SR-4020P Sheet Router
  1. Vertical Mills
  2. SR Sheet Routers
  3. SR-4020P Sheet Router w/ATC
    CNY ONLY
Sheet Router with 169" x 86" x 13" travels and ATC
Haas SR Series sheet routers are affordable alternatives to gantry-style milling machines for cutting lighter materials, such as wood, plastics, high-density foam, and composites. Powered by the industry-leading Haas control, SR Series routers provide a level of programmability and functionality not found in other CNC routers
The SR-4020P is equipped with an 24,000-rpm ISO30-taper spindle and an 8-station linear tool changer for high productivity and fully automated operation. It includes a PVC vacuum table with selectable zones, and a 7.4 hp (5.5 kW) vacuum pump. The machine’s large travels easily accommodate full sheets of material, long extrusions, or multiple setups of smaller parts, and the intuitive Haas control interface and robust features make programming and adjustments easy – even for beginners.
NOTE: The SR-3015P uses servomotor axis drives. Includes (8) ISO30 ER32 toolholders and (1) ER32 collet wrench.
  • 24,000-rpm ISO30 integral motor spindle
  • 8-station linear tool changer
  • Built-in dust removal system
  • Vacuum table with 7.4 hp (5.5 kW) pump
  • Full-function, easy-to-use Haas control
  • Includes (8) ISO30 ER32 toolholders and (1) collet wrench
  • ISO30 Taper
  • 3 Axis
  • 24k RPM
  • 8 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Available for order in North America, Europe, and the UK only, with estimated delivery December 2025.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Machine Info
  • Specs
Series Info
AVAILABLE OPTIONS
RELATED PRODUCTS
Fast | Affordable | Reliable
Haas SR Series sheet routers are affordable alternatives to gantry-style milling machines for cutting lighter, non-metallic materials, such as wood, plastics, high-density foam, and composites. The large travels of these machines easily accommodate full sheets of material, long extrusions, or multiple setups of smaller parts.
ER32 / ISO30
TAPER
AXIS
18,000-24,000
RPM
1 - 8
TOOL CAPACITY
Sheet Routers
Haas SR-3015
SR-3015 Sheet Router
CNC Sheet Router with 118" x 59" x 7.1" travels
    CNY ONLY
Learn More Build & Price
Haas SR-3015P
SR-3015P Sheet Router
Sheet Router with 118" x 59" x 11.7" travels and ATC
    CNY ONLY
Haas SR-3015
SR-4020 Sheet Router
CNC Sheet Router with 159" x 86" x 6.8"
    CNY ONLY
Haas SR-3015P
    CNY ONLY
HAAS CONTROL
Powered by the industry-leading Haas control, SR Series routers provide a level of programmability and functionality not found in other CNC routers. The intuitive Haas control interface and robust features make programming and adjustments easy – even for beginners. This is the same powerful, easy-to-use Haas control found on every machine we build. Designed and built in-house – hardware and software – the Haas control is optimized specifically for Haas machine tools, and is the same across the entire product line. The Haas control is fast, smart, and powerful, with a simple user interface and consistent, intuitive navigation that make it easy to learn and use. With more than 300,000 Haas controls in use worldwide, it clearly is an industry standard.
Standard Features:
■ Touchscreen Interface
■ Dedicated Keypad
One-Button Features
■ Multi-Function Jog Handle
■ Color LCD Screen
■ Ethernet Interface
■ USB Port
■ M130 Media Player
Advanced Tool Management
■ 1 GB Program Memory
■ Power-Failure Detection
■ HaasConnect Mobile Monitoring
■ WiFi Connectivity
■ HaasDrop Wireless File Transfer
DUST COLLECTION SYSTEM & TOOL SETTER
SR Series sheet routers are equipped with a built-in vacuum dust collection system to easily remove chips, swarf, and dust produced during machining, keeping your shop cleaner, and reducing exposure to airborne dust.
A built-in tool setter is hardwired to the Haas control, with easy-to-use templates that simplify job set up when changing tools.
Standard Features
  • 24,000-rpm ISO30 Spindle
  • 8-Station Linear Tool Changer
  • Air-Oil Blast, SR-P Series
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • Power Surge Protection
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Visual Part Programming System
  • Spindle Orientation
  • User-Definable Macros
  • Coordinate Rotation and Scaling
  • Dust Collector for Sheet Router
  • Vacuum Table System
  • Phone Charging Stand
Warranty
  • 6-Month Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing (Coming Soon)
  • Operator’s Manual
RELATED PRODUCTS
SMALLER VERSION
Haas SR-3015P
  • ISO30 Taper
  • 3 Axis
  • 24k RPM
  • 8 Tool Capacity
    CNY ONLY
Lower Price
Haas SR-3015
  • ER32 Collet Taper
  • 3 Axis
  • 18k RPM
  • 1 Tool Capacity
    CNY ONLY
40-Taper Alternative
Haas GR-510
GR-510
CNC Gantry Router with 121" x 61" x 11" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 10 Tool Capacity
    CNY ONLY
Travels S.A.E METRIC
X Axis 168.90 in 4289 mm
Y Axis 86.40 in 2195 mm
Z Axis 13.03 in 331 mm
Spindle Nose to Table (~ max) 13.4 in 340 mm
Spindle Nose to Table (~ min) 0.4 in 9 mm
Spindle Nose to Table (min) Table Surface Table Surface
Spindle S.A.E METRIC
Max Rating 12.1 hp 9.0 kW
Max Speed 24000 rpm 24000 rpm
Max Torque 5.6 ft-lbf @ 10000 rpm 7.6 Nm @ 10000 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper ISO30 ISO30
Table S.A.E METRIC
Length 157.5 in 4000 mm
Width 78.7 in 2000 mm
Max Weight on Table (evenly distributed) 7716 lb 4000 kg
Between Columns 82.1 in 2084 mm
Feedrates S.A.E METRIC
Max Cutting 394 ipm 10.0 m/min
Rapids on X 1772 ipm 45.0 m/min
Rapids on Y 1772 ipm 45.0 m/min
Rapids on Z 591 ipm 15.0 m/min
Axis Motors S.A.E METRIC
Drive Type Servomotor Servomotor
Max Thrust X 900 lbf 4004 N
Max Thrust Y 450 lbf 2002 N
Max Thrust Z 1215 lbf 5406 N
Tool Changer S.A.E METRIC
Type Linear Rack Linear Rack
Capacity 8 8
Max Tool Diameter (full) 2.0 in 50 mm
Max Tool Weight 22.0 lb 10.0 kg
Spindle Speed 24000 rpm 24000 rpm
Spindle Power 10.0 hp 7.5 kW
Full Load Amps (3 Phase) - Low 38 A 38 A
Weight 4497 lb 2040.0 kg
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
Build & Price
Get Started
Need More Information?
