    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Fixture Clamps
      • Toolmakers Vise
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Plug & Ring Gauges
      • Gauge Blocks & Accessories
      • Pin Gauges & Accessories
      • Test Bars
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Spindle Drive - Troubleshooting Guide - CHC
Service Home Spindle Drive - Troubleshooting Guide - CHC
Recently Updated Last updated: 08/24/2022
Jump to Section 1. Introduction 2. Symptom Table 3. Alarm 123 SPINDLE DRIVE FAULT 4. Alarm 149 SPINDLE TURNING. Alarm 186 SPINDLE NOT TURNING. 5. The spindle did not orientate correctly. 6. The spindle speed is incorrect. 7. mechanical problem with the spindle or the motor 8. The speeds and feeds are incorrect. The tools are dull. Back to Top
Prior to the implementation of the Haas Vector Drive, Haas Automation used variable frequency drive from a number of drive manufacturers such as Fuji, Mitsubishi, Magnatek and Yaskawa. Spindle Drives used in Haas machinery are variable frequency motor controllers. They vary the frequency and voltage to operate the electric motors.
The MOTIF PCB sends spindle speed commands to the spindle drive. The I/O PCB sends directional commands to the spindle drive. The spindle drive sends (3) signals to the I/O PCB. It will send a Spindle Stop, Spindle at Speed, or a Fault Signal command.
Symptom Possible Cause Corrective Action Section
Alarm 123 SPINDLE DRIVE FAULT There are multiple possibilities. Check the error code on the drive for the cause and the corrective action. 1
Alarm 149 SPINDLE TURNING The spindle speed is not at zero during a tool change. Use the diagnostic data to identify and address the fault. 2
Alarm 186 SPINDLE NOT TURNING The spindle does not turn when commanded to.
Alarm 116 SPINDLE ORIENTATION FAULT The spindle did not orientate correctly. Inspect the orientation ring/shot pin assembly. 3
The spindle speed is incorrect. The signal from the control is incorrect or bad. Check the command voltage. 4
The spindle load is too high. There is a mechanical problem with the spindle or the motor. Check that the spindle turns freely. 5
The tools are dull. Replace the dull tools. 6
Corrective Action:
Check the spindle drive display for an error code. Refer to (1) of these manuals for the cause and the corrective action.
  • Mitsubishi A200
  • Yaskawa GPD 503 Technical Manual
  • Yaskawa GPD 515 Manual
NOTE: A missing jumper can cause a 123 Spindle Drive Fault,  for example some motors may not have an overheat sensor in this case the 500 cable must have a jumper.
Possible Cause: The spindle speed is not at zero during a tool change. The spindle does not turn when commanded to.
Corrective Action:
Check the following inputs on the diagnostic page of the Haas control.
If the bit does not change when they are supposed to, jump the connector at P21 on the I/O PCB:
  1. Jump RED to GRN: The input "SP ST*Spindle Not Stopped" should change.
  2. Jump WHT to GRN: The input "SP AT* Spindle Not At Speed" should change.
If the bit changed after you jumped the P21 connector on the I/O PCB, the cable or spindle drive is at fault.
If the bit did not change after you jumped the P21 connector,  refer to the Classic Haas Control - I/O PCB - Troubleshooting Guide
Field Spindle is Stopped Spindle is Not Stopped
SP ST*Spindle Not Stopped 0 1
SP AT* Spindle Not At Speed 1 0
Corrective Action:
Decrease the values of Parameter 73 SP HIGH G/MIN SPEED and Parameter 74 SP LOW G/MIN SPEED to slow the orientation speed. The spindle will orient easier in high gear than it will in low gear and the machine can be programmed for this.
Inspect the orientation ring [1] and shot pin assembly [2] for damage.
Verify the operation of the mechanical roller switch and solenoid.
Possible Cause: The signal from the control is incorrect or bad.
Corrective Action:
Check the voltage of the speed command. The speed command for the spindle drive is sent by the 720 cable from P16 on the Motif or the Mocon. When the maximum rpm for the spindle is commanded you should measure 10 VDC across the 720 cable at the drive and P16 at the Motif or the Mocon.
Check 720 cable connections. Make sure they are not loose and make good contact.
If the voltage is correct, verify if the spindle drive parameters are correct. Refer to the Magnatek & Mitsubishi SP Drive Programming Manual.
Possible Cause: There is a mechanical problem with the spindle or the motor.
Corrective Action:
Check if the spindle and motor turn freely by hand. Check for a short to ground in the spindle motor. Refer to the Spindle Motor - Troubleshooting Guide.
Corrective Action:
Check the program for the application and the tool path.
Check for dull or damaged tools. Replace tools as needed.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
