EC - 400/500 Inline Pin Drive Spindle - Replacement - AD0729
Service Home How To Procedures EC - 400/500 Inline Pin Drive Spindle - Replacement - AD0729
Recently Updated Last updated: 12/07/2023
AD0729
- Jump to Section - 1. Introduction 2. Spindle Removal (3 steps) 3. Spindle Installation (2 steps) 4. Spindle Verification (2 steps) Back to Top
This procedure applies to EC-400 and EC-500's that have a 40T spindle with an inline pin drive.
This procedure applies to the following service kits:
  • 93-30-13742: SPINDLE 40T INLINE 8K PIN HMC W/DB
  • 93-30-13739: SPINDLE 40T INLINE 15K PIN HMC W/DB SVC
The following tools are also recommended for this procedure:
  • Silicone Fluid
  • T-2108 SMTC Arm Alignment Tool
  • T-2086 CT-40 Alignment Split Tool
  • T-2087 BT-40 Alignment Split Tool
Note: The images in this procedure are all of an EC-400, but the same steps will apply for an EC-500 with a 40T spindle with an inline drive.
Spindle Removal
Jog the Y axis to position the Spindle Head to facilitate the removal of the spindle.
Push [E-STOP].
Disconnect the spindle lubrication tube and remove the elbow fitting [1].
Note: Failure to remove the fitting will cause the fitting to become damaged.
Remove bolts [1] followed by removing the Spindle [2] away from the Spindle Head [3].
Apply Silicone Fluid to these parts:
  • Transfer Tube [1]
  • (2) Transfer Tube O-rings [2]
  • Pin-Coupler Bushings [3]
  • Spindle Coupler Pins [5]
Install the Transfer Tube [1] to the motor shaft.
Visually align the bushings [5] to the pins [4] on the Motor Coupler.
Caution: An incorrectly aligned coupler can cause damage to the bearings.
Bring Spindle [1] against the Spindle Head [2] to snug the (6) bolts [3] in a star pattern.
Torque the (6) SHCS 3/8-16 bolts that hold the Spindle [1] to the Spindle Head [3]. Refer to HAAS FASTENER TORQUE SPECIFICATIONS.
Put a test bar into the spindle.
Put an indicator onto the table.
Put the tip of the stylus against the side of the spindle test bar. Find the high spot then jog the Z Axis and check the alignment.
If the spindle is correctly aligned, the total indicated reading is NTE 0.0005".
If  the spindle is not within the indicated reading, add shims between the spindle casting and the spindle housing until the spindle is correctly aligned.
Torque the (6) screws that hold the spindle. Refer to Haas Fastener Torque Specifications. Use the value for iron.
Do this step again to make sure the alignment did not change.
If the spindle is not correctly aligned after shimming, adjust the spindle motor alignment process. Refer to Spindle Motor Alignment - EC-400
Connect the spindle lubrication tube and attach the elbow fitting [1].
Reset Spindle Orientation Offset. Refer to Side-Mount Tool Changer - Spindle Orientation Offset - NGC or Side-Mount Tool Changer - HSK - Spindle Orientation Offset - NGC
Verify SMTC Offset using Split Tool.
Run a SPINDLE VIBRATION TEST
Run the spindle break-in program: SPINDLE - BREAK-IN PROGRAMS - LATHE AND MILL
