VMC- Chip Washdown System - Installation - AD0838
Service Home How To Procedures VMC- Chip Washdown System - Installation - AD0838
- Jump to Section - 1. Introduction 2. Chip Washdown System - Templates 3. VMC Small Template Alignment 4. VMC Medium Template Alignment 5. Installation (11 steps) 6. Test and Verification (1 step) Back to Top
Recently Updated Last updated: 06/15/2026
VMC - Chip Washdown System - Installation
Revision 4
AD0838
Revision G - 6/2026
Updated
This procedure tells you how to install the chip washdown system on small and medium VMC machines.
Machine Compatibility:
  • Multistage Pump
  • VF-1/2/3/4/5/SS/YT
  • VP-5
  • VM-2
  • Chip Separator Version A or higher
  • VR-5
Required Tools:
  • 18V Drill/Driver
  • Step Drill Bit - Up to 3/4"
  • 1/4" Drill Bit
  • 5/32" Hex Bit
  • Adjustable Crescent Wrench - 7/16", 11/16", 1-1/8"
  • 1/8" Drill Bit
  • Provided Hole Template (See table below)
  • Center Punch (Recommended)
  • Hose Cutter (Optional)
This procedure applies to the following service kits:
  • 93-1001188: WASHDOWN FIELD KIT VF S YT SMTC50   (VF-1/2 YT, VM-2 - 50 Pocket SMTC)
  • 93-1001189: WASHDOWN FIELD KIT VF S YT SMTC70   (VF-1/2 YT - 70 Pocket SMTC)
  • 93-1001190: WASHDOWN FIELD KIT VF S YT SMTC30   (VF-1/2 YT - 30 Pocket SMTC)
  • 93-1001191: WASHDOWN FIELD KIT VF S NYT SMTC30   (VF-1/2, VM-2 - 30 Pocket SMTC)
  • 93-1001192: WASHDOWN FIELD KIT SMTC50 VF-3/4   (VF-3/4 - 50 Pocket SMTC)
  • 93-1001193: WASHDOWN FIELD KIT VP-5 (VP-5)
  • 93-1001194: WASHDOWN FIELD KIT SMTC70 VF-3/4/YT   (VF-3/4/YT - 70 Pocket SMTC)
  • 93-1001195: WASHDOWN FIELD KIT SMTC30 VF-3/4/YT   (VF-3/4 YT - 30 Pocket SMTC)
  • 93-1001196: WASHDOWN FIELD KIT SMTC50 VF-3YT/40    (VF-3YT/40 - 50 Pocket SMTC)
  • 93-1001197: WASHDOWN FIELD KIT VF-3YT/50   (VF-3YT/50)
  • 93-1001198: WASHDOWN FIELD KIT SMTC50 VF-5/40   (VF-5/40 - 50 Pocket SMTC)
  • 93-1001199: WASHDOWN FIELD KIT SMTC70 VF-5/40   (VF-5/40 - 70 Pocket SMTC)
  • 93-1001200: WASHDOWN FIELD KIT SMTC30 VF-5/40   (VF-5/40 - 30 Pocket SMTC)
  • 93-1001201: WASHDOWN FIELD KIT VF-5/50   (VF-5/50)
  • 93-1001395: WASHDOWN FIELD KIT UMB20 VF-5/40
  • 93-1001396: WASHDOWN FIELD KIT UMB20 VF-3/4/YT
  • 93-1001397: WASHDOWN FIELD KIT VR-5
Chip Washdown Alignment Templates will help to place the chip washdown system in the correct location on your machine.
For the placement information below, please reference the image for the alignment section.
[1] Indicates the right side of the machine when facing the front of the machine.
[2] Indicates the left side of the machine when facing the front of the machine.
NOTE: The image shown references a VF-2YT. Be sure to use the correct alignment and template for your machine.
Use the chart to download the correct templates for your Small VMC Machine. Then, reference the images below to accurately place the template on the machine.
Be sure the bottom edge of the template is aligned with the seam between the bottom pan and back panel, with the text facing right-side up. Use tape to secure the template in place so that it does not slide while marking or drilling the hole centers.
VMC SMALL
Machine Back Left Template Alignment Back Right Template Alignment
VF-1/2. VM-2 with 30 Pocket SMTC
See Back Left Template Placement [3]
VF-1/2, VM-2
See Back Right Template Placement [4]
VF-1/2 YT with 30 Pocket SMTC
VF-1/2 YT
VF-1/2 YT, VM-2 with 50 Pocket SMTC
VF-1/2, VM-2
VF-1/2 YT with 70 Pocket SMTC
VF-1/2 YT
3. Back Left Template Placement:
Align the right slot of the template above the 2nd screw from the left.
Align the left slot of the template above the 3rd screw from the left.
4. Back Right Template:
Align the slot of the template above the second screw from the left.
Use the chart to download the correct templates for your Medium VMC Machine. Then, reference the images below to accurately place the template on the machine.
VF-3/4/YT
VF/3/4/YT with 30 Pocket SMTC
VF-3/4/YT - 30 Pocket SMTC
See Back Left Channel Corner Placement [5]
VF-3/4/YT
See Back Right Channel Edge Placement [9]
VF/3/4/YT with 70 Pocket SMTC
See Back Left Channel Edge Placement [6]
VF-3/4/YT
VF-3/4 UMB-20
UMB-20 VF-3/4
VF-3/4/YT
VF-3/4 with 50 Pocket SMTC
VF-3/4/YT
VF-3 YT/40  with 50 Pocket SMTC
VF-3/4/YT
VF- 3 YT/50
VF-3YT/50
See Back Left Second Screw Placement [7]
VF-3YT/50
VF-5
VF-5/50
VF-5/50
VF-5/50
VF-5/40 with 30 Pocket SMTC
VF-5/40
VF-5/40 with 50 Pocket SMTC
VF-5/40
VF-5/40 with 70 Pocket SMTC
VF-5/40
VF-5/40/XT with UMB 20
UMB-20 VF-5/40/XT
VF-5/40
VP-5
VP-5
VP-5
See Back Left Channel Edge Placement [6].
VP-5
See Back Right Channel Corner Placement [10]
5. Back Left Channel Corner:
Align the cutout of the template to the channel corner.
6. Back Left Channel Edge:
Align the template to the left or right side of the channel, as indicated on the template.
7. Back Left Second Screw Placement:
Align the slot of the template above the second screw from the right.
8. Back Left Chiller Stand Placement
Align the cutout of the template above the chiller stand.
9. Back Right Channel Edge Placement
Align the side of the template along the channel edge, as indicated by the template.
10. Back Right Channel Edge Placement
Align the cutout of the template along the channel corner, as indicated by the template.
Use the provided hole template [4] on the left side on the outside of the back panel of the machine.
Align the template so that the third screw [3] from the right is aligned with the left line of the template and the second screw [2] from the right is aligned with the right line of the template.
Use a center punch to mark the hole centers OR Use a 1/8" drill bit to drill pilot holes.
Use a 1/4" drill bit to drill holes starting with the first hole [1] and following in the pattern shown, without drilling the center hole.
Drill a pilot hole to the minimum inner diameter of the step drill to the middle hole [4].
Use the step drill to drill a 1/2" diameter hole through the middle hole [4].
Be sure that the threads of the push-connect fitting fit through the hole.
Use 3X of the 1/4-20 button-head screws (15/32" hex) [2] to install the support bracket [1] to the interior face of the back panel.
Use a 7/16" wrench to tighten the 3X flange nuts [3].
NOTE: A second person may be necessary to help tighten the screws.
Insert the manifold [1] in the arms of the support bracket [2].
Use a washer [3] in-between the back panel and the push-connect fitting [4] and install the push-connect fitting through the back panel and thread into the tee of the manifold.
Tighten the push-connect fitting with an 11/16" wrench.
Use the provided hole template [1] on the right side on the outside of the back panel of the machine.
Align the hole template so the slot aligns vertically with the second screw [2] from the left that connects the bottom pan to the back panel.
Be sure the edge aligns with the support channel.
Repeat steps 1-5 for this side.
Use a 1-1/8" wrench to remove the garden hose cap [1] and fitting from the chip separator manifold and install the supplied tee fitting [2] with push-connect fittings.
NOTE: You may need to remove the bottom push connect fitting [3] in order to tighten the tee. Version B chip separators can skip this step.
Route the supplied hoses as shown. Check if the hoses are properly installed by gently tugging at the base of the hose connected into the push-connect fittings.
NOTE: The 8-foot hose should be routed through the cutouts of the base casting. Excess hose lengths can be trimmed with a hose cutter, but ensure that the hoses are not tight or kinked. Do not trim hose at an angle.
To test if there are any leaks, turn on the coolant and check the push-connect fittings at the hose and threaded ends, support bracket, and tee fitting at chip separator manifolds.
Tighten fittings where necessary.
Angle the nozzles down at approximately a 45-degree angle. Ensure that the coolant nozzles do not hit the sheet metal.
  • Rotate the manifold [1] clockwise and counterclockwise by hand or with a hex bit on the plug end.
  • Rotate the steel fitting [2] clockwise and counterclockwise by hand or with a crescent wrench.
NOTE: Loosening manifold or steel fitting excessively may result in reduced pressure and performance. Do not loosen too much.
For installation kits that come with the anti-rotation, flanged bracked [1], rotate the coolant nozzles until they're flush with the flange. This will hold the nozzles at the correct angle while coolant is flowing. .
Updated
Go to MDI and type in M08.
IMPORTANT:  VMC-6 models and larger are equipped with a dedicated chip washdown pump. For these machines, use M07 to activate the chip washdown system.
Press [Cycle Start]
Test the flow of coolant through the manifold. Coolant should form a continuous sheet along the bottom of the machine.
Note: Coolant from nozzles should NOT be hitting the machine's table or saddle.
