Zero Point Ready - UMC Installation - AD0765
Service Home How To Procedures Zero Point Ready - UMC Installation - AD0765
4.2 UMC Single Zero Point Installation
Recently Updated Last updated: 03/16/2026
Single Zero Point Ready - Installation - UMC
AD0765
Revision B - 06/2026
Updated
The single zero point ready installation only needs to be done on machines that are ordering the RPL-25KG to be added to an existing machine.
Note: For machines purchased with an RPL-25KG, the single zero point ready is already installed on the machine. Skip this section if the machine already has the single zero point ready kit installed.
  • 93-1001315 - Single Zero Point Ready Kit UMC-500
  • 93-1001316 - Single Zero Point Ready Kit UMC-750
  • 93-1001317 - Single Zero Point Ready Kit UMC-1000
The corresponding machine kit below will also need to be ordered to be able to do this procedure:
  • 93-1001320 - RPL-25KG READY KIT UMC-500
  • 93-1001321 - RPL-25KG READY KIT UMC-750
  • 93-1001322 - RPL-25KG READY KIT UMC-1000
The purpose of the single zero point ready kit is to allow for the pneumatics to be routed to the single zero point clamp through the body of the tilt rotary. Installing this involves removing the platter and rotating the machine B-axis. Make sure this is possible before starting this procedure.
Note: The Robot Pallet Loader option also requires an auto window option to be installed. Refer to the UMC Auto Window - Installation - AD0663 to order and install this option on your machine.
Note: The only difference between these kits is the bottom cover panel for the TRT body on the different size machines.
UMC Zero Point Ready - Installation
Start by assembling the pneumatic manifold [1] that goes inside the C-body of the machine.
Tighten the NPT 1/4" plug fitting [2] to the single port.
Tighten the 2 Brass 1/4" fittings [3] to the angled ports.
Tighten the 2 ORB6M NPT 1/4" steel fittings [4].
Install the 4 O-Ring 2-212 [5] into the grooves of the manifold.
Note: Install the four O-rings into alternating grooves on the top face of the manifold block, leaving one empty groove between each installed O-ring.
Connect the 3 Port Rotary Union Shaft to the 3 Port Rotary Union Shaft Extension using [2] SHCS 1/4-20 X 5/8 make sure the O-Ring 2-011 [1] are seated in the cavities of the shaft.
Torque the bolts to their required specs.
Press the dowel pin [1] into the anti-rotation block [2] until it bottoms out.
Assemble the platter coupler [3] by placing the O-rings in position.
Place 3 of the 2-011 O-Rings [1] on the air ports shown in the image.
Place the larger 2-031 O-Ring [2] onto the middle groove of the coupler.
Rotate the B-axis +90 degrees and remove the cover [1]. Return the B-axis to its original position at 0 degrees.
This cover will be replaced by the cover included in the zero point ready field install kit.
Updated
Remove the platter by following the removal section of the UMC C-Axis Platter Replacement linked below.
 WARNING: IF YOU DO NOT DEPRESSURIZE THE SYSTEM BEFORE REMOVING THE PLATTER YOU CAN PERMANENTLY DAMAGE THE BRAKE BY REMOVING THE PLATTER.
Note: Take note of the platter orientation before removing to make sure to install the platter in the same orientation later on.
UMC Rotary Unit – Weight Reference Guide
Updated
Place the platter on a bench and bolt the coupler [1] to the platter using SHCS 1/4-20 X 5/8 [2].
While the platter is on the bench insert the felt strip included in the kit in the groove [3]
NOTE: If the UMC is not exchanging platters reuse the felt strip already in the groove.
Updated
When using the same platter:
The height measurement between the top of the platter and the top of the coupler needs to be taken to ensure proper fitment of the workholding spud.
Use a depth micrometer to measure between the two surfaces. The measurement should be 0.7000 ± .0010" for machines built before 5/22/2026 and 0.7560 ± .0010" for machines built after 5/22/2026 [1].
Note: The measurement is taken without the seal.
Install shims P/N 59-2350 and 59-2351 as needed to achieve proper workholding height. The shims are installed between the workholding and the platter face [2].
Install the coupler onto the shaft assembly [1] by using 1/4-20 X 1 1/4 bolts [3]. Make sure the O-Rings 2-011 [2] are in the cavaties of the shaft and not where the bolts attach.
Install the coupler and platter assembly [2] back onto the rotary using M12 bolts [1].
Tighten the bolts, but do not torque them down yet.
Follow the installation section of the UMC C-Axis Platter Replacement linked below for the full instruction on how to correctly re-install the platter.
The Zero point receiver will come assembled. Depending on the machine type, the receiver can have different features.
UMC-500:
  • Zero Point Receiver Assembly has no spacer plate [2] as shown in the left image.
UMC-750/1000:
  • Zero Point Receiver Assembly has a spacer plate [2] between the platter [1] and receiver [3] as shown in the right image.
Note: The zero point receivers come assembled. The steps below can be referenced to ensure the assembly includes all the needed components and that the receiver is compatible with the machine.
Turn the clamp assembly upside down.
Use dielectric grease to install the 3 O-rings onto the clamp assembly.
Install the smallest O-ring on the clamp port [1].
Install the large O-ring [2] and the medium O-ring [3] onto the clamp assembly as shown in the image.
13
Install the clamp assembly [1] onto the zero point receiver [2].
Make sure that the clamp port [3] is aligned with the port on the pallet receiver plate [4].
Note: If the clamp port is not aligned, the zero point will not clamp/unclamp properly.
14
Place the alignment keys on the pallet receiver plate [3] and the platter spacer plate [4].
Fasten the alignment key [1] to the plates using the 2 M6 x 1 x 12MM SHCS [2]
Note: The platter space plate [4] is only on UMC-750 and UMC-1000 machines. UMC-500 machines do not need the spacer plate shown in the image.
Assemble the pallet receiver that will be installed on the platter.
Important: Place the 3 O-Rings [5] in the receiver plate.
Note: The platter space plate [3] is only on UMC-750 and UMC-1000 machines. UMC-500 machines do not need the spacer plate shown in the image.
Fasten the receiver spud [1] to the pallet spacer plate [2] and the receiver plate [3] using the 3 M6 x 55mm SHCS [4].
Note: Make sure that the platter spacer and receiver plate are oriented the same direction. The alignment keys installed in the previous step will help this alignment.
16
Place 3 2-011 O-Rings into the top of the coupler through the center bore in the platter.
Then install the pallet receiver and spud assembled in the previous step to the platter.
The receiver is held in position by 4 T-nuts that are placed in the T-slots of the platter.
Use the 4 SHCS [3] to fasten the pallet receiver [2] to the T-nuts [1].
Note: The spud is not shown in the image but should be located into the center bore in the platter. The spud must be assembled to the pallet receiver [2] before the receiver is fastened to the platter.
17
Rotate the B-axis 90 degrees [1].
18
Attach the anti-rotation block [3] to the gearbox using the M6 bolts [4].
If the read head is in configuration [1] you will need to clock it to position [2]  this will require you to redo the compensations on the machine.
If the read head is in configuration [2] the compensations will not need to be redone.
Please contact service about borrowing a swivel checker.
19
Install the manifold assembly [2] from step 1 by inserting the anti-rotation dowel pin [1] into the pneumatic manifold.
20
After installing the shaft assembly to the pneumatic manifold make sure to install the snap ring [2] to the shaft groove [1].
Note: If the groove for the snap ring is not visible on the shaft, then some bolts may not be fully tightened, or the dowel pin needs to be pressed further into the manifold.
21
Install the foot pedal cable [1] to P14 on the I/O board.
From there route the cable to the hole of the front skirt of the machine.
Connect the foot pedal to the cable [1] coming from the front skirt of the machine.
Note: If there is already a foot pedal cable connected to P14 make sure it is cable 32-1303. This has additional cables going to P14 for the robot load station.
Lube Panel - Installation
Close the air valve [1] at the bottom of the lube cabinet.
Bleed the remaining air out of the manifold by pulling on the air release [2]. Make sure the gauge on the manifold reads zero.
Install the elbow fitting [1] directly into the air manifold on the front face as shown in the image.
Install the Air Booster on the back of the machine using the magnets to attach it.
Hose and Cable Routing
Route the zero point air lines through the black conduit that routes through the center bore and to the work holding manifold.
Route the opposite ends of the zero point air lines [1] to the Air Booster.
Note: Make sure the hoses for the zero point are high pressure hoses.
Pull the hoses through the B-axis body and to the pneumatic manifold as shown.
Use the velcro-ties [1] and cable clamps to neatly route the cables to the pneumatic manifold.
The unclamp hose denoted in green  [1] goes the fittings as shown.
The clamp hose denoted in red [2] is goes to the fitting as shown.
Connect the green hose to the unclamp port [1] of the solenoid denoted with a green zip tie on it.
Connect the red hose to the clamp port [2] of the solenoid denoted with a red zip tie on it.
Connect the air booster to the manifold [1] using the included HOSE 1/4 OD PE RED HIGH PRESSURE.
This step is for non-CAN lube panel machines only:
Connect cable 33-1532 - Air Lube Solenoid cable to P35 on the IO PCB with the connector with the pigtail for Pallet Unclamp [16].
Route the cable to the lube panel to make the following connections to all the solenoid power cables. The color for each connector is listed:
[2] PulseJet Solenoid - White and Violet
[3] Auto Door  - Gray
[4] TRP Unclamp  - Yellow and Black
[5] Spindle Air - Violet
[6] Spindle Lube - White
[7] Min Lube Grease - White and Red
[8] Open Door Interlock - White and Brown
[9] Auto Air Gun (AAG) - Red
[10] TSC Purge - White and Orange and Yellow jumper to TAB Air [15]
[11] SMTC Pocket U/D - White and Black
[12] UMC Auto Window - White and Yellow
[13] Purge Solenoid - White and Gray
[14] Pallet Air Blast - White and Green
[15] Tool Air Blast Air (TAB) Yellow jumper from TSC Purge [10]
Connect cable 33-1307 CBL AIR VISE PRESS SWS PP ROBOT 21FT to the pressure sensor as shown.
Route the cable back to the I/O board and plug this into P13 using the adapter cable provided in the kit.
Note: The pressure sensor should be on the fitting where the red hose is connected. This sensor makes sure the zero point is clamped.
Connect cable 33-1306 to P36 [5] on the IO PCB. Connect the coolant refill to the pigtail if needed.
Route the other end directly to the Air Booster.
Connect the V-1 end [1] to the solenoid going to the zero point in the machine [4].
Connect the V-2 end [2] to the solenoid going to the load station zero point [3].
Re-introduce air to the manifold by turning the valve [1].
Check for leaks and tighten fittings as needed.
Reinstall the new cover [2] and return the rotary [1] to 0 degrees on the B axis.
Update Configuration Files
If this is a field installation, the configuration file will need to be updated to implement the necessary parameters.
Visit HBC.HAASCNC.COM to download the latest configuration file.
Note: Only Haas Certified Service technicians can log into this website.
Load the configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Zero Point Receiver - MRZP
After installing the Zero Point Receiver, MRZP needs to be done to account for the change in pallet height compared to the platter.
Assemble the zero point MRZP pallet [1].
Press the dowel pin [2] into the MRZP pallet.
Install the zero point pull stud [3] using the M10x20 SHCS [4].
Mount the MRZP artifact [5] to the zero point MRZP pallet using the 2 SHCS [6].
Go to the Recovery Page. Press [F2] [1] to unclamp the zero point pallet receiver [2] inside the machine.
Place the MRZP pallet assembly [3] with the artifact in the receiver. Make sure the dowel pin is aligned in the correct position.
Clamp the zero point receiver by pressing [F2] again.
Exit recovery and continue with doing MRZP. Refer to the UMC - MRZP and Safe zones page for more information on how to do MRZP.
Note: The center bore in the zero point calibration pallet can also be used for probing. The diameter of the center bore is 2 inches.
Zero Point Ready - Testing
To test the clamp and unclamp of the zero point ready kit go to the Pallet Changer Recovery page.
Press [F2] [1] to unclamp the zero point pallet.
Place a pallet [2] into the zero point receiver [3].
Note: Make sure that pallet is oriented correctly so that the dowel pin aligns with the zero point receiver.
Press [F2] again to clamp the zero point pallet.
Verify that the pallet is clamped to the receiver and that no alarms are generated.
