EC-400 - 4th Axis Receiver Rebuild
Service Home How To Procedures EC-400 - 4th Axis Receiver Rebuild
- Jump to Section - 1. Introduction 2. EC-400 4th Axis Receiver Rebuild (5 steps) Back to Top
Recently Updated Last updated: 07/31/2025
Revision A - 07/2025
This procedure applies to the reboot EC-400 & 500's 4th Axis assemblies that were built before 5/2022.
Refer to the EC IDENTIFICATION DOCUMENT for assistance on determining if the machine is a reboot machine.
For the newer machines that were built after 5/2022 or are upgrading to the new design using 93-3465 PALLET RECEIVER & CLAMP ASSY EC-400/500 please refer to Pallet Receiver & Clamp Assy EC-400/500 - Installation
NOTE: Contact Haas Service for additional information regarding the upgrade to the new design.
Turn off the main breaker for the HPU. Manually activate the unclamp/clamp solenoids to relieve any pressure from the system.
Unbolt and lower the sensor/anti-rotation bracket [1]. Remove the snap ring [2] from the shaft. Lower the block [3] off the shaft.
Install jack bolts [4] under the clamp plate to prevent damage to the piston quad-ring.
Remove the (8) bolts [5] from the receiver.
Install (2) eyebolts in the clamp plate. Use an appropriate lifting strap to raise the receiver from the rotary.
Note: Hydraulic oil will leak out when the receiver is lifted.
Remove the jack bolts then remove the clamp plate [1].
Pull the shaft [2] out of the receiver housing [3]. The clamp springs [4] may fall out of their location.
Remove the lock nut [5] and piston [6] from the shaft.
Replace the o-ring [7] and quad-ring [8] on the piston.
Replace the quad-ring [9] and o-ring [10] in the receiver housing.
Lube all o-rings and quad-rings with hydraulic oil.
Install the piston [6] on the shaft [2]. Tighten the locknut [5] to 100 ft-lbs.
Note: You can install the clamp plate [1] on the shaft and hold the assembly by the clamp plate in a vise to loosen/tighten the lock nut.
Support the shaft vertically. Install the clamp springs on the piston. Lower the receiver housing onto the shaft. Install the clamp plate and use the jack bolts to raise the clamp plate until the piston is fully seated into the housing.
With the jack bolt [1] in place, lower the receiver onto the rotary body. Make sure the new O-ring stays in place under the receiver as its lowered into position. Hand tighten the (8) receiver bolts [2].
Install the rotary union block [3] onto the shaft and install the snap ring [4].
Install the sensor/anti-rotation bracket [5]. Apply a light layor of grease the pin.
Use a mag base and indicator to measure the runout of the receiver.
Place the indicator tip on the keys as shown in the image [1]
Rotate the rotary and center the cap to .001 in (0.025 mm) T.I.R.
Torque the bolts to 80 ft lbs and re-indicate the cap to verify the alignment.
Verify the B Axis TC Offset in the next step.
Zero return the B Axis, set the Grid Offset (press B + F4 while on the parameter page in service mode.)
Handle jog the rotary until the arrow on the pallet is pointing towards the spindle.
Mount a mag base with indicator on the spindle. Jog the X Axis and indicate the face of the pallet. Handle jog the rotary until the face is parallel to X Axis is within 0.002".
While on the parameter page in service mode, press B + F2 to set the TC Offset.
Command a pallet change to verify that the B and Z axis TC Offsets are set correctly.
