Lathe - Y-Axis - Toolholder to Spindle Centerline Adjustment - CHC
Service Home How To Procedures Lathe - Y-Axis - Toolholder to Spindle Center Line Adjustment - CHC
Recently Updated Last updated: 10/04/2019
- Jump to Section - 1. Section 1: Toolholder to Spindle Centerline Check (1 step) 2. Section 2: For Lathes Equipped with a Y-Axis - Set Parameter 211 and 254 (6 steps) Back to Top
  • This procedure assumes that you have went through the steps before spindle centerline in the ST, DS - Field Service Lathe Level and Alignment Checklist. If not, do this now to ensure that you do not induce errors from other components that could be out of alignment.  Always start at the basics and then move forward.
  • Check the current spindle centerline setting:
    • Start with tool pocket 1
    • For Hybrid turrets, first check the VDI pockets and make any necessary adjustment to bring the turrent into centerline if need be. This will assure the whole turret is in alignment.  Then you can go check each of the BOT pockets and adjust individual pockets by using the cam if necessary.
  • Note: Make sure that the mating surfaces of the tooling are clean. Any debris between the turret and the toolholder will affect the measurements.
  • Get the value of Parameter 254 SPINDLE CENTERLINE from SYSTEM parameters
  • Instert Parameter 254 into a TOOL GEOMETRY offest that is not used
    • Press F2 to insert the Parameter 254 value.  It should now show in inches or millimeters
  • Clamp the co-axial indicator [2] in the chuck
  • Install a boring bar toolholder into tool 1 [1]
  • Jog the turret until the co-axial indicator is inside the toolhoder
  • Then carefully jog the machine to the x position that was recorded from the Parameter 254 value
  • Sweep the inner diameter (ID) of the tool holder bore [1]
    • Not to Exceed (NTE) 0.001" (0.0254 mm)
  • Pockets other than tool 1 must not exceed 0.003" (0.076mm)
  • If this value is exceeded you will you need to adjust your spindle centerline
  • The goal is to have the co-axial indicator [2] show the closest to zero as possible at the 3 o'clock [4] and 9 o'clock [3] positions, NTE 0.001" (0.0254mm)
  1. Set the indicator to zero at the 3 o'clock postion
  2. Turn the spindle by hand until the indicator is in the 9 o'clock position
    • Note the value that the indicator moved
  3. Jog the X-Axis half the value the indicator moved in the direction of the pocket center
  4. Rotate the spindle back to the 3 o'clock position and set the indicator back to zero
  5. Rotate to the 9 o'clock position again and the value the indicator moved should be less
  6.  if the value is not zero then repeat Steps 3-5 until you get the closest reading to zero as possible
    • The runout is NTE 0.001" (0.0254 mm) but the smaller the runout the better the machine will be
  • Record the value of Parameter 700 (Y-Axis Wedge Angle) in a safe location, you will need this value to reset this Parameter later.
  • Set the Parameter 700 to 0
  • Record the value of Parameter 211 (Y-Axis Tool Change Offset)
  • Set Parameter 211 to 0
  1. Turn the spindle by hand until  the indicator is at the 12 o'clock position [3].
  2. Multiply the value on the indicator by 1.414.
    • For example, +0.0600 x 1.414 = +0.0848.
  3. Jog the Y-Axis to the calculated value, for example +0.0848.
  4. Jog the X-Axis again until the indicator shows 0 at 3 o'clock [1] and 9 o'clock [2].
  5.  Repeat 1-4 until the indicator shows 0 at 3 o'clock [1], 9 o'clock [2], and 12 [3] o'clock.
  • In DEBUG mode, press [POSIT].
  • Record the COMMAND Y value from the DEBUG RAW DATA.
  • Record the COMMAND X value from the DEBUG RAW DATA.
  • Change a negative number to a positive number. Or change a positive number to a negative number. And remove the "." from the number.
  • Enter the Y-value into Parameter 211.
    • For example, if the raw data value is 11.0087, enter -110087.
  • Enter the X-value into Parameter 254.
    • For example, for -78.2231 enter 782231.
  • Change Parameter 700 back to the initial value.
  • Check centerline as in Section 1.  NTE 0.001" (.0025 mm).
    • Toolholders other than tool 1 NTE 0.003" (0.0762 mm)
  • If centerline is off, repeat the steps for setting Parameter 211 and 254.
  • Be sure to calibrate the tool probe at this time. Refer to the procedure in the Lathe Operator's Manual.
