SR-3015P Sheet Router
  1. Vertical Mills
  2. SR Sheet Routers
  3. SR-3015P Sheet Router w/ATC
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
Sheet Router with 118" x 59" x 11.7" travels and ATC
See Available Stock
Current Lead Time
  • ISO30 Taper
  • 3 Axis
  • 24k RPM
  • 12 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Haas SR Series sheet routers are affordable alternatives to gantry-style milling machines for cutting lighter materials, such as wood, plastics, high-density foam, and composites. Powered by the industry-leading Haas control, SR Series routers provide a level of programmability and functionality not found in other CNC routers
The SR-3015P is equipped with an 24,000-rpm ISO30-taper spindle and a 12-station linear tool changer for high productivity and fully automated operation. It comes standard with a PVC vacuum table with selectable zones, and a 7.4 hp (5.5 kW) vacuum pump (for use with the grid table and sealing cord). The machine’s large travels easily accommodate full sheets of material, long extrusions, or multiple setups of smaller parts, and the intuitive Haas control interface and robust features make programming and adjustments easy – even for beginners.
NOTE: The SR-3015P uses servomotor axis drives. Includes (12) ISO30 ER32 toolholders with pull studs, and (1) ER32 collet wrench.
  • 24,000-rpm ISO30 integral motor spindle
  • Vacuum table with 7.4 hp (5.5 kW) pump
  • 12-station linear tool changer
  • Built-in tool setting system
  • Built-in dust removal system
  • Full-function, easy-to-use Haas control
  • Includes (12) ISO30 ER32 toolholders, with pull studs, and (1) collet wrench
ATTENTION! The supplied vacuum pump is suitable for use with the standard grid table, using sealing cord to hold down the workpiece. For use with spoil board, a much larger vacuum pump from a 3rd-party supplier will be required.
NOTE: SR Series sheet routers are intended for profiling, drilling, and shaping flat sheets of lighter materials. They are not intended for surfacing large areas with high accuracy.
Available for order in North America only.
HAAS SHEET ROUTER
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 118.00 in 3000 mm
    Y Axis 59.00 in 1500 mm
    Z Axis 9.80 in 250 mm
    Spindle Nose to Table (~ max) 11.7 in 297 mm
    Spindle Nose to Table (~ min) 1.9 in 47 mm
    Spindle S.A.E METRIC
    Max Rating 12.1 hp 9.0 kW
    Max Speed 24000 rpm 24000 rpm
    Max Torque 5.6 ft-lbf @ 10000 rpm 7.6 Nm @ 10000 rpm
    Drive System Integral Spindle/Motor Integral Spindle/Motor
    Taper ISO30 ISO30
    Table S.A.E METRIC
    Length 120.1 in 3050 mm
    Width 59.0 in 1500 mm
    Max Weight on Table (evenly distributed) 2976 lb 1350 kg
    Between Columns 62.4 in 1584 mm
    Feedrates S.A.E METRIC
    Max Cutting 394 ipm 10.0 m/min
    Rapids on X 1772 ipm 45.0 m/min
    Rapids on Y 1772 ipm 45.0 m/min
    Rapids on Z 591 ipm 15.0 m/min
    Axis Motors S.A.E METRIC
    Drive Type Servomotor Servomotor
    Max Thrust X 900 lbf 4004 N
    Max Thrust Y 450 lbf 2002 N
    Max Thrust Z 1215 lbf 5406 N
    Tool Changer S.A.E METRIC
    Type Linear Rack Linear Rack
    Capacity 12 12
    Max Tool Diameter (full)** 2.0 in 50 mm
    Max Tool Length (from gage line) 3.25 in 83 mm
    Max Tool Weight 22.0 lb 10.0 kg
    Tool-to-Tool (avg) 20.00 s 20.00 s
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 24000 rpm 24000 rpm
    Spindle Power 10.0 hp 7.5 kW
    Full Load Amps (3 Phase) - Low 60 A 60 A
    Full Load Amps (3 Phase) - High* 30 A 30 A
    Domestic Pallet 90.0 in x 180.0 in x 78.0 in 229 cm x 457 cm x 198 cm
    Export Pallet 90.0 in x 180.0 in x 78.0 in 229 cm x 457 cm x 198 cm
    Weight 4057 lb 1840.0 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    RELATED PRODUCTS
    Standard Features
    • 24,000-rpm ISO30 Spindle
    • 12-Station Linear Tool Changer
    • Air-Oil Blast, SR-P Series
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Visual Part Programming System
    • Spindle Orientation
    • User-Definable Macros
    • Coordinate Rotation and Scaling
    • Dust Collector for Sheet Router
    • Vacuum Table System
    • Phone Charging Stand
    Warranty
    • 6-Month Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Operator’s Manual
    • SR-3015P Flyer
    RELATED PRODUCTS
    SMALLER VERSION
    Haas SR-3015
    SR-3015 Sheet Router
    CNC Sheet Router with 118" x 59" x 7.1" travels
    • ER32 Collet Taper
    • 3 Axis
    • 18k RPM
    • 1 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas DT-2
    DT-2
    CNC Drill/Tap Center with 28" x 16" x 15.5" travels
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 20+1 Tool Capacity
        CNY ONLY
    COMPACT 40-TAPER
    Haas Super Mini Mill
    Super Mini Mill
    Super-Speed Mini Vertical Mill with 16" x 14" x 15" travels
    • 40 Taper
    • 3 Axis
    • 10k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Build & Price
    Get Started
    Need More Information?
