40-Taper - Gearbox - Installation Aid - AD0188
Service Home How To Procedures 40-Taper - Gearbox - Installation Aid - AD0188
Recently Updated Last updated: 10/10/2024
AD0188
Applies to machines built from: January, 1990
- Jump to Section - 1. Introduction 2. Installation (4 steps) 3. Parameter Setup 4. 40 Taper Gearbox Lubrication System Back to Top
Each Haas Factory replacement gear box has been fully tested before leaving the factory.  It is the installing agents responsibility to ensure the previous gearbox has been thoroughly and correctly trouble shot before installing the new replacement item.
Failure to ensure the root cause of the previous failure will result in damage to the newly installed components and will not be covered under Haas Warranty
Push [POWER OFF] .
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Before you install a replacement gearbox, you must find the type of sensors in the old gearbox. If the old gearbox has mechanical switches [1] and the replacement gearbox has proximity sensors [2] remove the mechanical switches from the old gearbox and install them on the replacement gearbox.
Refer to step 3.
NOTE: The gearbox with micro switches [3] is backwards compatible with gearbox that used mechanical or proximity sensors. Use adapter cable PN 33-1382 that comes with the gearbox to connect the micro switches to the terminal bracket.
Do this step if the old gearbox has mechanical switches [1] and you install  a replacement gearbox with proximity sensors.
  1. Remove the (4) bolts [3] from the oil tank [2].
  2. Remove the shift dampener [4].
  3. Transfer the mechanical switches [1] to the replacement gearbox.
If the mechanical switches [5] from the old gearbox look damaged:
  1. Disconnect the mechanical-switch cables [5] from the terminal bracket.
  2. Measure the resistance from the mechanical-switch cables. The open contact measurement should be 100 kOhms. The closed contact measurement should be between 0-3 Ohms.
Remove these parts and thoroughly inspect them before transferring to the replacement gearbox assembly:
  1. Transmission oil pump
  2. Solenoid pack and connector bracket
    Note: On CALM machines, the connector bracket is installed behind the spindle. The solenoid pack is in the CALM cabinet. Neither require removal.
  3. Spindle encoder
  4. Spindle drive belt
  5. High/low gear proximity sensors or mechanical switches
  6. Mid belt shield
Remove the shot pin orientation assembly, if it is installed, and install it on the replacement gearbox.
Refer to the chart below for other items to consider when replacing the gearbox.  Thoroughly clean and inspect all re-used items to ensure proper operation of the new gearbox assembly.
Components to check Action
Air Hose Install new
1/4" Air hoses for High/Low Gear Install new
Fan cable Inspect, re-use/replace on condition
High/Low gear cable Install new (Clean and check connectors)
OIl Flow/Pressure Cable Inspect, re-use/replace on condition
OIl Level Switch Cable Inspect, re-use/replace on condition
Encoder Cable Inspect, re-use/replace on condition
Fan Clean, Inspect, re-use/replace on condition
Spindle Encoder Inspect, re-use/replace on condition
Drive Belt(s) Inspect, re-use/replace on condition
Encoder Belt Inspect, re-use/replace on condition
Oil Pump Inspect, re-use/replace on condition
Flush oil lines and pump
Clean oil filter
High/Low Gear/ Pre-Charge/shot Pin valve  Install new for Non-CALM, Reuse for CALM
Shot pin Orientation assembly Inspect, re-use/replace on condition
Spindle Drive (Brushless) Vector Drive upgrade
Replace shift solenoid cables
Check and/or replace I/O
Verify parameters for Lincoln or Baldor vendor
Set parameter 75 (gear change speed) to zero
Spindle Drive (Brush) Replace cables
Check and/or replace I/O board
Spindle Drive - Troubleshooting Guide CHC
For further assistance on the spindle drive please reference the spindle drive troubleshooting guide.
If the encoder from the old gearbox is a belted encoder [2]:
  1. Remove the belted encoder [2] from the old gearbox.
  2. Install the belted encoder assembly [2] on the standoffs [1].
if the encode from the old gearbox is not a belted encoder [2], remove the standoff [1].  Move the encoder to the new gearbox.
If the air solenoid assembly has a 35-psi regulator [3] on the input side of the shift solenoid, remove it.  Replace the 35-psi air regulator [3] with the tee fitting [4].  On CALM machines, the air regulator [7] is in the CALM cabinet.
If the air solenoid assembly has an adjustable air regulator, set the air pressure to 80 psi.
Install the fitting [5] on the high-gear side of the air solenoid assembly.  Install the hose [6] from the air-over oil shifting assembly to the fitting [5].
Parameter Setup
Software Upgrade Information:
Upgrade M18.xx software to the latest M18.xx main software and Mocon software. Upgrade M17.xx software to the latest Mocon software. Do not update the main software.
Make sure these Parameters are correct:
  • Change Parameter 1305 to 3.
  • Change Parameter 1304 to 10.
  • Change Parameter 130 from 1000 to 1300.
  • Change Parameter 75 to 2 for software 9.08 or sooner
  • Change Parameter 75 to 30 for software 9.09 or later
This table applies to a 16DP-65T Gearbox: Part Numbers 93‑30‑9990B, 93‑30‑9991B, 93‑30‑9992B, 93‑30‑9993B, 93‑30‑9993C, 93‑30‑9994B, 93‑30‑9994C, 93‑30‑11022A, 93‑30‑11022B
Enter the value for Parameter 150 for your gearbox based on the spindle RPM and the values of the parameters listed:
16DP-65T Parameter 150 Chart
RPM Parameter 131: Parameter 183: Parameter 1287: Parameter 1288: Parameter 150:
5000 5000 16667 N/A N/A 1212
7500 7500 20000 N/A N/A 1818
8100 8100 26667 10000 10000 2424
8100 8100 21600 N/A N/A 1963
10000 10000 26667 10000 10000 2424
10000 10000 26667 N/A N/A 2424
The following table applies to the Paramters for Baldor/ABB Motor kits:
  • 93-4777 SPINDLE MTR 30T BELT 30K ABB
  • 93-4787 GBOX ASSY 16DP65T 40T VF, SERVICE ABB
  • 93-4788 SPNDL MTR 30K TBLK ABB-SERVICE
  • 93-4789 SPNDL MTR GR 5K 10HP TBK ABB
  • 93-4790 SER SPNDL MTR 10K TBLK ABB
  • 93-4791 SPNDL MTR 30K 5M TBLK ABB
  • 93-4792 GBOX ASSY 7.5/10K 16DP65T 30/10 VD/DEL ABB
  • 93-4793 GBOX ASSY HS 10HP VD 16DP65T ABB
Change parameters 180 and 181 to the following values:
Motor Configuration Parameter Value
WYE/DELTA
or
Fixed WYE
180
180 * Par183 / 26667
Note: See example below
181 38
Fixed DELTA
and
40HP Vector Drive
180
150 * Par183 / 26667
181 37
Example for Parameter 180:
Parameter 180 = 180 * (Parameter 183 / 26667)
So if Parameter 183 on the machine = 25000, Parameter 180 for Baldor/ABB = 168.74, so round up to 169.
The video shows how the 40 Taper Gearbox lubrication system works.
