Zero Point Ready (ZERO POINT READY )
Product Image
GET QUOTE
Zero Point Ready
    CNY ONLY
For use with the Haas Robot Package-25kg Pallet Loading System
  • Option Info
  • Specs
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
Our Zero Point Ready kit includes everything you need to load parts with the Haas Robot Package-25kg Pallet Loading System. Includes a zero point pallet receiver to accept zero point pallets, a foot pedal for manual clamping/unclamping, and all necessary plumbing, solenoids, and hardware for installation.
NOTE: The Zero Point Ready option is included when the RPL-25KG is ordered with a new machine, but must be purchased through service when installing the RPL-25KG on a machine in the field.
  • Accurate, repeatable pallet clamping
  • Control manually or via the Haas control
Service Documents
SPECIFICATIONS SAE Metric
Positional Repeatability 0.0002 in 0.005 mm
Clamp Force w/Air 5,952 lbf 26,476 N
Clamp Force w/o Air 2,204 lbf 9,804 N
Max Part Diameter 8.0 in 203 mm
Max Square Part 6.75 in x 6.75 in 171.0 mm x 171.0 mm
Pallet Size 8.27 in x 8.27 in 210 mm x 210 mm
Pallet Weight (w/hardware) 9.0 lb 4.1 kg
Air Pressure Min 100 psi 6.9 bar
Need More Information?
