Haas Robot Package 2 - UMC - Installation
Service Home How To Procedures Haas Robot Package 2 - UMC - Installation
Recently Updated Last updated: 09/27/2023
Haas Robot Package-25kg - UMC - Installation
AD0872
Revision A - 05/2025
This procedure will show you how to install the Haas Robot Arm Package-25kg.
Note: The Haas designed work cell made up of a CNC machine and a robot have been evaluated for compliance to CE requirements. Changes or variations to the Haas cell design should be evaluated for compliance to the applicable standards and are the responsibility of the user/integrator.
Machine Requirements:
  • 100.21.000.1120 version or higher
  • UMC-500/750/1000 Built By Date: (see machine requirements in procedure)
    • Haas Auto Window Option, 90 Degree Control Cabinet, Haas Workholding Ready.
  • Remote Jog Handle - XL 93-1000610 REMOTE JOG HANDLE TOUCH LCD (RJH-XL)
  • I/O PCB HINGE DOOR 93-1000297 I/O DOOR ASSY HINGED
  • Requires separate 200-230V 3-Phase, 50/60 Hz, 3 kVA Power Supply[7]. See the Fanuc STARTUP GUIDE for more information.
Fixing / Anchoring Requirements
The Haas Robot Package-25kg needs to be anchored according to Fanuc's recommendation to be sufficiently stable when used according to Haas defined part size and weight limits. See the Robot Anchoring section below.
The Haas Robot Package Includes the following Components:
  • 30-13419 Robot PKG-25kg UMC Safety Guard (fencing with gate to enclose the operators station)
  • 32-0994 Gate Interlock
  • 32-1276 RJH Holster Assembly (includes holster and 36' foot cable for remote handle jog with Emergency Stop)
  • 32-9016  HRP-25kg Electrical Interface Box Assembly (Includes robot signals and power cables)
 Note: The parts above are subject to change, and there will be some variation depending on the build date.
 Note: In order for the dual grippers to reach the vise, the B axis may need to be tilted toward the robot.
The Haas Robot Package needs the following components to be field installed on a Haas Machine:
PART NUMBER DESCRIPTION
93-1001031 - HRP Ordered Param Robot Magic Code
93-1000997 - Front Automation Safety Par Only
or
93-1000996 - Side Automation Safety Par Only
Front Door Robot Safety Parameter
or
Side Window Robot Safety Parameter
93-1000979 - INSTALL KIT HRP-2 UMC NOT CE
or
93-1000917 - INSTALL KIT HRP-2 UMC CE
UMC-500/750/1000 HRP-2 Install Kit
or
CE UMC-500/750/1000 HRP-2 Install Kit
One of these Robot Safety Devices:
93-1000897   HRP-2 SAFETY FENCE UMC
08-1897   Laser Area Scanner Kit
08-1899   Multi-sided Light Curtain HRP Kit
Robot Safety Device
Robot Lifting
Robot Lifting Requirements
Use this information for lifting/moving Robot Package-25kg.
The Haas Robot Package-25kg needs to be lifted according to Fanuc's recommendation. See the Fanuc Robot M-20iD/25 Mechanical Unit Operator's Manual, Chapter 1, Section 1 Transportation starting on page 1 for lifting/moving information.
HRP-25kg Fanuc Robot M-20iD/25 Mechanical Unit Operator's Manual
Robot Installation
Table 1[1]
Table 2[2] (optional)
Place the Fanuc Control Box on the back side of the machine next to the control panel[3].
Part Flip Station [4].
The plate the robot is mounted on should be orientated with the extra hole [4] pointed toward the machine.
The anchoring plate made before 1/3/2024 [1] will have only four anchoring holes [3] in the corners.
The anchoring plate made after 1/3/2024 [2] will have the original four anchoring holes [3], but also has an additional eight (8) anchoring holes [5].
The mounting plate requires at least four (4) anchors to be used and if only four are used the original holes in each corner [3] must be used. If eight (8) anchors are to be used, use the new outer holes [5].
Measure these dimensions from the machine skirt to the edge of the robot base plate.
 Note: The following dimensions are recommended distances. The position may vary depending on the users application.
Dimension Number UMC-500 UMC-750 UMC-1000
1 (Front side of robot base plate to the side of the machine) 17.0 in. (431.8 mm) 17.0 in. (431.8 mm) 17.0 in. (431.8 mm)
2 (Left side of robot base plate to the front of the machine) 9.5 in. (241.3 mm) 14.5 in. (368.3 mm) 16.5 in. (419.1 mm)
3 (Front table bracket of Table 1 to the side of the machine) 13.0 in. (330.2 mm) 17.0 in. (431.8 mm) 15.0 in. (381.0 mm)
4 (Left mounting hole of the front table bracket of Table 1 to the front of the machine) 22.0 in. (558.8 mm) 13.0 in. (330.2 mm) 15.0 in. (381.0 mm)
5 (Left mounting hole of the front table bracket of Table 2 to the front of the machine) 37.5 in. (952.5 mm) 37.5 in. (952.5 mm) 37.5 in. (952.5 mm)
6 (Right mounting hole of the front table bracket of Table 2 to the front of the machine) 46.5 in. (1181.1 mm) 46.5 in. (1181.1 mm) 46.5 in. (1181.1 mm)
7 (Left mounting hole of the front table bracket of Table 2 to the right mounting hole of the front table bracket of Table 1) 59.0 in. (1498.6 mm) 82.0 in. (2082.8 mm) 80.0 in. (2032 mm)
8 (Rear right anchoring hole of Part Flip Station to the left side of robot base plate) 28.0 in. (711.2 mm) 28.0 in. (711.2 mm) 28.0 in. (711.2 mm)
9 (Front right anchoring hole of Part Flip Station to the side of the machine) 22.0 in. (558.8 mm) 22.0 in. (558.8 mm) 22.0 in. (558.8 mm)
Robot Anchoring Requirements
The Haas Robot Package-25kg Base Plate, Part Table, Fence, and Part Flip Station needs to be anchored to be sufficiently stable when used according to Haas defined part size and weight limits. See the Anchoring Instructions (Drop-In Expansion) for anchoring information.
  • The APL spring pusher is made with a shank to fit either a 25mm or 1” tool holder
  • This tool must take up a toolholder in the tool carousel.
  • Program the following steps to the beginning of any  program to make sure the part is properly seated into the chuck:
    • Locate the spring pusher above the part
    • Move the Z axis to compress the spring about 0.50 inches or 12.7 mm
    • Open the vise with a dwell of one second
    • Close the vise with a dwell of one second
Note: The Part Number for the spring pusher is:
  • 30-12642 SPRING PUSHER APL.  The 25mm or 1.0” holder is sold separately.
Parts Table Assembly
The Parts Table needs to be assembled. Follow the procedure below for installation.
Haas Robot - Parts Table Assembly
Shaft Loading Kit Installation
To install the HRP-2 Shaft Loading Kit. Follow the procedure below for installation.
HRP-25kg - Shaft Loading Kit - Installation
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
UMC Robot Interface Mounting Location
The Robot electrical interface box has magnetic mounts to attach to the machine sheet metal.
Mount the Robot electrical interface box [1] as shown.
Route the Robot interface electrical cables through the bottom of the electrical cabinet.
Pendant Access Cover
Remove the plug installed on the Pendant Access Cover and install the rubber grommet.
If the Pendant Access Cover does not have the access hole, drill a 0.75" hole in the end of the cover.
UMC Robot Electrical & Air Routing
Route cable 33-1134 [1] from the RJH Holster along the fence to the Pendant Access Cover grommet to the SKBIF PCB.
Route cable 33-1135 [2] from the Interlock along the fence and machine skirt with the magnet mounts to the Electrical Interface Box.
Route cable 33-8561C [3] from the Electrical Interface Box along the 90 Degree Control Panel channel to Control Panel.
Route air hose [4] from the Air Regulator along the machine skirt to the Calm Cabinet.
Coil the extra cable from the Fanuc Control Box to the Robot and zip tie the coil to the magnet mounts to attach to the back of the machine off the ground.
Turn the machine air supply OFF.
Inside the CALM cabinet, remove a NPT plug from one of the CALM manifold ports.
The Robot Gripper Air Regulator has magnetic mounts to attach to the machine sheet metal.
Mount the Robot Gripper Air Regulator to the machine skirt below the pendant.
Route the air line from the right side of the regulator along the side skirt of the machine to the CALM cabinet and install the push to connect fitting.
Route the air line from the left side of the regulator to the Air 1 port on the robot and install to the push-to-connect fitting.
Turn the machine air supply ON.
Set the regulator to air pressure required for your application. The higher the pressure, the greater the clamp force. Below are the air pressure ranges of the Single and Dual Grippers for the HRP-2.
  • Single Gripper Air Pressure Range - (36.0 - 100.0 psi)
  • Dual Gripper Air Pressure Range - (44.0 - 100.0 psi)
Perform the following steps to connect the robot to the Haas machine.
Robot Power
Requires separate 200-230V 3-Phase, 50/60 Hz, 3 kVA Power Supply[7]. See the Fanuc Startup Guide for more information.
 Note: It is recommended to install a strain relief cable grip to remove stress on the power cable connections and isolate the power cable from the controller cabinet.
Cable P/N 33-8561C has multiple connections:
I/O PCB
  • Connect the E-STOP terminal block connections to SIO PCB TB-1B (see diagram)[1].
  • Verify the jumper is installed on the SIO PCB at JP1.
  • Connect the Setup mode terminal block connections to SIO PCB TB-3B (see diagram)[1].
  • Plug the User Relays into K9 and K10.  (see diagram)[11].
  • Connect the cable labeled P1 SIO to the SIO PCB at P1[2].
Note: Do not plug anything into the connector FILTER OV FAULT.
Maincon PCB
  • Connect the RJ-45 cable [3] to Ethernet to USB adapter [4] (P/N 33-0636). Connect the USB connector end to the Maincon PCB J8 top port (see diagram). Add a ferrite filter 64-1252 to the USB adapter.
PSUP PCB
  • Mount the 24VDC Power Supply[10] to the left side of the control cabinet and plug into connector labled 24V PS on cable 33-8561C. Connect cable 33-1910A[9] to the 24VDC Power Supply[10] and plug into P3 on the PSUP PCB.
SKBIF to Remote Jog Handle
  • Connect the RJ12 cable 33-1134[5] from the Remote E-stop box to cable 33-0713 and plug into the SKIBF PCB P9.
  • Remove the jumpers JP2 and JP3 on the SKBIF from the horizontal position and replace them in the vertical position.
  • Plug the RJH-XL cable into the cradle.
 Warning: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe. Jumpers MUST be inserted vertically.
Robot Electrical Box to Robot Control
  • Connect the Robot Control Signal Cables [6] P/N 33-8592A to the Robot Electrical Interface Box. Add a ferrite filter 64-1252 to the RJ-45 cable.
 IMPORTANT: When connecting the Robot Control Signal Cable [6], make sure to line up the M12 connector female notch with the M12 connector male key to prevent any misalignment that could result in damaged pins.
 Note: If cable 33-8591A or 33-8592A is not installed to the Fanuc Control box, see the HRP Troubleshooting Guide Robot Control Wiring HRP-2/3 step for wiring instructions.
Robot Safety Device
  • Connect the robot safety device cable [8] from the electrical interface box to the robot safety device—either light curtain, interlock fence or area scanner.  For more information regarding safety devices, refer to the Robot Safety Device section below.
Robot Safety Device
IMPORTANT: DO NOT OPERATE THE ROBOT UNTIL YOU HAVE PROPERLY CONFIGURED AND TESTED THE OPERATION OF THE SAFETY DEVICE.
Light Curtain
If the machine came equipped with the light curtain option, the light curtain needs to be installed. Follow the procedure below for installation:
Light Curtain Installation
Robot Fence:
If the machine came equipped with the fence option, the robot fence and door interlock assembly need to be installed to machine. Follow the procedure below for installation:
Robot Fence Installation
HRP-25kg UMC Fence Layout
Attention: The fence anchors will use a 3/8th drill bit, they are NOT the same size as the robot anchors.
Robot Fence:
Install the fence panel assembly to the fence post with the self tapping screws. The top of the fence panel assembly should be 14.5 inches from the top of the fence post.
Install the fence panel assembly to the side of the machine with the self tapping screws. The location installed will depend on the machine and fence location
Robot Fence:
Install the control panel fence panels together. Install the fence panel assembly to the 90 degree control panel channel.
Install the fence panel assembly to the fence post and side of the machine with the self tapping screws. The location installed will depend on the machine and fence location
Area Scanner:
If the machine came equipped with the area scanner option, the area scanner needs to be installed and configured to the space. Follow the procedure below for installation:
Area Scanner Installation
First Power-UP
Locate the Mode Switch on the Controller Operator Panel. The key should be set to Auto Mode[2].
Make sure the [E-STOP] button[3] is not pressed.
Turn on the Robot Control box by rotating the Breaker clockwise to On[1].
Turn on the Haas CNC.
Zero Return all Axes.
Insert Service USB key.  Go into Service mode.
Go to Parameters> Factory tab.  Change the following:
  • 1278 [1278:] Robot Ready E-Stop Enabled to TRUE
  • 2191 [694:] LIGHT CURTAIN TYPE to LC_TYPE_1
Note: Machines with Software Version 100.20.000.1010 or higher will need to change the following parameter:
  • 2192 [:] Light Curtain Trigger Threshold to 0
Press [SETTING].
Set the Settings:
  • 372 Parts Loader Type to 3: Robot.
  • 376 Light Curtain Enabled to On
Press [CURRENT COMMANDS].
Go to Devices>Robot>Jogging tab. Change the following:
  • Maximum Jogging Speed to 7.9 in/sec (200 mm/sec).
Go to the Setup tab. Change the following:
  • Max Robot Speed to 157 in/sec (3988 mm/sec).
  • Gripper Net Mass - Enter the Net Mass of the gripper. Refer to the HRP-2 Machine Layout Drawing to get the correct value for this setting.
    Warning: Setting this value incorrectly can cause the Robot Arm to not move correctly.
  • Number of Grippers to the number of grippers.
  • Raw Gripper Clamp Output to 1.
  • Raw Gripper Unclamp Output to 2.
  • Raw Gripper Clamp Delay to the clamp/unclamp duration in sec.
  • Raw Gripper Clamp Type to OD/ID.
Go to Devices>Robot>Setup tab[1].
Press [E-Stop].
Press [F1] to connect the robot[2].
The first time connecting a robot to a machine, a Robot Activation window will pop-up. This pop-up shows the Software Version of the machine[3], the MAC address of the robot[4], and the Machine Generated Code[5] used for Machine Time Extension on the portal.
To activate the robot, enter the F Number[6] and Unlock Code[7].
The F Number is found on the robot ID tag that is on the control panel door or on the robot arm.
The Unlock Code is generated after completing the Robot Installation on the Haas Business Center.
 Note: The machine needs to be activated before the robot is activated. Follow the Machine Activation / Time Extension - NGC procedure.
For Service Activation. In Service Mode, Press [INSERT] to connect the robot. This will be disabled after a Cycle Power.
Note: This step can only be completed by a HFO Service Technician.
Note: The green button on the control box will light up.
Press the [HANDLE JOG] button.
Press the [CURRENT COMMANDS]  and go to Devices > Robot > Jogging tab.
On the Remote Handle Jog Touch press the Joint button to go into the Joints Coordinates.
Jog the robot from its shipping position to a safe position.
Note: Press [Emergency Stop] before working on the robot.
Note: Turn off the machine air by turning the valve in the Air/Lube cabinet and pull the pressure relief valve to release the air in the system.
Gripper Assembly
Install the gripper to the robot end effector mounting face.
See the HRP-25kg Dual Gripper - Installation instructions for installing the dual gripper on the HRP-25kg.
This is the case for all UMCs with HRP-2.
Once a loading position is determined, the loading position can be saved by going to Current Commands -> Devices -> Automatic Part Loader -> Load part [2] -> Internal Axes Location for Load [1].  Press F2 to set the current position of the machine as the loading position.
More information about setting up HRP templates can be found at HRP - Operations.
If the load and unload locations need to be different, custom templates will need to be used. HRP - Operations - 9.3 - Custom template.
Route the air lines between the solenoid on robot arm and the gripper. Connecting the airlines to the corresponding color coded fittings. Install conduit to each pair of air lines.
 Note: Turn on the machine air by turning the valve in the CALM cabinet.
Verification
Test the E-stop:
  • Press the Pendant and External E-STOP buttons and make sure the machine generates 107 EMERGENCY STOP alarm.  If the E-STOP button does not generate a 107 EMERGENCY STOP alarm verify the wiring. Load the latest configuration files to enable the RJH-XL.
Test the Robot Safety Device:
Make sure that there is an E-STOP or light curtain triggered icon on the Haas pendant when the robot safety device is triggered.
  • Fence - Insert the key into the interlock, verify that the two red LED lights in the front of the interlock are OFF. Remove the key from the interlock, verify that the two red LED lights are ON.
  • Area Scanner - Step inside the protective field, verify that the red LED lights up on the area scanner. Step outside the protective field, verify that the green LED lights up.
  • Light Curtain - Interfere the light curtain beams, verify that the light curtain triggered icon appears on the Haas pendant. Press [RESET]. Step outside of the light curtain beams, verify no icon appears on the Haas pendant.
 NOTE: If the light curtain triggered icon does not show, verify wiring, alignment and factory setting: 2191 [694:] LIGHT CURTAIN TYPE is set to LC_TYPE_1.
Test the operation of the grippers:
  • Verify that both grippers clamp and unclamp correctly.
  • Press the [CURRENT COMMANDS]  and go to Devices > Robot > Jogging tab.
  • Press [F2] to clamp/unclamp the Finish Gripper.
  • Press [F3] to clamp/unclamp the Raw Gripper.
Test the Remote Jog Handle:
  • Undock the Remote Jog Handle
  • Press the [HANDLE JOG] button.
  • On the Remote Handle Jog press the Joint button to go into the Joints Coordinates.
  • Move the robot to a safe location.
 IMPORTANT: If a yellow warning message appears saying "Please activate Light Curtain or Cell Safe" while trying to job the robot, verify the safety parameter was applied by re-uploading the configuration files from HBC.
Verify Safe / Run Mode Operation
All Haas CNC machines are equipped with a key switch on the side of the control pendant to lock and unlock setup mode. The robot will have the following behaviors depending on what mode is selected.
  • When the Haas control is in Run mode, mode 1, unlocking the interlock and opening up the gate stops all motion, and no motion can be started until it is closed and locked.
  • When the Haas control is in Set up mode, mode 2, speed limited motion such as jogging an axis of the robot can be performed in order to program a robot's path of motion, pick up position, set a robot's tool center point, (an offset), load and pick up parts from the spindle or part holder in the machine, etc. The programmed path will also be able to be run slowly to prove out the programmed path of the robot. The robot in setup mode can only be handle jogged while the F2 button the RJH is pressed.
Each Haas Robot is provided with FANUC's DCS System. This allows the user to define speed and positional limits to the robot. If the robot goes outside of these limits, DCS will stop the robot and remove power to the motors.
This procedure will show you how to set up a Fanuc Dual Check Safety (DCS) zone.
Fanuc Memory Device (MD) Backup
Fanuc Memory Device (MD) Backup - No Audio
After the DCS Zone has been setup, create a Memory Device (MD) backup of the robot. Connect to the Fanuc Control with a laptop and iPendant.
Insert the thumb drive with the MD backup into the USB port in the black door on the controller (UD1:) or USB port on the teach pendant (UT1:).
Navigate to the Navigate pendant.
Set the default device to the device you want. The two options are UT1: for the Fanuc Teach Pendant or UD1: for the USB port on the front of the Fanuc Control Box.
  • Press MENU and then File.
  • Press F1, [TYPE]. Select File.
  • Press F5, [UTIL]. Select Set Device.
  • Navigate to the Device you want to save the backup to, UT1: or UD1:.
  • Press F4, [BACKUP]. If you do not see [BACKUP], press [FCTN] and select RESTORE/BACKUP.
  • Select All of Above and press [ENTER].
  • It will prompt you select the backup operation you want to perform. Press F4, [YES] to back up the current file.
  • The backup process will take a few minutes to complete.
Attach the MD Backup to the machine Work Order.
After installing the robot, set up a job following the procedure below.
Disable the Robot
To disable the robot to run the machine in stand-alone mode. Press [SETTING]. Change the following Settings:
  • 372 Parts Loader Type to 0: None
  • 376 Light Curtain Enabled to Off
