Wye-Delta Contactor - Troubleshooting Guide - CHC - TG0164
Service Home Wye-Delta Contactor - Troubleshooting Guide - CHC - TG0164
Recently Updated Last updated: 10/15/2025
Wye - Delta Contactor - Troubleshooting Guide - CHC
TG0164
- Jump to Cause - 1. Components 2. Electrical Safety 3. Symptom table 4. Wye-Delta Assembly Inspection 5. Wye Contactor Voltage Inspection 6. Delta Contactor Voltage Inspection 7. Electrical Diagrams Back to Top
Components
  1.  Wye contactor.
  2. Delta contactor.
  3. 120 VAC Power cable.
  4. Contactor Feedback cables (NGC machines Only).
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Symptom table
SYMPTOM POSSIBLE CAUSE CORRECTIVE ACTION
Alarm 236 SPINDLE MOTOR OVERLOAD, Alarm 2041 VECTOR DRIVE OR SPINDLE AMPLIFIER-OVERLOAD, and/or the spindle load pegs to 200% when any spindle speed is commanded. There is an open coil on one of the Wye-Delta contactors. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
There is no voltage from the I/O PCB to the Wye contactor coil. Measure the resistance and the voltage.  Refer to Wye Contactor Voltage Inspection section.
The encoder belt is damaged, or the Non-Contact Encoder has a fault Inspect the encoder belt, encoder connections, encoder gaps and encoder alignment.
Alarm 236 SPINDLE MOTOR OVERLOAD, Alarm 2041 VECTOR DRIVE OR SPINDLE AMPLIFIER-OVERLOAD, and/or the spindle load pegs to 200% when speeds above 2500 rpm are commanded. The machine operates properly at low speeds. There no voltage from the I/O PCB to the Delta contactor coil. Measure the resistance and the voltage.
Check the diagnostic page to coordinate when to measure the voltage across the delta contactor coil.
Alarm 123 SPINDLE DRIVE FAULT at any spindle speed, and Alarm 2040 VECTOR DRIVE OR SPINDLE AMPLIFIER-SHORT CIRCUIT. Faulty Wye-Delta contactor assembly. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
Faulty vector drive. Inspect the vector drive and look for a shorted output.
Go to: Vector Drive - Troubleshooting Guide to troubleshoot the vector drive.
Alarm 116 SPINDLE ORIENTATION FAULT. There is a loose connection on the WYE/DELTA buss connectors. Inspect the WYE/DELTA contactor buss connections make sure they are making all the terminal leads.
Spindle load pegs to 200% There is an open coil on one of the Wye-Delta contactors. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
Corrective Action:
Inspect the Wye-Delta assembly. Make sure that all connections are tight, and that there are no signs of arching or burn marks on the contactors, burnt marks on the jumper bus-bar or contacts.
With the machine OFF, measure the resistance across the coil between connectors A1 and A2. The resistance should read 10-100 Ohms. If the reading is open (OL) or less than 5 ohms, then the coil is defective.
Power-up the machine and make sure that only the Wye contactor is energized when no spindle speed is commanded. If both contactors are closed at the same time, one of the contactors may be stuck (welded shut). The vector drive sees this condition as a short.
Corrective Action:
  1. Power up the machine and wait until the machine finishes booting up.
  2. Measure the voltage across the coil between the A1 and A2 connectors of the Wye contactor. It should read 120 VAC.
    • If the voltage is correct, but the contactor does not engage, the contactor may have a mechanical issue.
    • If there is no voltage present, the problem may be caused by the I/O PCB, or the wiring from the Wye/Delta to the I/o PCB
    •  Go to:
      •  Classic Haas Control - I/O PCB - Troubleshooting Guide
Corrective Action:
  1. Power-up the machine and enter a program in MDI that commands the spindle to spin at 2000 rpm. Slowly increase the spindle speed while observing the diagnostics page.
  2. Classic Haas Control: Look at bit 15 , Spindle D:Y At the moment this bit changes from 0 to 1, the Delta contactor is energized.
  3. Measure the voltage across the Delta contactor’s coil between the A1 and A2 connectors.
    • Go To:
Electrical Diagrams
