Door Edge Sensor - Lathe - Installation - AD0575
Service Home How To Procedures Door Edge Sensor - Lathe - Installation - AD0575
5.2 Lathe Edge Sensor Install
Recently Updated Last updated: 09/29/2023
AD0575
The procedure outlines how to install the door edge sensor on lathes.
Machine Requirements:
  • Software Version 100.21.000.1110 or higher
  • Haas Autodoor (See machine requirements for CAN AUTO DOOR)
  • 93-1000756: EDGE SENSOR KIT 37.5 INCH ST-10/15/L
  • 93-1000757: EDGE SENSOR KIT 45.5 INCH ST-20/30 and DS-30Y (Reboot)
  • 93-1000758: EDGE SENSOR KIT 45.5 INCH ST-20L/30L
  • 93-1000818:  EDGE SENSOR FIELD INSTALL KIT 58.75 INCH ST-40's
Attach the rail to the sheet metal using the double sided tape provided. Drill 0.159 inch holes in the sheet metal and secure the rail using the provided self-tapping screws.
  • ST-10/15/L use (4) 10-24 PHCS (PN: 40-0192)
  • ST-20/30/L/40 use (5) 10-24 PHCS (PN: 40-0192)
  • DS-30Y (Reboot) use (5) 10-24 PHCS (PN: 40-0192)
Note: When attaching the rail to the sheet metal, make sure there is clearance for the door to close properly.
Slide the edge sensor [1] onto the rail.
Attach the cable on the edge sensor to cable [A]. Route cable [A] to the electrical cabinet as shown.
The cable part number for cable [A] is as follows:
  • ST-10/15/L: 33-0792
  • ST-20/30 and DS-30Y (Reboot) : 33-0793
  • ST-20L/30L: 33-0794
  • ST-40: 33-1799
Note: The edge sensor cable may be pinched when reinstalling the sheet metal over the cable routing, if this is the case, use washers under the bolts at [1] to relieve pressure off the cable.
Remove the LVPS and Autodoor power supply assembly [1] from the electrical cabinet.
Make sure the switch on the relay is switched to the ON position [1].
Remove the Autodoor power supply and attach the Edge Sensor Relay bracket (25-15536) [1] to the LVPS  using the screws [2] from the LVPS.
Snap in the Edge Sensor Relay [3] as shown, no hardware is needed.
Reattach the Autodoor power supply [1] to the LVPS and Relay assembly.
Attach the complete assembly [2] into the electrical cabinet.
Connect the following cables to the relay as shown in the diagram:
  1. Cable [A]
  2. Cable 33-0797
  3. Cable 33-0601
  • ST-20/30 and DS-30Y (Reboot): 33-0793
  • ST-40: 33-1799
Door Edge Activation
Turn on the machine.
Login to the HBC PORTAL.
Download the Door Edge option configuration patch files.
Note: The option files will appear on the configuration download page after the Door Edge service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Verification
Verify that the necessary patches are loaded to the machine.
Verify that INPUT 128 [1] is triggered when the edge sensor is tested.
