ST-10/15/20/28/30/35 - Non-Contact Encoder Ring - Replacement
Service Home How To Procedures ST-10/15/20/28/30/35 - Non-Contact Encoder Ring - Replacement
- Jump to Section - 1. Introduction 2. ST-10/20/28/30/35 - Non-Contact Encoder Ring - Removal (4 steps) 3. ST-10/20/28/30/35 - Non-Contact Encoder Ring - Installation (2 steps) 4. Lathe Encoder Ring to Read Head Alignment 5. Conclusion Back to Top
Recently Updated Last updated: 07/30/2025
Version A - 07/2025
This procedure tells you how to replace the non-contact encoder (NCE) ring on the lathe spindle. The replacement encoder ring may be from a different manufacturer than the encoder ring you are replacing. The installation and operation are the same.
 CAUTION: Always replace the encoder ring and the read head as a set. Gen 1 and Gen 2 NCEs will not communicate with each other’s components. A replacement with a Gen 2 NCE requires a full replacement for the read head and ring.
 NOTE: Gen 2 NCEs will have "Gen 2" printed both on top of the read head and on the side of the ring. Gen 1 NCEs do not have any print indicating that its Gen 1.
 IMPORTANT: When replacing a non-contact encoder under warranty, make sure the old part is returned in the replacement part packaging, or the warranty may be voided.
IMPORTANT: Gen 1 and Gen 2 NCEs will not communicate with each other’s components. A replacement with a Gen 2 NCE requires a full replacement for the read head and ring. Gen 2 NCEs will have "Gen 2" printed both on top of the read head and on the side of the ring. Gen 1 NCEs do not have any print indicating that its Gen 1.
Power off the machine.
Remove the front left enclosure panel [1] to gain access to the spindle encoder.
Disconnect the spindle encoder cable from the read head.
Remove the bolts [1].
Remove the read head [2].
Remove the bolts [3].
Remove the NCE read head mount [4].
IMPORTANT: Do not dispose the read head mount[4]. It will be reinstalled.
Slide the halves of the T-0116 [1] around the NCE ring.
Install the shoulder bolts [3] through the cross bar [4].
Turn the bolt [1] to pull the NCE ring from the hub.
NOTE: Hold the T-0116 crossbar from rotating with the 1" open end wrench while pulling the NCE ring.
Use the hot plate to heat the replacement NCE ring to 300°F (150°C).
IMPORTANT: Do not exceed 320°F (160°C) when heating the NCE ring. Overheating the NCE ring will cause permanent damage.
Slip the hot NCE ring over the hub until the shoulder on the NCE ring is up against the hub.
Allow the NCE ring to cool.
Using a dial indicator measure the runout of the NCE ring and mark the high spot. The TIR must not exceed 0.003".
Install the NCE read head mount [3] and torque the bolts [3].
Fasten the read head [6] to the mount with use two WASHER FLAT 0.170ID X 0.400OD and two bolts [5]. Leave these bolts hand tight to set the air gap between the read head and the ring.
IMPORTANT: Gen 2 NCE read heads do not use any 45-2000 washers. Remove these washers if they were present underneath the Gen 1 NCE read head.
Align the previously marked high spot on the NCE ring with the read head.
Use the plastic shim that came with the replacement encoder [2] to set the air gap between the NCE ring and the read head.
Tighten the read head mounting bolts [1].
Connect the spindle encoder cable.
Install previously removed enclosure covers.
Proper alignment of the read head to the encoder ring is critical. The alignment will vary based on the brand of encoder. Use the chart provided to make sure the encoder ring and read head are properly aligned.
        VENDOR                                 RLS
               A                    0.0118" +0.0079 / -0.0039
               B                       0.0591" +0.059 / -0.019
               C                                    (0.0197")
IMPORTANT: If C for RLS Gen 2 NCE is over 0.0197" you will need to order a new NCE read head mount:
If machine is a ST-15/20 using a 20-8301 NCE READ HEAD MOUNT, TL, ST order:
  • 20-11056 MOUNT READ HEAD NCE 3" GEN 2 ST-15/20.
If machine is a ST-28/30/35 using a 20-8301 NCE READ HEAD MOUNT, TL, ST then order:
  • 20-11055 MOUNT READ HEAD NCE 3" GEN 2 ST-28/30/35.
        VENDOR                                 BAUMER
               A                                0.0118" +/-0.004
               B                                 0.045" +/-0.019
               C                                        (0.305")
Conclusion
If the machine is equipped with the C axis use the link below to reset the C axis engagement offset.
Lathe - C-axis Engagement Offset
