EC-400/500/630 - WIPS - Field Installation - AD0778
Service Home How To Procedures EC-400/500/630 - WIPS - Field Installation - AD0778
- Jump to Section - 1. Introduction 2. Installation (25 steps) 3. Pop-up Probe Cylinder - Test (1 step) Back to Top
Recently Updated Last updated: 02/13/2025
AD0778
This procedure will show you how to install the WIPS system on EC-400/500/630 machines.
Requirements:
  • All NGC Machines
  • 93-1000219 - INTUITIVE PROBING BT40 EC400
  • 93-1000230 - INTUITIVE PROBING CT40 EC400
  • 93-1000394 - INTUITIVE PROBING HSK-A63 EC-400/500
  • 93-1000866 - INTUITIVE PROBING CT50 EC-500/50
  • 93-1000867 - INTUITIVE PROBING BT50 EC-500/50
  • 93-1000868 - INTUITIVE PROBING CT50 EC-630
  • 93-1000869 - INTUITIVE PROBING BT50 EC-630
Stone and clean the B-AXIS BODY surface [1].
Stone [1] and clean the POP-UP PROBE ASSEMBLY surface [2].
Rotate the purple zip-tie and the gray zip-tie towards each other [3].
EC-630 Machines
Install bracket [1] with the (4) SCHS 5/16-18 X 2 1/2" bolts [2].
Remove right operator's side front panel [1].
Find the PURPLE HOSE & GRAY HOSE [1].
Route purple hose [1] and grey hose [2] air lines through the B-Axis Body Casting [3].
Cut the Purple and Gray Hose [1] H=3" long.
 EC-630 ONLY: 3" from top of Bracket
Remove the red plastic plugs from the POP-UP PROBE Assembly.
Connect the PURPLE HOSE [1] and GREY HOSE [2] to the POP-U PROBE.
EC-400/500 Machines
Fasten the POP-UP PROBE [1] to the B-AXIS BODY [2] with the (4) SHCS 5/16-18 x 10 [3].
Torque fasteners. Refer to Haas Fastener Torque Specifications.
EC-630 Machines
NOTE: Note the orientation of the POP-UP PROBE.
Secure the UP/DOWN SENSORS [1] with VELCRO STRAPS.
Route the UP/DOWN SENSORS [1] through the CABLE CARRIER [2] (on the same channel as the air hoses).
Connect the UP/DOWN SENSOR CABLES [1] on the CONNECTOR BRACKET [2] location labeled PROBE UP and PROBE DOWN.
13
EC-400/500 Machines
Remove the hardware [1] that secures the PROBE BASE ASSEMBLE [2].
Remove the PROBE BASE ASSEMBLE [2] from the PROBE COVER ASSEMBLY.
14
EC-630 Machines
EC-400/500 Machines
Fasten the PROBE BASE PLATE COVER [1] onto the POP-UP PROBE [2] using the (2) FBHCS 1/4-20 x 1/2 screws [3].
16
EC-630 Machines
17
EC-400/500 Machines
Stone and clean the PROBE BASE PLATE surface highlighted [1] & [2].
18
EC-630 Machines
19
EC-400/500 Machines
Fasten the PROBE COVER ASSEMBLY [1] onto the PROBE BASE PLATE [2] with the FBHCS 1/4-20 x 1/2 [3].
 NOTE: Wrap the shop towel around exposed portion of the pop-up cylinder rod [4] to avoid any damage while aligning the linkage base.
20
EC-630 Machines
21
EC-400/500 Machines
NOTE: Wrap the shop towel around exposed portion of the pop-up cylinder rod to avoid any damage while aligning the linkage base.
Attach the trap box lid linkage [3] to the top of the pop-up cylinder rod [4] with the bolt [1] and the flat washer [2].
Setup a dial indicator [5] magnetic base on the spindle to indicate the straight edge [6] of the linkage base in Z axis.
Rotate the linkage base until the straight edge [6] is parallel to Z axis motion NTE 0.003" (0.075 mm).
Hold the pop-up cylinder rod from rotating with 1" open wrench and tighten the mounting bolt [7].
Verify the alignment of the straight edge [6] after tightening the mounting bolt. Repeat the alignment steps if needed.
22
EC-630 Machines
23
EC-630 Machines
Install the PROBE COVER LOWER [1] with a GASKET PROBE MOUNT CVR [2].
Fasten the (4) BHCS 10-32 x 3/8" [3] to the EC-630 bracket.
24
With the pop-up probe extended attach the linkage assembly [2] to the trap box lid [3] with the two BHCS [1]. Leave the bolts [1] loose at this time.
Retract the pop-up probe.
With the probe retracted make sure that the linkage mounting bolts [1] have some free movement in the slots. If the bolts are bound-up against the perimeter of the slot check the alignment of the linkage base in the previous step.
Tighten the linkage mounting bolts [1] in small increments until snug.
Extend the pop-up probe.
Finish tightening the linkage mounting bolts [1] while observing the movement in the links [2]. The linkage mechanism should not have any bind or tension and you should be able to move the links and the lid a small amount by hand. Bound-up linkage will cause the probe repeatability problems.
NOTE: If binding occurs, the screws that fasten the box to the cylinder body [4] can also be used for adjustment.
25
Install the OTS [1] onto the OTS base [2] and tighten the six setscrews around the OTS base.
Align the OTS stylus. Refer to the link below for more info.
WIPS - Installation
On the CURRENT COMMANDS page navigate to the DEVICES - MECHANISMS tab and press F2 [1] to extend/retract the tool probe.
Observe the operation of the pop-up probe cylinder and the trap box lid.
Refer to the link below to calibrate the probing system.
NGC - Probe Calibration
