30/40-Taper - Tool Release Piston - Pre-charge - Adjustment - VMC
Service Home How To Procedures 30/40-Taper - Tool Release Piston - Pre-charge - Adjustment - VMC
Recently Updated Last updated: 09/27/2023
- Jump to Section - 1. Introduction 2. Belt/Gearbox Drive - Tool Release Piston - Pre-charge - Adjustment (1 step) 3. Inline Drive - Tool Release Piston - Pre-charge - Adjustment (2 steps) 4. Through Spindle Coolant - Tool Release Piston - Pre-charge - Adjustment (3 steps) Back to Top
This procedure tells you how to adjust the pre-charge for the Tool Release Piston (TRP) of a 30 or 40-taper spindle. Complete this procedure before you adjust the TRP clamp/unclamp switches.
The following service video shows how to set the TRP precharge.
  NOTE:  This  service video is for reference only and does not replace the written procedure.
 Caution: Do not perform this procedure on a machine that has through-spindle coolant (TSC). This damages the TSC system.
Find the knob on the pre-charge air regulator. Turn the knob counter clockwise until it stops.
Make sure Parameter 149 PRE-CHARGE DELAY is set to 300.
Make sure no tool is in the spindle.
Push the [Tool Release Button].
 Note: If the pre-charge is not correctly adjusted, you hear a loud noise when the piston hits the drawbar.
Turn the main air pressure regulator clockwise one half turn.
If you hear the TRP hit the drawbar, turn the main air pressure regulator clockwise one quarter turn.
 Caution: Do not increase the pressure too much. Only increase the pressure until you cannot hear the TRP hit the drawbar.
To assemble a pressure gauge assembly:
  • Attach the gauge [1] to the tee-fitting [3].
  • Attach the (2) quick-release fittings [2] to the tee-fitting [3].
  • Cut the 1/4" tubing in half. Connect the (2) pieces to the quick-release fittings [2].
Remove the toolholder from the spindle.
Close the primary air valve. This stops the air supply to the machine.
Install a pressure gauge at the output-side of the pre-charge regulator.
 Note: The configuration in the illustrations show one example. This is not the correct configuration for each machine.
Open the primary air valve.
Turn the pre-charge regulator adjustment knob counterclockwise to the fully out position.
 Note: For newer machines, the pre-charge regulator is not adjustable. There is no adjustment knob.
Run this code in MDI mode:
M59 P1120;
Set the pre-charge regulator to 30 psi (2.1 bar).
 Note: On newer machines, the pre-charge regulator has no adjustment knob. You cannot adjust the pressure.
Read the pressure gauge. Make sure the pressure is 30 psi (2.1 bar). If the pre-charge regulator cannot keep the pressure at 30 psi (2.1 bar), you must replace it.
Push [RESET].
Lock the adjustment knob on the regulator.
Remove the pressure gauge from the pre-charge regulator.
  • Insert the 1/4" tubing [4] into one of the quick-release fittings [2].
Disconnect the tube [1] from the output-side of the pre-charge pressure regulator [4].
Put the tube into the top of the pressure-gauge assembly [2].
Connect the 1/4" tube [3] from the pressure-gauge assembly to the regulator.
On some machines, you cannot adjust the regulator. Use the pressure-gauge assembly to make sure the regulator operates correctly. To make sure the regulator [2] operates correctly:
Adjustable regulator:
Push and hold the button on the pre-charge solenoid valve [1] for 20 seconds.
Pull the regulator adjustment knob to unlock it. Set the air pressure to Belt/Gearbox: 4 psi (0.28 bar)Inline: 30 psi (2.1 bar). Release the solenoid button. Push and hold the button on the solenoid valve [1] for 20 seconds.
Make sure the gauge shows Belt/Gearbox: 4 psi (0.28 bar) Inline: 30 psi (2.1 bar). Release the solenoid button. Push the regulator adjustment knob to lock it.
Non-adjustable regulator:
Make sure the gauge shows Belt/Gearbox: 4 psi (0.28 bar) Inline: 30 psi (2.1 bar). If the gauge does not shows the correct pressure, the regulator is defective. Replace the regulator.
Both: Remove the pressure-gauge assembly from the regulator.
