Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter - Lathe - AD0710
Service Home How To Procedures Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter - Lathe - AD0710
Recently Updated Last updated: 10/10/2024
AD0710
- Jump to Section - 1. Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (2 steps) 2. SL/ST/DS - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (5 steps) 3. TL - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (5 steps) 4. Office Lathe - Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter (3 steps) Back to Top
Change the units to lbf, as follows:
  • With the unit powered off, hold [0] and [9] and push [POWER] at the same time [1]. The unit will turn on with the current units displayed.
  • Push [SELECT]until the display shows lbf.
  • Hold [POWER] until the power goes off.
  • Push [POWER] again to start the meter in normal operation.
To display frequency in Hz, push [HZ] [2] repeatedly until the display shows Hz [3].
Push [MASS] [1].
Reference the Lathe - Spindle Belt Tension Specifications Document for updated belt tension values and settings.
Enter the correct values from the Mass, Width, and Span columns in the table from the reference above. For example, for an ST-10, push this sequence: 0, 0, 5, 5. This sets the value to 5.5 for the mass.
Loosen the (4) motor mount screws [1].
Turn the (2) belt tension screws equally until tension is in the belt.
Use your hand to tighten the motor mount fasteners.
 Note: The illustration shows the belt tension screws for an ST-20. The location of the belt tension screws for SL and other ST lathes are different.
Attach the sensor cable to the Gates sonic tension meter.
Push this button sequence on the Gates sonic tension meter:
  1. Push [POWER].
  2. Push [MEASURE].
Place the sensor approximately 3/8 in (1 cm) away from the belt. Quickly pull your finger across the edge of the belt ("Pluck" the belt like a guitar string). Do not let the sensor touch the belt.
 Note: If you cannot make the necessary vibration with your finger, you can tap the belt with the handle of a screwdriver.
Compare the "Tension" value from the table to the value on the meter.
If the tension is too low, use the belt tension screws to tighten the belt.
If the tension is too high, use the belt tension screws to loosen the belt.
Measure the tension again, and make adjustments until the belt tension is correct.
Torque the motor mount screws. Refer to Haas Fastener Torque Specifications. Use the values for steel.
Loosen the (3) screws [1] on the plate that holds the motor.
Push down on the plate until the belt has tension.
Use your hand to tighten the (3) screws for plate.
  1. Push [POWER].
  2. Push [MEASURE].
If the lathe is a TL-3 or TL-4, go to Step 5.
For TL-1 or TL-2 lathes:
  • Find the 2 adjustment openings. Put a crowbar in one of the openings.
  • If the tension is too low, push the plate down.
  • If the tension is too high, lift the plate up.
  • Measure the tension again. Adjust the plate until the belt tension is correct.
For TL-3 or TL-4 lathes:
  • Put a jack under the plate that holds the motor.
 Caution: Make sure the jack lightly touches the plate. If the jack pushes on the plate, this can damage the motor.
  • Find the (2) adjustment openings and put a crowbar in one of the openings.
    • If the tension is too high, decrease the hieght of the the jack.
    • If the tension is too high, increase the height of the jack.
    • Measure the tension again. Make adjustments until the belt tension is correct.
Torque the (3) motor mount screws. Refer to Haas Fastener Torque Specifications. Use the values for steel.
Loosen the (6) screws [1] for the plate that holds the motor.
Push the plate to the right until the belt has tension.
Use your fingers to tighten (6) screws [1].
  1. Push [POWER].
  2. Push [MEASURE].
If the tension is too low, push the plate to the right.
If the tension is too high, push the plate to the left.
Torque the (6) screws for the plate that holds the motor. Refer to Haas Fastener Torque Specifications. Use the value for steel.
82˚ Point Angle Countersink, 25mm Maximum Diameter x 10mm Shank, 3 Flute, Uncoated $54.95 $0
5C 28mm Smooth Round Collet $19.95 $10.97
DNMG432-HML / DNMG150408-HML, Carbide Turning Insert, 55° Rhombic, Grade HTP15 - Pack of 5 $34.95 $26.97
60° Indexable Chamfer Mill, 1.25 in \ 1-1/4" - 2.04" Diameter x 3/4" Shank x 4" Overall Length, 3 Inserts $136.95 $116.97
