EC-400 - APC Rotation Cylinder - Replacement
Service Home How To Procedures EC-400 - APC Rotation Cylinder - Replacement
Recently Updated Last updated: 08/14/2020
- Jump to Section - 1. Introduction 2. Cylinder Removal (6 steps) 3. Cylinder Installation (4 steps) 4. Cylinder Damper Adjustment (1 step) 5. H-Frame I/O Status (1 step) Back to Top
The EC-400 Pallet Changer has a hydraulic cylinder with a gear rack attached to one end. Upon extension and retraction, the cylinder will rotate a gear on the pallet changer counter clockwise and clockwise respectively (viewed from the top of the machine). The cylinder has an internal dampner to help smooth the rotation motion. Over the life of the machine, the seals in the cylinder will wear, lessening the effectiveness of the dampner. The cylinder can be removed and replaced.
Cylinder Removal
Remove the HPU service panel[1], giving access to the cylinder and the hydraulic power unit[2].
Ensure that pallet 1 of the pallet changer is in the machine. Perform a pallet change if necessary.
Note: For pallet pool machines, the pallet 1 referenced in this procedure is not the pallet 1 in the pallet scheduler, but the number 1 on the pallet changer H-Frame. This ensures that the cylinder is in its retracted state.
On the operator pendant, enter the pallet changer recovery mode by pressing RECOVER, followed by 2 to select Automatic Pallet Changer.
In the pallet change recovery, press F2[3] to unclamp, and then press F1[2] to lift the pallet changer. F3[4] can be pressed to turn off the air blast.
Press the E-STOP button.
Remove the four bolts securing the cylinder to the pallet changer bridge casting.
Rotate the pallet changer by hand, turning the H-Frame clockwise approximately 60 degrees[1]. This will push the cylinder out.
Note: Do not rotate the H-frame once the gear rack on the cylinder is free of the gear. This will cause the gear rack mesh to be one or more teeth off upon reinstallation, and the pallet changer will not function correctly.
Remove the cylinder and disconnect the hydraulic lines. There may be residual fluid in the lines, so plug the hydraulic lines. The Pallet Changer rotation circuit is not connected to the accumulator so there will be no pressure when the HPU is not running.
Measure the distance that the gear rack is to the cylinder mounting flange and record this number. This measurement will be used when installing the gear rack onto the rebuilt or replacement cylinder. Remove the gear rack and locking nut from the cylinder rod.
Note:  The gear rack was changed to have a notch added so it would not trip the sensor before the pallet was in place. Replace the gear rack with the new version. Check to see what version you have before ordering replacement part.
Install the gear rack and lock nut onto the replacement cylinder, using the measurement from the previous step to set the rack position. Tighten both damper adjustment screws all the way down then back off a turn and a half. Install the cylinder into the pallet changer, with the cylinder in the retracted position. Install the four bolts.
Rotating the H-Frame by hand, verify that the pallet changer stops at the 0 and 180 degree positions. If they do not, either the rack is not adjusted correctly on the cylinder rod, or the gear and gear rack are off one or more teeth.
Once any misalignment is correct, return pallet 1 to the to the inside of the machine. Lower the H-Frame and clamp the pallet via the recovery page.
If the pallet cylinder damper is not slowing the pallet, causing it to slam into the hard stop. Adjust the damper on both sides of the cylinder. Counter clockwise on the screw to open and speed up the damper. Clockwise to close and slow it down.
H-Frame I/O Status
Use the H-Frame I/O status section the Pallet Changer Troubleshooting Guide to verify all the switches are in the correct state depending on the pallet location.
