APL V-Rail Retrofit Kit - Installation - AD0484
Service Home How To Procedures APL V-Rail Retrofit Kit - Installation - AD0484
4.1 APL AU-AXIS V-RAIL Retrofit
Recently Updated Last updated: 02/01/2021
AD0484
APL V-Rail Retrofit Kit - Installation Video
Sheet Metal & Cable Removal
If the APL is already installed to a machine. Lower the ram to above the middle and right side of the table. The gripper plates should be parallel to the table and the gripper fingers 0.25" above the table. If connected to a machine, power off the machine.
Remove the front sheet metal cover[1].
Remove the top rear sheet metal cover[2].
Disconnect the motor cables for both motors[3].
Disconnect the switch cables[4] and switch cable zip ties.
 Note: Note how the switch cables are positioned on the switch.
Remove the horizontal cable carrier from rear lower sheet metal[1].
Remove the cable carrier from carriage plate[2] and vertical beam[3].
Remove the lower rear sheet metal[4].
If the APL has the shipping brackets installed. See the APL Installation procedure below for removal. Do not remove the vertical beam shipping bracket[5].
Note: If the vertical beam shipping bracket[5] is removed, install it to the vertical beam.
APL Installation
Motor & Carriage Removal
Remove the vertical beam motor and motor spacer[1] from the carriage plate.
Loosen the shipping bracket hardware[2] on the vertical beam and lower the ram to the table so the gripper plates or fingers rest on the table. Tighten the shipping bracket hardware.
Remove the horizontal beam motor[3] from the carriage plate.
Remove the 4 vertical wheels[4] from the left side of the vertical beam.
Slide the carriage away from the vertical beam and remove the 4 lower horizontal wheels[5] from the carriage plate and lift the carriage plate off of the horizontal beam.
Linear Rail Installation
Install the spacers[1] and T-nuts[2] to the v-rails. Space the spacers by one hole all the way down the v-rail. Torque the center screw[3] that mounts the spacer to the v-rail to 10 ft-lbs with the spacer pressed against the shoulder of the v-rail. Snug down the t-nuts.
Slide the rail onto beam snugging down and orienting the T-nut as you slide into the horizontal beam slot. Install 2 rails on top and 2 on bottom of the rack. The left side of the rail should be 4.5"[4] from the edge of the left side of the horizontal beam.
Assemble the V-rail spreader tool using wheels[5], bushings[6], spacers[7], washers[8], and screws[9] from the retrofit kit.
Remove the hard stop on the right side of the beam and slide the v-rail alignment tool onto the v-rails.
Start at the end of the rail and use a flat blade screwdriver to spread top rail and then tighten the right screw on the first spacer.
Note: Torque M6 screws to 10 ft-lbs.
Spread the lower rail and then tighten the right screw. Move down to next screw starting at the top rail and continue spreading and tightening the rails from the right to left.
Note: Where the v-rails meet, use the screw driver to spread both rails and tighten the screws on either side. Insure that the rails are against each to have a smooth transition for the carriage.
Reinstall the hard stop 6.7"[1] from the edge of the beam.
Carriage & Motor Installation
Transfer the 4 vertical wheels[1] from the old carriage plate to the right side of the new carriage plate.
Remove the vertical switch[2] and the 2 sheet metal brackets[3] from the old carriage plate and install them to the new carriage plate.
Remove the wheel assemblies[4] from the v-rail spreader tool and install them with lock washers to the carriage plate.
Install the horizontal switch[5] and cable carrier bracket[6] to the carriage plate.
Install the carriage onto the v-rails and install the lower wheels.
Start with the outside wheels and adjust the cams so wheels engage the rail and do not spin.
Install the middle wheels and adjust the cams to engage the wheel to the rail.
Install the horizontal beam motor[1] to the carriage plate.
Slide the carriage to vertical beam and install the 4 vertical wheels[2] to the carriage plates.
Loosen the shipping bracket hardware on the vertical beam and raise the ram off the table. Tighten the shipping bracket hardware.
Install the vertical motor[3] to the carriage plate.
Sheet Metal & Cable Installation
Assemble the wipers and install them to carriage plate.
Install the lower rear sheet metal[1].
Install the cable carrier to the carriage plate[2] and vertical beam[3].
Install the horizontal cable carrier to the rear lower sheet metal[4].
Connect the motor cables to both motors[1].
Connect the switch cables[2] and install new switch cable zip ties.
Install the top rear sheet metal cover[3].
Install the front sheet metal cover[4].
Testing
Remove the vertical shipping bracket and move carriage along v-rails checking for wheel engagement and a smooth transition from one rail to the other.
Adjust the lower horinzontal wheels if engagement is not made along length of the v-rails.
