UMC-500/750/1000 Rotary Brake Bleed - AD0496
Service Home How To Procedures UMC-500/750/1000 Rotary Brake Bleed - AD0496
- Jump to Cause - Back to Top
10.1 UMC ROTARY BRAKE BLEED - PROCEDURE
Recently Updated Last updated: 06/25/2025
UMC-500/750/1000 Rotary Brake Bleeding - Procedure
AD0496
Revision A 06/2025
Use this procedure to bleed the rotary brakes on Reboot UMC machines.  For a UMC750 Non-Reboot machine refer to AD0309 UMC-750 B and C Axis Rotary Brakes - T-0062C Bleed - Instructions.
Note:  To identify which iteration of these machine models you are dealing with, refer to UMC-750 Machine Version - Identification.
This document applies to the following service kit:
  • 93-3243 UMC ROTARY BRAKE BLEED SERVICE KIT
Preparation - Bleed Tool Assembly
Assemble the bleeding tool as shown.
Use teflon thread sealing tape if necessary.
Note: Be sure the arrows on the check valve are pointing towards 58-3050
B-Axis Bleeding
  • Home the B-Axis
  • Press MDI, program "M11", press cycle start.
  • Press the Emergency Stop button
  • Open the lube panel on the tool-changer side of the machine
  • Rotate the air shut off valve to cut off air the the machine
    • The wings of the valve should be perpendicular to the pipe
Purge excess air pressure from the machine by pulling and holding the ring on the purge valve until you no longer hear air escaping.
Note: The initial pull of the ring will make a popping sound. This is normal.
  • Remove access plug
  • To do so, drill a pilot hole then, screw in a wood screw to use as a handle to pull the plug out
Use a T-handle allen wrench to remove the threaded brake bleed plug.
Note: Be careful to not drop this plug into the casting.
  • Screw in and tighten the bleed tool.
  • Ready a catch -can to catch any oil bled from the brake system.
  • Attach a clear 1/4" OD hose to the bleed tool and run it to the catch-can.
  • Turn air back on. The wings of the the valve should run parallel to the pipe.
  • Release Emergency Stop and clear alarms.
  • Open MDI, program "M10", press Cycle Start.
  • The booster will pulse 3 to 5 times in an attempt to build pressure and in doing so will pump out brake fluid.
  • You should recieve alarm 6.4011 Rotary Brake Engagement Failure.
  • Clear the alarm and repeat until all air bubbles are bled from the system.
  • If you did not recieve this alarm, and no oil left the bleed tool, check to see that the check-valve of the bleed tool is properly oriented.
  • When finished, press emergency stop then turn air off again.
  • Purge excess air pressure from the machine by pulling and holding the ring on the purge valve until you no longer hear air escaping.
  • Remove the bleed tool then, quickly reinstall the threaded plug being careful to not drop the plug in the casting.
  • Turn air back on
  • Jog the B-Axis, then X-axis, then B-Axis again to ensure the B-Axis brake reliably engages and disengages.
  • Be sure to refill the B-Axis brake fluid resevoir to the appropriate level
  • Install a new B-Axis bleed port access plug (20-5715)
C-Axis Bleeding
  • Jog the C-axis platter such that the access hole is in the 3 O'clock position.
  • Press MDI, program "M13", press cycle start.
  • Open MDI, program "M12", press Cycle Start.
  • The booster will pulse 3 to 4 times in an attempt to build pressure and in doing so will pump out brake fluid.
  • You should recieve alarm 7.4011 Rotary Brake Engagement Failure.
  • If you do not recieve this alarm, and no oil leaves the bleed tool, check to see that the check-valve of the bleed tool is properly oriented.
  • Turn air back on
  • Jog the C-Axis, then X-axis, then C-Axis again to ensure the C-Axis break reliably engages and disengages.
13
  • Install a new C-Axis bleed port access plug (22-9087)
