Servo Driven SMTC - Grid Offset and Tool Change Offset - VMC - CHC
Service Home How To Procedures Servo Driven SMTC - Grid Offset and Tool Change Offset - VMC - CHC
6.8 Servo Driven SMTC - Grid Offset and Tool Change Offset - VMC - CHC
Recently Updated Last updated: 08/13/2025
Servo-Driven SMTC - Grid Offset and Tool Changer Offset - VMC - CHC
Revision A - 08/2025
Arm at Origin Position - Check
Press [POWER ON].
Press [PARAMETER DIAGNOSTIC] (2) times. Select the I/O 2 tab.
If Origin is 1 . Go to the Grid Offset and Tool Changer Offset section.
If Origin is 0 [1], put the machine in DEBUG mode.
Press [RESET] to clear alarms.
Press [M] for manual recovery if you have software version 18.01A or higher.
Press [Y] (3) times if you have software lower than 18.01A.
Press [ATC FWD] or [ATC REV] until Arm at Origin changes to 1.
Set Grid Offset
Change setting 7 to OFF.
Put the machine in [DEBUG] mode.
Press [ZERO RETURN]. Press [ALL].
Press [POSITION].
Type GRID TT and press [WRITE ENTER]. The screen shows the message GRID OFFSET DONE.
Set Tool Change Offset
Change Parameter 487 to 0.
Go into MDI. Press [RECOVER], press [F1], and press [M].
Press [ATC REV] to bring Arm at Origin to 1.
Change Parameter 462:18 to 0.
Jog the TT-Axis in .01 increments.
Press [POSITION].
Jog the double-arm in the positive direction until it is under the spindle. The MOTOR STOP is 1 and the ORIGIN is 0.
Note: Make sure to jog the double arm slowly. Stop the arm rotation as soon as the bit changes. If you turn the arm too far, do the procedure again.
Jog the double-arm in the negative direction. Jog until MOTOR STOP is 1 and the ORIGIN is 1.
 Note: The arm is near the origin position but not under the spindle.
Record the TT PRIME ENC value 1.
Jog the double-arm in the negative direction until the Motor Stop or the Origin is 0.
Record the TT PRIME ENC value 2.
Add value 1 and 2 that you recorded in the step before. Divide by 2.
Type as a negative value the TT PRIME ENC value into Parameter 487.
For example, if the result is 190312, set Parameter 487 to -190312.
Make sure the Origin bit is 1.
Change Parameter 462:18 to 1.
Go out of DEBUG mode.
Change setting 7 to ON.
