40/50-Taper Spindle - Hubbed Encoder - Replacement - AD0182
Service Home How To Procedures 40/50-Taper Spindle - Hubbed Encoder - Replacement - AD0182
Recently Updated Last updated: 10/14/2025
AD0182
Applies to machines built from: February, 2008
- Jump to Section - 1. Introduction 2. Parts Required 3. 40-Taper Spindle - Hubbed Encoder - Replacement (5 steps) 4. 50-Taper Spindle - Hubbed Encoder - Replacement (5 steps) 5. 40/50 - Taper Spindle - Hubbed Encoder - Adjustment (5 steps) Back to Top
This procedure tells you how to remove and install a encoder with a hub. Perform this procedure on VMCs and HMCs with a 40-taper or 50-taper hubbed spindle encoder.
Do not perform this procedure for an encoder with a shaft. If you have an optical encoder with a shaft refer to the 40/50-Taper Spindle - Optical Encoder Replacement.
Parts Required
  • P/N 93-1902 HAAS MAGNETIC ENCODER - NEW WING
Press [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the spindle head covers as necessary.
Remove the (3) screws [1] and the (3) washers [2] that attach the cover [3] of the encoder.
Remove the encoder cover.
Disconnect the encoder cable [4].
Loosen the (2) screws [1] on the collar clamp.
Remove the screw and small spacer [1] from the bracket. Remove the large spacer and washer [2].
Keep these for the installation.
Remove the encoder assembly from the motor shaft.
Remover the cover of the replacement encoder.
Attach the replacement encoder to the replacement bracket. Use the (2) screws.
Perform these steps in the opposite order to install the encoder assembly onto the motor shaft.
Remove the access panel to get access to the encoder.
Remove the (3) screws that attach the cover of the encoder.
Remove the (2) screws [1] that attach the encoder to the bracket.
Remove the ground cable [2].
Disconnect the encoder cable [3].
Remove the (2) screws [1] that attach the bracket [2] to the spindle motor.
Remove the bracket.
Discard the bracket.
Perform these steps in the opposite order to install the new encoder assembly onto the motor shaft.
If you have a 40-Taper Spindle:
Use a feeler gauge.
Measure the distance between the bracket and the washer.
The distance must be between 0.02"- 0.04" (0.5 mm - 1 mm).
If the distance is not correct:
  • Loosen the collar screws.
  • Move the encoder higher or lower on the shaft of the motor. This changes the distance.
  • Tighten the collar screws.
  • Measure the distance again.
  • Repeat the steps above until distance is correct.
Tighten the encoder bracket screw.
If you have a 50-Taper Spindle:
Use a feeler gauge.
Measure the space in the wing as shown. [1].
Tighten the encoder bracket screws.
Tighten the encoder screws.
Operate the spindle clockwise for 1 minute [1].
Look at the spindle motor load gauge [2].
The encoder is adjusted correctly if the value is less than 20%.
Repeat step 2 if the value is higher than 20%.
If the value is higher than 20%, make sure the encoder parameters are correct. Refer to Parameter Checker.
Operate the spindle at 25%, 50% and 100% [1] of maximum speed.
 Note: In this example the maximum speed is 7500 RPM.
Make sure the RPM in the program [1] is the same as the RPM in the display [2].
If these RPM values are not the same, make sure the encoder parameters are correct. Refer to Parameter Checker.
When the values are correct, make sure all the screws are correctly tightened.
Refer to the applicable spindle orientation procedure.
  • VMC - Side-Mount Tool Changer - Spindle Orientation Offset - Parameter 257
  • VMC - Umbrella Tool Changer - Spindle Orientation Offset - Parameter 257
