Bijur - Mechanical - Oil Pump - Replacement - AD0207
Service Home How To Procedures Bijur - Mechanical - Oil Pump - Replacement - AD0207
- Jump to Section - 1. Introduction (1 step) 2. Removal and Installation (5 steps) 3. Parameter 117 Adjustment Back to Top
Recently Updated Last updated: 05/19/2025
AD0207
Revision A - 5/2025
This procedures is applicable if your Bijur mechanical oil pump has one of the following features:
  • The oil pump is in the air and lubrication panel under the machine enclosure.
  • No drip-sight glass
  • 1 drip-sight glass
  • 2 drip-sight glasses
Parts Required: P/N 93-1195 Lube Oil Tank
Remove the cover [1] for the lubrication panel.
Remove the (2) screws that attach the cable tray [2]. Remove the cable tray [3].
 Note: The air and lubrication lines are removed from the image for clarity.
Disconnect the (3) cables [1] with these labels:
  1. LUBE PUMP
  2. LOW LUBE
  3. OIL PRES
Unscrew the nut [3] that attaches the conduit [4] to the panel. Remove the nut [3].
Disconnect the tube [1] that comes out of the oil filter. Unscrew the fitting [3] where it attaches to the fitting assembly [2].
Remove the screws that attach the oil pump to the panel. Remove the pump.
Do these steps in reverse order to install the pump assembly.
Fill the tank to the MAX fill line [1].
 Note: To prevent build up of contamination, use Mobil SHC 625, Mobil 1 5W-20, or Mobil 1 10W-30. Do not use Mobil Vactra #2.
 Note: You must fill the reservoir tank to the fill line [1] each time you fill the tank. This makes sure the dip trough [2] is full of oil. This lubricates the drive and worm gears [3] of the pump.
There are two motors which have a rated rpm of 1.2 and 1.4 respectively. This is indicated on the motors label [1].
Enter service mode to change the following.
Parameter 117 will have to be altered for each of these rated speeds.
1.2 RPM Motor: 90000
1.4 RPM Motor: 75000
Bijur - Mechanical - Oil Pump - Test
Lift the plunger to hand-prime the pump until the pressure reads approximately 20 psi (1.38 bar).
 Note: If the lever arm [1] pushes up on the plunger, you cannot hand-prime the pump. Operate the spindle up to 30 minutes for the next pump cycle to complete.
In MDI mode, command the spindle to run at low speed, for example, 5 RPM.
This turns on the oil pump motor.
Stop the spindle when the lever arm drops.
Disconnect the oil feed tube [1] from the fitting [3] above the canister filter.
Pull up on the plunger [2].
Oil comes out of the fitting [3] when the pump operates correctly.
Connect the oil feed tube.
If no oil comes out of the fitting, refer to Mechanical Bijur Lube Pump Troubleshooting Guide.
In MDI mode, command the spindle to run at a low speed, for example, 5 RPM.
 Note: The Bijur mechanical pump takes approximately 30 minutes to complete a cycle.
Look at the oil pressure gauge when the plunger drops.
The oil pressure gauge shows 20 to 40 psi (1.38 - 2.75 bar). The pressure gradually decreases to 0 psi (0.0 bar) in 3-10 minutes.
