40-Taper - Inline 3rd Generation Spindle - Convert Baldor Motor to Yaskawa
Service Home How To Procedures 40-Taper - Inline 3rd Generation Spindle - Convert Baldor Motor to Yaskawa
Recently Updated Last updated: 01/18/2019
- Jump to Section - 1. Introduction 2. Replace Baldor Motor with Yaskawa Motor (3 steps) Back to Top
You will need:
  • Kit part number 93-2870 (YASK MTR UPGRADE KIT 3RD GEN)
  • 17/64" Drill Bit
  • Power Drill
  • Cutting tool (modify sheet metal shroud)
Turn off and lock out machine.
Remove sheet metal, motor shroud, and spindle motor fan.
Unplug encoder cables and disconnect terminal block cables.
Remove the encoder [1] and save for the Yaskawa motor.
Note: Inspect the encoder belt and pulley for wear.  If it is worn, replace immediately in order to not damage the new motor.
Use a lifting strap through the motor bracket [2] and remove the motor [3].
Remove the old motor spacers [4] and bolts.
Install the encoder [1] to the Yaskawa motor.
  • Install 25-6293A (encoder bracket) and 25-6298 (bracket sheet metal) to the motor using 4 EA of 40-1645 (SHCS 10-32 x 5/8).
  • Attach 25-6298 to 25-6293A using 2 EA of 59-0742 (spring).
Install the new motors [2] spacers to the tool release piston (TRP).
Note: Match the orientation of the spacers [3].
Install the motor using the lifting bracket [4].
Plug in all encoder and terminal box cables.
Once the spindle and motor coupler are mated, align the motor to the spindle.
Leave the motor bolts loose during alignment.
Run the spindle CW and the CCW at 1000 RPM for about a minute each.
Begin to slowly snug the motor bolts down while running CW at 1000 RPM.
If there's any noise from misalingment you can put the vibrational analyzer on the spindle and watch the vibration displacement spike as you snug each bolt.
Torque motor bolts per Haas Torque Specifications
The existing motor shroud may need the following modifications:
Cut off exisiting motor shroud legs if necessary [3].
Drill 8 x 0.265" (17/64" drill bit) diameter holes in the shown locations (red) on the shroud.
4 holes on panel [1] and 4 holes on panel [2]. The holes are through-all to both sides.
  • 9.50" height from top of shroud to first set of holes
  • 2.25" height to second set of holes
  • 3.50" width across holes
The dimensions are referenced from the panel centerline.
Locate the centerline (blue) from the center distance of the square cutout in the bottom of the shroud.
The holes are used for mounting the shroud to the universal shroud mount and lifting bracket.
