Coolant Level Float Sensor - NGC - Installation - AD0661
Service Home How To Procedures Coolant Level Float Sensor - NGC - Installation - AD0661
18.1 Coolant Level Float Sensor - Installation
AD0661
Revision A - 3/2026
COOLANT LEVEL FLOAT INSTALLTION
This procedure tells you how to install the Coolant Float Sensor into the coolant tank.
Do this procedure for these tanks:
  1. 55-gallon tank
  2. 95-gallon tank
The machine software requirements:
  • NGC Software
This procedure applies to the following P/N:
  • 93-2876        FIELD INSTALL KIT CPK-MM EDU/UK
  • 93-CS_GR     FIELD INSTALL CS-GR
  • 93-1000353  COOLANT OPTION W/AUGER GM-2
  • 93-1000354  COOLANT OPTION GR
  • 93-1000396  COOLANT OPTION KIT GM-2 3AX
  • 93-1000397  COOLANT OPTION KIT GM-2 5AX
  • 93-2257        COOLANT FLOAT SVC KIT
COOLANT LEVEL FLOAT INSTALLTION INTEGRATED BASE
This procedure tells you how to install the Coolant Float Sensor into integrated base tanks.
Do this procedure for these machines.
  • ST-10
  • ST-10Y
  • ST-15
  • ST-15Y
Coolant Level Float Installation
Push [POWER OFF].
Put the float [1] from the coolant float assembly [A] into the tank.
If coolant tank has dimples [2], align the housing dimples [3] with the dimples of the side of the tank lid [2].
Push the housing [4] down into the cutout of the tank lid.
Put the cable [5] from the assembly to the coolant electrical connection panel.
Coolant Level Float Installation Integrated Base
Push [POWER OFF].
Attach coolant float assembly [1] 30-30090E to float assembly bracket [2] 25-14916.
Align slots and dimples on each assembly.
Attach the float assembly to bracket until it snaps into place.
Place Float Sensor and bracket through casting cutout and hang on the inside edge of base casting [1].
 Note: You may need to rotate assembly in order to place in correct location.
Coolant Level Float Sensor Connection
 Note: The location of the electrical connector panel changes with the machine type.
Route the cable from the assembly to the coolant electrical connection panel.
Connect the M12 cable [1] from the coolant float assembly to the rear-panel coolant sensor [2].
Verifying Parameters
Push [POWER ON].
Insert Service USB key and go into Service Mode.
Push [DIAGNOSTIC].  Go to the Factory tab.
Push [E-STOP].
Ensure the values for Parameters 603 and 604 are correct. Refer to the tables below for the correct values of parameters.
To make sure the coolant tank float operates correctly, do these steps:
  1. Push [MEMORY] on the pendant.
  2. The upper-right corner of the screen shows a coolant level arrow. When the float goes up, the arrow goes up [1]. When the float goes down, the arrow goes down [2].
Mill Machine Model Parameter 603 Value
(NGC)
Parameter 604 Value
(NGC)
DM, DT, EC, ES, GR, HS, UMC, VF, VR, VS 2580 3080
MM, SMM 2580 3080
Lathe Machine Model Parameter 603 Value
(NGC)
Parameter 604 Value
(NGC)
TL-1, TL-2 0 0
ST‑10 through ST-55, DS‑30 2580 3080
