30T/40T Spindle Motor - Troubleshooting Guide - NGC - TG0010
Service Home 30T/40T Spindle Motor - Troubleshooting Guide - NGC - TG0010
- Jump to Cause - Back to Top
10.2 3oT/40T Spindle Motor - Troubleshooting
Recently Updated Last updated: 12/12/2025
30T/40T - Spindle Motor - Troubleshooting Guide - NGC
TG0010
Revision C - 04/2026
  1. Drive shaft
  2. Power leads
  3. Built-in Spindle Motor Overheat switch connector
  4. Spindle Motor Overheat Analog Sensor
Download and fill out the Spindle Motor Inspection Report Checklist below before replacing any parts.
Alarm 123 SPINDLE DRIVE FAULT
Alarm 236 SPINDLE MOTOR OVERLOAD
Internal short circuit. Test the spindle motor.
Failed temperature sensor. Test the overheat sensor.
Over-aggressive application. Adjust the program.
Vector drive shorted. Test the vector drive.
Vector drive fans failed.
Cable connection incorrect or loose. Inspect cables and connections.
The spindle motor cable is shorted.
Wye/Delta contacts burnt or shorted. Test the Wye/Delta.
Spindle encoder belt worn or damaged. Examine the encoder belt.
Alarm 4.254 SPINDLE MOTOR OVERHEAT Over-aggressive application. Adjust program.
Spindle fan failed. Check spindle fan and cable.
The input cable for the spindle head does not have a ferrite filter. See Spindle Motor Overheat section below.
Alarm 4.9975 S (SPINDLE) MOTOR TEMPERATURE CRITICAL OVERHEAT This alarm is generated through the built-in spindle motor overheat switch. See Spindle Motor Overheat section below.
Alarm 4136 MOTOR CONFIGURATION FILE NOT SELECTED Motor configuration file was not selected after new kit download.
Call your HFO to update your spindle motor brand configuration.
For Service Techs: Log-in to HBC. Navigate to Service > Utilities > Documents and Software >  12 - Activation Codes and Configuration Files > 5 -  Spindle Motor - Brand Configuration - NGC
For 8.1/10/12 K 40T Spindle Motors Built between 10/2024 and 5/2025 only: Decreased performance, epecially between 4k and 6k RPM. Long acceleration periods to commanded speeds.  Spindle Motor Parameters may be set incorrectly.
Check spindle motor brand. See 10.3 40T Spindle Motor Brand Identification. Contact your HFO with your spindle motor brand and serial number.
For Service Techs: Set the spindle motor brand. Spindle Motor - Brand Configuration - NGC. This is Distributor Only Content.
and Load Hardware Definition File menu is blank.
Missing configuration files.
Take an error report and contact your HFO.
Motor noise.
Poor finish on parts (Inline only).
Determine if the problem is mechanical or electrical.
  1. Run the spindle to where the noise is heard.
  2. Turn off the machine.
  3. If the noise is still heard then the problem is mechanical.
  4. If the noise goes away then test all the electrical components in the spindle drive system.
Vibration due to damaged bearings. Do a vibration analysis.
Coolant contamination. Inspect the TSC union for leaks.
Spindle motor coolant damage. Coolant intrusion due to TSC union leaking.
Ensure the spindle motor has the latest compensation TSC union installed respectively to the machine:
  • 93-2778: TSC UNION ASSY COMP 40T VF RETROFIT SKIT
  • 93-2779: TSC UNION ASSY COMP DT/DM RETROFIT SKIT
    Refer to AD0391 to upgrade from a bearingless TSC union to compensating TSC union.
Upgrade machine software to version 100.22.000.1000 or higher.
Loud screeching during acceleration/deceleration or RPM change.  Motor parameters set incorrectly.
Contact your HFO to update Spindle Motor Parameters.
 For Service Techs: Log-in to HBC. Navigate to Service > Utilities > Documents and Software >  12 - Activation Codes and Configuation Files > 5 -  Spindle Motor - Brand Configuration - NGC
Alarm 4.254
  • This alarm is generated when the analog sensor [1] detects a limit in temperature for a certain amount of time.
  • It can be also caused if there is too much electrical noise in the cable that provides wrong feedback to the control.  Make sure the cable has a ferrite filter installed at connection P39 on the I/O PCB. If the cable does not have a ferrite filter installed, install one. (P/N: 64-1252).
  • The analog sensor data can be seen in DIAGNOSTIC>I/O tab, Analog input #9 SPINDLE MOTOR TEMPERATURE.
Alarm 4.9975
  • This alarm is generated through the built-in spindle motor overheat switch [3].
  • If spindle motor temperature checks correct.   Make sure that the cable is not damaged and that it is connected.  Check the connection at the Maincon PCB Channel 6.
  • The spindle motor overheat switch status can be viewed on Diagnostic>Mocon tab, “CH 6 [S] Axis Brake Air Pressure” [4].
Spindle Motor Test
Corrective Action:
Disconnect all the wires from the terminal block that come from the electrical cabinet and remove the jumpers.
Use a multimeter to check these terminals on the motor:
  • Measure between motor leads or terminals (1-4) (2-5) (3-6). If the difference between each pair is more than 0.1 Ohms, replace the spindle motor.
  • Measure between motor leads or terminals (2-4 and 3-4) (1-5 and 3-5) (1-6 and 2-6). If the multimeter reading is not open (O.L.), replace the spindle motor.
  • Measure between each individual motor lead or terminal and the motors armature. If the multimeter reading is not open (O.L.), replace the spindle motor.
Vector Drive Test
Corrective Action:
Press [POWER OFF].
If the vector drive voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED on the vector drive to go off completely.
Inspect the vector drive.
Disconnect terminals 2 and 3 and check for a short to the spindle motor circuit by measuring the resistance of terminal 2 to 9, 10, and 11. Measure terminal 3 to 9, 10, and 11.
Go to Vector Drive - Troubleshooting Guide to troubleshoot the vector drive.
Wye/Delta Inspection
Corrective Action:
Check for loose connections or burn marks.
Go to Wye-Delta Contactor - Troubleshooting Guide to troubleshoot the Wye/Delta contactors.
Spindle Motor Cables Test
Corrective Action:
  1. Disconnect all the spindle motor cables from the amp/vector drive (terminals A, B, C. + GND).
  2. If machine is equipped with a Wye-Delta contactor, disconnect the cable going to the motor. (L1,L2,L3 + GND).
  3. Disconnect the spindle motor cables from the motor, including the ground cable.
     Important: At the motor end put electrical tape to each lead to make sure the leads do not touch each other.
  4. At the electrical cabinet end, using a meter test for resistance across each lead. Take the same readings from the cable that goes to the motor from the Wye-Delta contactor.
    • If the meter reads O.L. then the cable is good.
    • If the meter reads a short circuit or low resistance the cable needs to be replaced.
Make sure all cable connections are not damaged. Use a multimeter to test each cable connection.
Regen
Corrective Action:
Disconnect the REGEN load leads from the vector drive at terminals 1 and 2. Measure the resistance across the leads. The reading must be as follows:
  • 2-resistor box: between 9.5 and 12.5 ohms.
  • 3-resistor box: between 6.3 and 8.3 ohms ohms. (As shown in the illustration.)
  • 4-resistor box: between 4.6 and 6.6 ohms.
Go to REGEN - Troubleshooting Guide to troubleshoot the REGEN resistors.
Spindle Fan
Corrective Action:
Check for airflow on top of the spindle enclosure. Make sure there is air flow out of the spindle enclosure when the spindle is commanded to run. DT/DM were setup to blow air down onto the motor but it should now be blowing out the top. Change the fan direction to blow out the top.
Run this command in MDI: S50 M03;
Check the voltage across the black and red wires on the I/O PCB at this location:
  • P32 if the machine has a Next Generation Control
The voltage should be 120 VAC. If no voltage is present, the I/O PCB is bad.
Encoder Belt
Corrective Action:
Make sure the encoder belt is adjusted correctly and is not damaged. Replace a damaged or worn belt.
Make sure the encoder pulley is not damaged. Make sure the set screw is tight.
Program/Application
Corrective Action:
Reduce the axis feed rate, or adjust the spindle rpm in the program.
Check for dull or damaged tooling.
Coolant (TSC Only)
Corrective Action:
Remove the head cover and inspect the TSC union for leaks. A leaking coolant union may cause coolant to get into the motor and wash the grease out of the bearings.
Bearings
Corrective Action:
Damaged bearings in the spindle motor can cause finish issues on the part. Contact your local HFO for a vibration analysis to see if the bearings are damaged.
Electrical Diagrams: Spindle Encoder Feedback / Drive Command
