SR-4020 Sheet Router
  1. Vertical Mills
  2. SR Sheet Routers
  3. SR-4020 Sheet Router
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Sheet Router with 159" x 86" x 6.8"
See Available Stock
Current Lead Time
See Available Stock
Current Lead Time
  • ER32 Collet Taper
  • 3 Axis
  • 18k RPM
  • 1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Haas SR Series sheet routers are affordable alternatives to gantry-style milling machines for cutting lighter, non-metallic materials, such as wood, plastics, high-density foam, and composites. Powered by the industry-leading Haas control, SR Series routers provide a level of programmability and functionality not found in other CNC routers.
The SR-4020 is equipped with an 18,000-rpm ER32 collet spindle that accepts tools up to 0.75" (20 mm) diameter, and the machine’s large travels easily accommodate full sheets of material, long extrusions, or multiple setups of smaller parts. The intuitive Haas control interface and robust features make programming and adjustments easy – even for beginners.
NOTE: The SR-4020 uses stepper motor axis drives. The machine does not require compressed air.
  • 18,000-rpm ER32 spindle, 4.5 kW
  • Full-function, easy-to-use Haas control
  • Built-in dust collection system
  • Built-in tool setting system
HAAS SHEET ROUTERS
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 158.60 in 4029 mm
    Y Axis 86.40 in 2195 mm
    Z Axis 6.76 in 172 mm
    Spindle Nose to Table (~ max) 7.3 in 185 mm
    Spindle Nose to Table (~ min) 0.3 in 8 mm
    Spindle S.A.E METRIC
    Max Rating 6.1 hp 4.5 kW
    Max Speed 18000 rpm 18000 rpm
    Max Torque
    Drive System Integral Spindle/Motor Integral Spindle/Motor
    Taper ER32 Collet ER32 Collet
    Table S.A.E METRIC
    Length 157.5 in 4000 mm
    Width 82.7 in 2100 mm
    Max Weight on Table (evenly distributed) 8818 lb 4000 kg
    Between Columns 82.1 in 2084 mm
    Feedrates S.A.E METRIC
    Max Cutting 236 ipm 6.0 m/min
    Rapids on X 315 ipm 8.0 m/min
    Rapids on Y 315 ipm 8.0 m/min
    Rapids on Z 98 ipm 2.5 m/min
    Axis Motors S.A.E METRIC
    Drive Type Stepper Motor Stepper Motor
    Max Thrust X 340 lbf 1512 N
    Max Thrust Y 680 lbf 3025 N
    Max Thrust Z 1150 lbf 5110 N
    Spindle Speed 18000 rpm 18000 rpm
    Spindle Power 6.1 hp 4.5 kW
    Full Load Amps (3 Phase) - Low 30 A 30 A
    Domestic Pallet 222.0 in x 112.0 in x 75.5 in 564 cm x 285 cm x 192 cm
    Weight 4850 lb 2200.0 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    RELATED PRODUCTS
    Standard Features
    • 18,000-rpm Spindle, ER32 Collet
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Visual Part Programming System
    • User-Definable Macros
    • Coordinate Rotation and Scaling
    • Dust Collector for Sheet Router
    Warranty
    • 6-Month Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing (Coming Soon)
    • Operator’s Manual
    RELATED PRODUCTS
    SMALLER VERSION
    Haas SR-3015
    SR-3015 Sheet Router
    CNC Sheet Router with 118" x 59" x 7.1" travels
    • ER32 Collet Taper
    • 3 Axis
    • 18k RPM
    • 1 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    More Capability
    Haas SR-4020P
    SR-4020P Sheet Router
    Sheet Router with 169" x 86" x 13" travels and ATC
    • ISO30 Taper
    • 3 Axis
    • 24k RPM
    • 16 Tool Capacity
        CNY ONLY
    40-Taper Alternative
    Haas GR-510
    GR-510
    CNC Gantry Router with 121" x 61" x 11" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
    • 10 Tool Capacity
        CNY ONLY
    Build & Price
    Get Started
    Need More Information?
