50-Taper - TRP - O-Ring - Rebuild Kit - AD0219
Service Home How To Procedures 50-Taper - TRP - O-Ring - Rebuild Kit - AD0219
Recently Updated Last updated: 11/30/2018
AD0219
Applies to machines built from: June, 2007
- Jump to Section - 1. Introduction (1 step) 2. Install Rebuild Kit (6 steps) Back to Top
This procedure tells you how to rebuild your 50-taper Tool Release Piston (TRP). The o-rings supply air-tight seals for the components of the TRP. Worn o-rings can cause a decrease in the air pressure that pushes the TRP pistons. A decrease in the air pressure can cause the TRP to push with less force. Replace the o-rings to prevent incorrect TRP operation.
Operation:
  1. The tool release button is pushed. High pressure air comes into the TRP.
  2. Air goes into the housing and pushes down on the pistons.
  3. The pistons push down on the shaft to release the tool.
  4. The spring forces the shaft to retract after the air is removed.
  5. Some TRP models have an additional air input to help the shaft retract.
P/N: 93-2315 TRP 50T 9DIA REBUILD SERVICE KIT
[A] 20-0015 QTY: 1
FORK LIFT SPINDLE
[B] 20-6581 QTY: 1
SHAFT TRP 50T, 9 IN PISTON
[C] 57-0018 QTY: 2
ORING, 2-446 BUNA PARKER 2-446N67
[D] 57-0027 QTY: 4
ORING, 2-121 BUNA
[E] 57-0095 QTY: 3
ORING, 2-327 VITON
[F] 59-1494 QTY: 1
SPRING COMPRESSION 50T TRP, 9 IN PISTON
99-4521A ELECTRICAL GREASE 5.3 OZ
P/N: 93-2628 TRP 50T 9DIA LP FORK REBUILD KIT
[A] 20-6962 QTY: 1
TRP FORK 50T
[B] 20-6581 QTY: 1
[C] 57-0018 QTY: 2
[D] 57-0027 QTY: 4
ORING, 2-121 BUNA
[E] 57-0095 QTY: 3
ORING, 2-327 VITON
[F] 59-1494 QTY: 1
P/N: 93-2316 TRP 50T 10DIA REBUILD SERVICE KIT
[A] 20-0015 QTY: 1
FORK LIFT SPINDLE
[B] 20-0018A QTY: 1
SHAFT, TOOL RELEASE PISTON 50T
[C] 57-0082 QTY: 2
ORING, 2-448 VITON
[D] 57-0027 QTY: 4
ORING, 2-121 BUNA
[E] 57-0095 QTY: 3
ORING, 2-327 VITON
[F] 59-0049 QTY: 1
SPRING COMPRESSION 2.343OD 1.843ID 3.000L 153LB
Install Rebuild Kit
The illustration shows these configurations:
  • Through-Spindle Coolant (TSC) [A]
  • No TSC [B]
Keep the shims [1].
Disassemble as shown.
Clean parts shown.
Apply a thick layer of grease to:
  • the o-rings
  • the inner diameter of the housing walls
  • the outer diameter of the spacers
Do not use too much grease.
Install the new o-rings in the opposite sequence of step 3.
Use the shims [1] removed in step 2.
Torque the 1/2-13 socket head cap screws (SHCS) [2] to 80 ft-lb (108 Nm).
Torque the 3/8-16 SHCS [3] (9" piston) to 45 ft-lb (61 Nm).
Torque the 1/2-13 SHCS [3] (10" piston) to 80 ft-lb (108 Nm).
  • TSC [A]
  • No TSC [B]
For TSC, apply a drop of red Loctite to the shaft threads. Torque the bearing holder [1] to 100 ft-lb (136 Nm).
For non-TSC, tighten the shaft collar [2] completely on the shaft. Torque the collar screw to 10 ft-lb (14 Nm).
