Extruded Spindle Liner - Installation - Lathe - AD0021
Service Home How To Procedures Extruded Spindle Liner - Installation - Lathe - AD0021
Recently Updated Last updated: 06/07/2022
Extruded Spindle-Liner - Installation - Lathe
AD0021
Applies to machines built from: July, 2005 to October, 2015
- Jump to Section - 1. Introduction 2. Installation Back to Top
This procedure tells you how to install the lathe spindle liner adapter and liners.
The adapter [2] goes onto the end of the hydraulic cylinder. The extruded spindle-liner [3] goes inside the adapter. The liner end-cap [1] holds the extruded spindle-liner in position. The size of the adapter changes with the size of the spindle bore. The size of the extruded spindle-liner changes with the size of the bar stock.
Refer to Spindle Liner Kit Reference Table to match your lathe to the correct Spindle Liner Kit and Adapter.
For non-extruded spindle-liner installations, refer to ST-30/30Y Big Bore, ST-35/35Y Spindle Liner Kit Installation.
 Important: The illustrations do not show the coolant collector and Bar Feeder. This lets you see the steps. The removal of these parts is not necessary.
Block the spindle so it cannot rotate. Use a physical block like a wooden beam, or the lathe turret or tailstock. If the lathe is equipped with a C Axis, you can use the spindle brake (M14). Never use M19 to block the spindle.
Apply removable thread-locking compound to the inner threads of the liner adapter.
Type A:
Turn the liner adapter [1] onto the threads of the hydraulic union.
Tighten the (3) clamp bolts [2] on the liner adapter.
Check the runout on the liner adaptor. Use the clamp bolts to adjust the runout if needed.
Type B:
Torque the liner adapter to approximately 70 ft-lb (95 Nm). Use the hook tool [3] to tighten the liner adapter.
Tighten the set screws [2] into, or on the liner adapter (ST-25/30).
Type A:
Remove the liner end cap [1]. Select the correct spindle liner for your bar stock. Put the spindle liner [2] into the spindle. If using an inner liner [3] you must use the included washer [4].
Install the liner end cap [1] onto the liner adapter with the wave washer [5] in place. With your hand, twist-lock the cap in place.
Type B:
Loosen the clamp screw and remove the liner end cap [1]. Select the correct spindle liner for your bar stock. Put the spindle liner [2] into the spindle.
Install the cap and tighten the lock screw [7] to approximately 2 ft-lb (3 Nm). If you tighten the screw too much, you can cause damage to the threads. If the screw is too loose, the cap moves.
 Note: If you removed the coolant collector, install it. Make sure you unblock the spindle before you continue operation.
