ST-30/35 Sub-Spindle Motor Replacement - AD0739
Service Home How To Procedures ST-30/35 Sub-Spindle Motor Replacement - AD0739
Recently Updated Last updated: 01/10/2024
ST-30/35 - Sub-Spindle Motor - Replacement
AD0739
- Jump to Section - 1. Introduction 2. Motor Removal (3 steps) 3. Install New Motor (4 steps) Back to Top
This procedure shows how to replace the sub-spindle motor on ST-30/35 machines. This applies to the following service kits:
93-3609
This kit contains the following parts:
  1.  6K RPM Servo Motor
  2.  Drive Sprocket Flanges
  3.  28T Drive Sprocket
IMPORTANT: This kit is for ST-30/35 reboot machines only.
Motor Removal
CAUTION: Press [EMERGENCY STOP] and then Push [POWER OFF] before working on the machine.
Set the main circuit breaker to the OFF position.
Remove the right enclosure panel [1] and so that you can access the sub-spindle motor. Remove the sub-spindle back cover [2] and motor shroud [3] Disconnect all cables from the servo motor [4].
NOTE: The right side access panel [1] is shown in the image. Other enclosure panels may need to be removed for easier access.
Remove the 4 SHCS [1] so that the existing servo motor can be uninstalled from the motor mounting plate [2]. Once the motor is removed, make sure the drive belt [3] is sitting properly on the spindle sprocket and is hanging as shown so that it can be tensioned properly onto the new motor.
NOTE: When removing the motor, make sure to slide the drive belt off the sprocket attached to the motor shaft.
NOTE: Make sure to keep the 4 SHCS since they will be used to fasten the new motor in place.
Install New Motor
Fasten the new motor to the motor plate [2] using the 4 Socket Head Cap Screws [1]. When fastening to the motor plate, make sure to loop the drive belt [3] around the motor drive sprocket [4]. Manually pull the drive belt to verify that it is sitting properly on the sprockets.
NOTE: The bottom view of the picture shows how the motor and drive belt should look like from inside of the sub-spindle casting.
Torque the 4 mounting SHCS [1] to the motor mount plate. Check the drive belt [3] tension using the Gates Sonic Meter [5]. The sub-spindle drive belt should be tensioned to 183N-227N.
To adjust the tension of the belt, untorque the 4 SHCS [2] that mount the motor plate to the sub-spindle casting. Then adjust the CAM alignment bolts [4] until the belt is at the correct tension. Make sure to torque the motor plate mounting SHCS [2] after the belt tension is within specification.
NOTE: For more details on how to use the Gates Sonic Meter tool, refer to the SPINDLE TENSION ADJUSTMENT - AD0710.
Run the Sub-spindle to verify that it is working properly.
Refer to the Lathe Operators manual for more details.
Reinstall the sub-spindle motor shroud [1] by fastening the 4 SHCS [2] to the mounting surface of the sub-spindle casting [3]. Fasten the sub-spindle back cover [4] with the SHCS [5]. Also, reinstall any sheet metal that was removed to gain access to the sub-spindle assembly.
