 INCH
Tools Required:
  • Gates 508c or 550 Sonic Tension Meter
Push [POWER OFF] on the lathe.
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker.
Remove the front enclosure panel.
To remove the belt [A]:
  • Loosen the (2) screws [1] on the tensioner [2]. This lets the tension adjuster [3] move.
  • Loosen the tension adjustment nut [4] to remove the belt [A] tension.
  • Loosen the (4) screws [5] on the right clamp plate [6]. Remove the belt [A] from the right clamp plate [6].
  • Loosen the (4) screws [7] on the left clamp plate [8]. Remove the belt [A]from the left clamp plate [8].
Put the new belt [A] through the left clamp plate [8]. Torque the (4) 10-32 socket head cap screws (SHCS) [7] to 25 in-lb (282 N-cm).
Put the new belt [A] around the idler pulley [9].
Use your hand to pull the belt [A] until it is tight. Put the belt through the right clamp plate [2]. Torque the (4) 10-32 SHCS [1] to 40 in-lb (452 N-cm). Tighten the tension adjustment nut [3] until the belt [A] has tension.
To prepare the Gates Sonic tension meter:
  • Connect the sensor cable to the meter.
  • Push [POWER] [4].
  • Push [MASS] [5]. Enter the correct belt values for "Mass/Weight". Enter the correct belt values for [WIDTH] [6] and [SPAN] [7].
Mass/Weight 3.3 g/m
Width  25 mm
Span 1700 mm
  • Push [Hz] until the display shows T ---------lbf[9].
  • Push [MEASURE] [10].
Use your hand to move the tensioner [1] fully to the left.
Put the sensor [2] less than 3/8" (9.5 mm) from the middle section of the belt [A].
Quickly pull your finger across the edge of the belt ("pluck" the belt like a guitar string). Do not let the sensor touch the belt. If you cannot make the necessary vibration with your finger, you can tap the belt with the handle of a screwdriver. Make sure the tension value shown on the meter is 75 lbf +/- 5. Adjust the tension adjustment nut [3] as necessary.
Measure the tension again. Adjust the nut [3] until the belt tension is correct. Torque the (2) 1/4-20 SHCS [4] to 12 ft-lb (16 N-m).
Install the front enclosure panel.
For a CHC Machine refer to Haas Bar Feeder Operator's Manual for more information about setting up the Bar Feeder.
For a NGC Machine see the link below for the setup procedure.
Haas Bar Feeder - Lathe Setup - NGC
