Lathe - Spindle Solid Front Cap - Replacement - AD0734
Service Home How To Procedures Lathe - Spindle Solid Front Cap - Replacement - AD0734
Recently Updated Last updated: 01/25/2024
AD0734
- Jump to Section - 1. Introduction 2. Machine Compatibility 3. Replacement (8 steps) Back to Top
This procedure shows how to replace current spindle front caps with solid front caps.
 Note: Only replace non-solid caps with a front solid cap if you are experiencing high runout and poor surface finish problems.
Service Kits are not available to order at this time.
Required Tools:
  • Feeler gauge
  • 0.0001" Dial Indicator with Mag Base
  • Air line with quick disconnect
  • T-0151 A2-8/A2-6 SPINDLE DEFLECTION TOOL KIT
  • T-0156 A2-5 SPINDLE DEFLECTION TOOL KIT
 Note: Only one of the above kits needs to be ordered. Choose the one that fits your spindle size. Refer to the Lath Chuck Diameter Chart if needed.
Machine Soild Cap Inner Shims
(see note)
Outer Shims
(see note)
Drain screw
TL-1/2  6-hole pattern: 20-10016
59-2099
(SHIM FRONT CAP A2-5 .003)
59-2105
40-1930
(FHCS 1/4-20 X 1 1/8)
ST-10  10-hole pattern: 20-10017 59-2098
TL-1/2
ST-15/20/30
 6-hole pattern: 20-10015
59-2097
(SHIM FRONT CAP A2-6 .003)
59-2106
ST-15/20/25/30
DS-30Y
 10-hole pattern: 20-10014 59-2096
ST-35  8-hole pattern: 20-10010
  59-2095
(SHIM FRONT CAP A2-8 .003)
59-2108
(SHIM FRONT CAP ST-35 A2-8 .003)
40-0297
(FHCS 1/4-20 X 1 1/4)
ST-28/35  10-hole pattern: 20-10013 59-2094
 Note: A majority of machines should need either 1x inner shim or 1x outer shim. Rare cases may need 2x inner or 2x outer. If more than 2x of the same shim are needed contact Haas service.
Replacement
Note: This procedure uses a ST-35 for illustrative purposes. The same applies to all machines listed above unless otherwise specified.
Remove chuck from spindle [1].
Remove bulkhead ring [2].
Remove the existing front cap [1] and clean up any sealant on the spindle head face [2], near the bearings [3], or where the bulkhead ring was seated [4].
Install the solid front cap [1] with half of the bolts. Snug bolts hand tight.
If the cap has 6 holes, use 3 bolts skipping every other hole.
If the cap has 8 holes, use 4 bolts skipping every other hole [2].
If the cap has 10 holes, use 5 bolts skipping every other hole [3].
Place a feeler gauge [1] under the empty bolt holes [2] to measure the gap between the solid front cap and the spindle head face [3].
The desired “crush” for a solid front cap is .002” - .005”.
Based on the previous feeler gauge measurement, there are 3 possible scenarios:
  1.  No feeler gauge will fit underneath the empty screw hole position.  This means there is no crush on the bearings.  Add 1x inner shim [1] and re-do step 4 with feeler gauge until desired “crush” is achieved.
  2. A feeler gauge more than .005” fits underneath empty screw hole. This is more than the desired “crush”.  Add 1x outer shim [2] then re-do step 4 with feeler gauge until desired “crush” is achieved.
  3. A feeler gauge between .002” and .005” fits underneath empty screw hole. This is the desired “crush” amount, so no extra shim is needed.  Proceed to step 6.
 Note: The inner shim will sit on top of the bearings and the outer shim will sit on the spindle head face.
Once the desired “crush” is achieved, install any remaining bolts [1] into the front cap.
Install the drain screw [3].
  • Snug the spindle cap srews [3]
  • Use a .001" shim [4] between the cartridge [1] and the spindle retainer [2]
  • Tap the spindle retainer with a plastic mallet until the shim clears every section of the cartridge
  • Torque the retainer screws [3] in a star pattern. HAAS TORQUE CHART
    • Note:You may need to start at a 1/3 of the torque value and torque them down 3 times. Torqueing down all the way the first time may displace the retainer cap and require it to be reset.
  • Sweep between the cartridge and the retainer cap one last time to verify the .001" shim has clearance all the way around [4]
Follow the Spindle Deflection Test procedure to confirm bearings are properly loaded.
Re-seal and install bulkhead ring [1].
Install chuck onto spindle [2].
