Power On/Off Circuit - Main Transformer - Troubleshooting Guide - NGC - TG0004
Service Home Power On/Off Circuit - Main Transformer - Troubleshooting Guide - NGC - TG0004
Jump to Section Back to Top
17.3 Power On/Off Circuit - Main Transformer - Troubleshooting Guide
Recently Updated Last updated: 10/08/2025
TG0004
This document will show you how to troubleshoot the power on/off circuit and the main transformer on a machine with the Next Generation Control.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Electrical Wiring for Haas Machines
Symptoms Probable Cause Corrective Action
Alarm 2095 TRANSFORMER OVERHEAT occurs at Power on. The machine detected a open circuit from the thermal switch at the transformer. Make sure the sensor is connected to the pigtail on P34 on I/O PCB. If is connected, jumper the wires. If alarm goes away check the overheat sensor by measuring the temperature on the transformer the sensor is normally closed until trip point 275F / 135C.
The transformer overheat cable pins making intermittent contact. Check the connector to make sure the connector is crimped correctly.
Alarm 2095 TRANSFORMER OVERHEAT occurs after the machine has been on for a long time, or during operation. The speeds and feeds are too high. Make sure the feeds and speeds are correct for the work.
The machine is located in a hot environment. Monitor the transformer temperature throughout the day. If the internal transformer exceeds 275F / 135C degrees throughout the day add the CABCOOL option.
Alarm 175 GROUND FAULT DETECTED. There is a short circuit in one of the 115 / 230 VAC components. Refer to the Ground Fault Circuit Monitor section in the Next Generation Control - I/O PCB - Troubleshooting Guide.
The Main Circuit Breaker Trips When you Press the [POWER ON] Button. There is a short-circuit in the main transformer. To troubleshoot the main transformer follow these simple steps:
  1. Turn off the main circuit breaker.
  2. Disconnect the 120 and 240 VAC output wires from the transformer.
  3. Turn on the machine. If the breaker trips the transformer is damaged.
The Vector Drive has a short-circuit.
Refer to the: Vector Drive - Troubleshooting Guide
The 320 VDC Power Supply has a short circuit. (OM, OL, MM, TM, TL, SR-100 Only)
Refer to the: High Voltage Power Supply (MMPS) Troubleshooting Guide.
One of the servo amplifiers has a short-circuit. Refer to the Servo Amplifier - Troubleshooting Guide.
The incoming voltage is not correct.
  1. Using a volt meter. Measure the incoming voltage at the top of the main circuit breaker.
  2. Make sure the incoming voltage is within the main transformer tap range.
Alarm 9100.005 POWER SUPPLY UNDEFINED. Pass/Fail lamps lit on PSUP PCB. There is a missing phase on the transformer. Check the three phase 240 VAC output on the transformer TB2. If there is a missing phase check for a loose connections on the terminal block TB2. Trace the missing phase all the way back to the main circuit breaker.
The machine will not turn on when the [POWER ON] button is pressed. The main circuit or service panel circuit breaker is turned off. Make sure the main circuit breaker or service panel breaker is turned on.
The T5 transformer jumper is not set correctly or the T5 transformer is defective. See the T5 transformer troubleshooting section below.
There is problem with the [POWER ON] or [POWER OFF] circuit. Make sure that the wires going to the [POWER ON] [POWER OFF] contactors terminals are secure. Check the cable from SKIBF to PSUP PCB see the above electrical diagrams.
The main circuit breaker is defective.
  1. Turn off the machine's main circuit breaker.
  2. Turn off the electrical service to the machine.
  3. Make sure that there is no voltage to the machine.
  4. Turn the machine's main circuit breaker to the ON position.
  5. Measure continuity between the top and bottom poles. If there is no continuity, replace the circuit breaker.
The K1 contactor coil is not receiving power or the wires are not connected on the correct terminals on the coil. Check that the K1 contactor is receiving approximately 24 VAC from the T5 transformer. See above diagrams.
The auto off circuit is open. Check the cable connection from the PSUP (P17) to I/O PCB (P56).
Machine equipped with CABCOOL shuts off intermittently. The main transformer is not tapped in the correct range. Measure the incoming voltage and check that the main transformer taps are placed on the correct range.  Note:  The main transformer generates a 240V/120V .  The cabcool runs off the 120V, if the 120V is not at nominal, then when the Cabcool turns on, the voltage can sag and cause the machine to turn off.
The CABCOOL thermal switch outlet (32-0376A) wiring is on the same phase that PSUP monitors for low voltage condition. Refer to the CABCOOL - Troubleshooting Guide.
The main transformer installed on the machine is not compatible with the CABCOOL option.  Note:  This probable cause does not apply to machines with the 480V option. Refer to the CABCOOL Installation procedure for correct power requirements.
The machine will not turn on. The F1 fuse is blown on the PSUP.
Check F1 fuse on PSUP and replace if necessary.
Check the JP1 jumper to be installed on PSUP if the machine has a High Voltage service input (380-480 VAC).
Note: If the machine has a 60 hp vector drive, make sure a 2A CERAMIC FUSE is installed at F1.
T5 Transformer Troubleshooting
The T5 transformer is a step down transformer that steps down the incoming voltage to approximately 24VAC. When the [POWER ON]  button is pressed this voltage is applied to the coil on the K1 contactor, then the machine will turn on.
Transformer Primary Check:
  1. Make sure the jumper is in the correct position for the input voltage.
  2. Disconnect the T5 transformer from the PSUP PCB.
  3. Find the cable for the T5 transformer. Measure the resistance between pins 3 (black) and 8 (yellow) on the cable. Use a multimeter set to ohms.
  4. When the T5 transformer operates correctly, you have one of these conditions:
Low Voltage T5 Transformer (32-1964)
  • Jumper at (221-240V) position the multimeter measures between 54 - 66 ohms.
  • Jumper at (180-220V) position the multimeter measures between 45 - 55 ohms.
High Voltage T5 Transformer (32-1965)
  • Jumper at (441 - 480V) position the multimeter measures between 216 - 264 ohms.
  • Jumper at (381- 440V) position the multimeter measures between 180 - 220 ohms.
  • Jumper at (340- 380V) position the multimeter measures between 153 - 187 ohms.
Voltage Check
  2. Use a multimeter set to Volts AC measure across pins 1 and 5, 1 and 6, 5 and 6.
  • You should measure 21.6 - 26.4 VAC between pins 1 and 5.
  • You should measure 10.8 - 13.2 VAC between pins 1 and 6.
  • You should measure 10.8 - 13.2 VAC between pins 5 and 6.
Electrical Diagrams
Machine Power On/Off Diagram
PSUP (P16) to SKIBF (J20) / SKIBF (J5) Detail Diagram
PSUP (P17) to I/O PCB (P56) Detail Diagram
T5 to PSUP (P13) / K1 to PSUP (P12) Detail Diagram
