Bearingless TSC Union to Compensating TSC Union - Upgrade - 30/40-Taper - AD0391
Service Home How To Procedures Bearingless TSC Union to Compensating TSC Union - Upgrade - 30/40-Taper - AD0391
Recently Updated Last updated: 08/27/2024
AD0391
- Jump to Section - 1. Introduction 2. Bearingless TSC Union to Compensating TSC Union - Upgrade - 40-Taper (9 steps) 3. TSC Compensating Union - Test (3 steps) 4. Compensating TSC Union Troubleshooting Back to Top
Important: This document is to upgrade to compensating union from bearingless union, not replacement kit for compensating union. For Compensating Union replacements, refer to AD0377 for the appropriate service kit and installation instructions.
Machine Compatibility
  • VMC/HMC with TSC 300, 1000, or 1k
  • VMC/HMC with Yaskawa spindle motors
  • DT/DM with TSC 300, 1000, or 1k
Document Applies to these Parts:
  • 93-2778: TSC UNION ASSY COMP 40T VF RETROFIT SKIT
  • 93-2779: TSC UNION ASSY COMP DT/DM RETROFIT SKIT
Tools Required:
  • Spindle Lock Tool (T-1635)
  • Dial Indicator (that can measure 0.0001") with Magnetic Base
  • Red-I Grease
  • Crows foot wrench
  • 99-0698 TSC union alignment tool
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Remove the spindle head covers.
Install the spindle lock tool (T-1635) onto the spindle.
For machines with a CALM:
  1. Locate the spindle solenoid. Remove the quick connect, and orifice [1].
  2. Install the T fitting , orifice , and quick connect [2] (parts B,C,& D) as illustrated. Install the removed components [1] on top of the T fitting.
  3. Rout the new 5/32 clear hose from the new fitting on the spindle solenoid to the TSC union in the spindle head.
  4. Unplug the power to the TSC/TAB Union Solenoid. Unplug and cut off the grey hose in the CALM panel and discard it.
For machines without a CALM:
  1. Locate the spindle air supply.
  2. Install the T fitting , orifice , and quick connect to create a T juction in the spindle air supply line.
  3. Rout the new 5/32 clear hose from the new T junction to the TSC union in the spindle head.
Remove the grey air hose and fittings [1] from the TSC drain (vacuum generator). Discard the removed items.
Insert a plug into the top of the TSC drain [2].
Replace the lower TSC hose fitting on the check valve with the new JIC fitting [3].
Remove and record the location of these parts from the bearingless TSC union:
  • high-pressure braided hose [1] (discard, remove from machine)
  • 20' (6096 mm) 1/4" gray tube [2] (discard, remove from machine)
  • 5' (1524 mm) 1/4" gray tube [3] (discard, remove from machine)
  • clamp for the 3/8" black hose [4]
  • 3/8" black hose [5]
Remove these parts from spindle motor:
  • (4) 1/4-20 socket-head cap screws (SHCS) [6]
  • bearingless TSC union [7]
  • (4) standoffs [8]
  • shaft [9]
     Note: Turn the shaft clockwise to remove it.
Remove the spindle lock tool.
Use the dial indicator [3] to measure the total indicated runout (TIR) of the shaft [2] and the top carbide [4].
The radial [3] and axial [4] TIR must be less than .0005''.  If the TIR exceeds this value, shim the TSC shaft.
To shim the TSC shaft:
Measure the radial runout [1].
Mark the high spot with a pen [2].
Loosen the TSC shaft enough to create a gap between the TSC shaft and the motor shaft.
If the radial runout is than .0015'' use .0005'' shim stock.
If the radial runout is greater than .0015'' use .001'' shim stock.
Insert the shim at the marked location [3] and torque the TSC shaft to 30 ft-lb.
Trim away the excess shim stock.
After shimming the TSC shaft:
Measure radial runout [1].  It must not exceed .0005''.
Measure axial runout [2].  It must not exceed .0005''.
If shaft runout cannot be corrected with shims contact Haas service.
Install the compensating union with the mounting bolts [1] loose and insert the alignment tool [2] through the fitting on the top of the coolant union to align it with the motor shaft.
Turn the motor by hand to make sure the shaft is not rubbing as you tighten the union bolts. Torque the bolts to 12 ft-lbs (16 Nm)
Remove the alignment tool.
Run the spindle motor at 100 RPM and verify the union is not rubbing on the shaft.
Note: A flat ended dowel pin or other cylindrical part that is 0.275 inches in diameter and at least 2.6 inches long is needed for this step.
Insert your dowel pin [1] into the top JIC fitting [2] until you feel it contact the piston [3].
 Note: The top cover has been removed in this image to illustrate the piston. Do not disassemble the union.
Lightly press downwards until you feel the piston [3] contact the shaft [4] to eliminate the gap [5]. The piston will move about 0.040".
Install the replacement TSC hose from the check valve to the union. Install the new 5/32 clear hose from the spindle solenoid to the union. Connect the drain hose to the union.
With no tool in the spindle, command TSC.
Check that a steady stream [1] of coolant comes out of the spindle.
Check the amount of coolant coming out of the drain tube. There should be no coolant draining but a steady drip [2] is acceptable.
Run TSC with the spindle at 1000 RPM.  Slowly ramp the speeds up to the maximum spindle RPM.
The union may make ringing noises as the carbide wears in. This noise should diminish within minutes of running for the first time. The noise may return briefly each time the speed or pressure is increased.
Insert a TSC tool with a small orifice [1] in the spindle, run TSC with the spindle at 1000 RPM. Slowly ramp the spindle speeds up to the maximum RPM.
Check that the amount of coolant coming out of the drain tube is not more than a steady drip [2].
A large flow of coolant comes out of the drain when the TSC is turned on for the first time. The union piston is not seated. Turn on TSC again with a TSC tool in the spindle and then quickly turn it off. The back pressure, or the TSC Purge cycle will likely push the piston down. Or, disconnect the hydraulic hose from the top of the union and use a screwdriver to manually seat the piston.
The amount of coolant flow from the drain tube is more than a few drops. Runout on the carbide tip or damage to the piston cup seal Check the motor shaft for runout. Inspect the piston cup seal.
The union is leaking coolant. Leaky drain tube or no air supply to the union. The drain tube connection is not watertight and requires glue to seal it during union assembly, make sure the hose clamp is tight. Check the solenoid and hose for air supply problems.
The union makes a high pitch ringing noise when running TSC that does not go away after a few minutes of running. TSC union alignment, or shaft runout. Check the motor shaft for runout. Inspect the piston cup seal. Re-align the union with no hoses connected.
The union makes a high pitch ringing noise when running TAB that does not go away after a few minutes of running. Excessive back pressure. Try using a tool with larger orifices to reduce back pressure or try turning on TSC briefly to lubricate the seals.
